Author Topic: Vacuum clamping making Domino that much faster  (Read 9282 times)
Offline Bill Wyko
« on: August 05, 2008, 02:28 PM »
This is just a plastic block with a hole drilled through top to bottom, then a hole drilled in the side to intersect the other hole and screw in a barbed fitting. Next put a ring of foam tape in a circle about 4 inches that goes around the drilled hole. Next make a circle of foam tape on the opposite side that is in a shape which will seal the work piece. Now set the block on a smooth, secure surface and turn on the pump. When you set your work piece ont the top, it will vacuume it in place. Now you can safley use your Domino to make the plunge and your work is very secure. Disconnect the hose and put on the next piece the re-attach the hose. This is about 10 times faster than using mechanical clamps. If you have any questions please feel free to ask.
« Last Edit: August 05, 2008, 03:56 PM by Bill Wyko »
The bitterness of poor quality, lingers long after the cheap price is forgotten.
Offline Peter Halle
Re: Vacuum clamping making Domino that much faster
« Reply #1 on: August 05, 2008, 02:43 PM »
Bill;
Great idea.  I use a similar setup to hold one end of crown molding or other molding in place while working alone.  Instead of disconnecting the hose from the barb, I have a short section of hose attached to the barb and then a john guest fitting attached to the main hose.
Offline Bill Wyko
« Reply #2 on: August 05, 2008, 03:58 PM »
|Good idea, thanks.
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #3 on: August 05, 2008, 06:24 PM »
Bill;
What's a john guest fitting??
Offline Bill Wyko
« Reply #4 on: August 05, 2008, 06:53 PM »
I think it's like a ball valve but push button. :-\
« Last Edit: August 05, 2008, 07:12 PM by Bill Wyko »
Offline Peter Halle
« Reply #5 on: August 05, 2008, 11:13 PM »
The fitting is like a compression fitting but instead of a wrench it has a little push ring that allow you to disconnect it by just pushing it in.  Remember chinese handcuffs when you were a kid.  Lowes, Home Depot and the other big box stores sell them in the area where they have brass fittings but these guys are plastic.  I'll take a picture and post.  Used a lot with diy people and pex plumbing.
Offline Peter Halle
« Reply #6 on: August 07, 2008, 11:35 PM »
Sorry for my delay in getting back.  Here is a fuzzy photo of the fitting I mentioned.
« Reply #7 on: August 07, 2008, 11:42 PM »
I didn't know these worked with vacuum tubing.
Offline Peter Halle
« Reply #8 on: August 07, 2008, 11:45 PM »
Yep.
I set up a jig for holding up crown or anything else on a wall - eliminates a helper.  Easy, cheap.  Reusable and reconfigurable.  Really makes the clients appreciate your other side too!!
Offline lat
« Reply #9 on: August 22, 2008, 04:54 AM »
What kind of vacuum pump do you use?
Lou
Offline Jim Kirkpatrick
    • My Instagram
« Reply #10 on: August 22, 2008, 11:37 AM »
Nice clamp but wouldn't it be easier to just use some sort of bench dog to bare against?
Offline Bill Wyko
« Reply #11 on: August 26, 2008, 02:55 AM »
Actually I think the vacuum is more stable because it holds the piece from moving any direction. I don't have to worry about it slipping and I don't have to hold the wood at all. IMHO.
Offline richard.selwyn
« Reply #12 on: August 26, 2008, 12:15 PM »
Looks like you'll be competing with the Festool vac sys (if you can still get mortgages in the US - to pay for one)  It's due here in September at about 1000 euros.  I think I like your inexpensive solution.  Can I have one in green tho? :D
