Author Topic: MFT Rip Fence  (Read 28213 times)
Offline Boatman
    • Ancora Yacht service
Re: MFT Rip Fence
« Reply #30 on: March 13, 2011, 09:56 PM »
I will try this tomorrow and take some photos if anyone thinks ti is needed.
hi
yes some photos, it's a good idea
else (see the link), an idea to fix the piece (fence at left with a T-slot) with the veritas bench blade
My incra-jig with fence is clamped to the table and I used QWAS dogs to align the fence to the holes. The incra-jig was fully extended and zeroed.
Another view of the clamps
Just another view of the dogs registering the fence
A subfence wider than the saw rail is attached to the incra-jig with double stick tape or hot-melt glue, but I use tape.
The rail is lowered to show the overhang.
the overhang is cut off with the saw and the subfence is now zeroed to the saw blade.
A quarter inch rip that I made.
As you can see, whatever the incra-jig is set to is what you will cut
Check Out My Website:
http://ancorayachtservice.com/
Offline Jesus Aleman
Re: MFT Rip Fence
« Reply #31 on: March 13, 2011, 10:57 PM »
I have used the incra positioner (aluminum one) in a similar fashion before.  The only difference with Boatman's jig is that the aluminum fence is taller and therefore you have to provide a spacer between the edge of the guiderail and the incra fence otherwise the TS will hit the fence.   I have the pics, but unfortunately the FOG and my laptop are in a hate hate relationship when trying to load pictures.
Offline manu31
Re: MFT Rip Fence
« Reply #32 on: March 14, 2011, 02:15 AM »
ok thanks, i understand
so, you don't fix your pieces when you rip ; there are stuck in the corner (mft's fence and subfence) ; and nothing move ?
don't hesitate to correct my english mistakes
Offline markchamness
Re: MFT Rip Fence
« Reply #33 on: October 17, 2020, 12:12 PM »
10 years have passed since the original posting and surprisingly there's still no solution from Festool or other vendors.  A right-side fence would be very useful for repeatable cuts of thin strips.  (For example, 1 or 2 cm width.)  I don't need a 24 inch fence hanging off the right side.  A 6 inch fence would be sufficient.  The closest solution I can find is the following: https://precisiondogs.us/products/precision-fence-plate
Unfortunately, it doesn't have flag stops.
