Author Topic: MFT topped temp A-frame work bench  (Read 2907 times)
Offline Steptoe
« on: November 21, 2019, 08:08 AM »
Hi all, first time poster!
im very much a novice regarding w/work but want to get more hands on. I have very limited garage space and want to join 2 standard MFT tops together on a temp A frame with  beam setup, so it can be packed away easily and conveniently. Below is my planned work horse setup.
I would also like 2 MFT board joined so the dimensions are 2204 x 718 x 18 (or 2158x718 as I will need to cut 23mm of each to make the 96centres work). I was thinking about clamping these together using some sort of fixing such as the ZIPBOLT MINI WORKTOP CONNECTOR
How have others temp connected MFT tops together in a non permanent way?
« Last Edit: December 01, 2019, 07:20 AM by Steptoe »
Offline Steptoe
Re: MFT topped temp A-frame work bench
« Reply #1 on: November 21, 2019, 08:33 AM »
Plan is something like below....
« Last Edit: December 01, 2019, 07:23 AM by Steptoe »
Offline Dane
« Reply #2 on: November 21, 2019, 11:43 AM »
I think an easier way to join those for quick assembly and breakdown would be to use something like a Striplox product: http://www.joinlox.com/product/striplox-180/  or a coffin lock.  Both are used by set builders to quickly assemble and break down panels over and over again.
Offline Steptoe
« Reply #3 on: November 21, 2019, 12:07 PM »
Thanks Dane, the striplox 180d
looks a better bet as it will illuminate any side and height slop and keep the hole alignment true! many thanks
« Last Edit: December 01, 2019, 07:25 AM by Steptoe »
Offline Svar
« Reply #4 on: November 21, 2019, 12:14 PM »
I would use simple door hinges. Or perhaps a piano hinge. Unless the weight is an issue and you want to break it down into lighter pieces.
« Last Edit: November 21, 2019, 12:22 PM by Svar »
Offline jobsworth
  • Festool Baby.....
« Reply #5 on: November 21, 2019, 12:19 PM »
If space is a issue why dont you get this
https://festools-online.com/festool/festool-multifunction-tables-1/203802-festool-mobile-workshop.html
and this
https://festools-online.com/festool/vacuum-clamping/203148-festool-vac-sys-system.html
Add a extra table and a vacuum clamp and you should be good to go. More mobile set up and compatiable with other festool tools and accessories. remember Festools are a system
Offline cubevandude
« Reply #6 on: November 21, 2019, 12:33 PM »
I was planning on making a 5 X 9 foot take down top.  3 pieces of top 3 x 5 ft in a 2x4 frame with a rabbet in the top edge of the 2x4 so they fit together tight with supports under the joints.  You could use 3" door hinges to hold the corners together and knock out the pins when you take it apart.  An idea anyway. You could also add magnets to hold things down so the top is more secure.  This whole thing could sit on 2x4s in your sawhorses.
Offline Steptoe
« Reply #7 on: December 01, 2019, 07:34 AM »
Sorry for slow reply :) Thanks for the advice
Usual bad back story with me, so having it in smaller components is important
Offline Steptoe
« Reply #8 on: December 01, 2019, 07:39 AM »
and this
Sorry for slow reply :) thanks for the links and suggestion/guidance
Alas way to much money for me although that cart is a neat design
Offline Steptoe
« Reply #9 on: December 01, 2019, 07:54 AM »
Sorry for slow reply :) thanks for the suggestion. How r u getting on with urs? I ordered a pack of the striplox 180D already as they seem the quickest for assembly
Offline Bob D.
« Reply #10 on: December 01, 2019, 09:49 AM »
You could make the mating edges like puzzle pieces that slip together but I wonder if the joint would remain secure enough after repeated setups and breakdowns.
Offline Steptoe
« Reply #12 on: December 01, 2019, 10:34 AM »
Would create more surface area contact rather than just butting them together and would eliminate any lateral slip? Will ponder the idea but I think I'm commented to these sliplox 180d's now. Many thanks
Offline Steptoe
« Reply #13 on: December 01, 2019, 10:36 AM »
I did this and really enjoy it:
https://www.festoolownersgroup.com/member-projects/my-take-on-4-ft-x-8-ft-worktable/msg583651/#msg583651
Thanks for the link, unfortunately I can not see the images Mike?? Is it just me not able to view them?
Offline Mike Goetzke
« Reply #14 on: December 01, 2019, 12:44 PM »
@Steptoe
I linked the photos a different way - please try again.
Mike
Offline Steptoe
« Reply #15 on: December 02, 2019, 05:45 AM »
@Steptoe
Mike
@Mike Goetzke
That a great design Mike, both the layout of holes/slots and the simplicity of the track tube with dowels. Way more sophisticated than im planning for mine. Had a quick look for tube tracks here but they don't seem to sell any thing to match that this side of the pond, i'll just use my stock 2x4 for the minute.
Any changes that you would make to the dog holes or slots?
« Reply #16 on: December 02, 2019, 09:01 AM »
@Steptoe
Mike
@Mike Goetzke
@Steptoe
I like my setup so much I bought additional track tubes to make both one and two slab tables for around the house and on the go.
I really like the hole/slot pattern I put together for assembly (I can fit my parallel jaw clamps through the slots) but I'm thinking of making a slab or two with just 20mm hole pattern. Have found small parts and tools have a way to fall through the slots (mostly screws and pencils).
Mike
