Author Topic: MFT 3 ideas for small shop  (Read 27641 times)
Offline Hal M
« on: February 13, 2018, 04:35 PM »
I have a small 8’x12’ shop in a shed.  I have used the MFT3 and TS55 as my primary saw.  I keep dust down with a Pro5 sander, a Trion Jigsaw and Domino. The  Festool system has allowed me to have a relatively dustless efficient space.   I made some changes to the MFT3.  I use the MFT as my primary workspace and need to have a clean space on the table and keep as much space left in my shop.
First, I basically never use the protractor and wanted to both maximize my cutting space and keep the table pushed close to the back wall.  I ordered another fence clamp and use two clamps to hold the fence on the table.  I added a Kreg scale on the front, so I can use a flip stop for measurement. i set up using a carpenter’s square at exactly 12.5” on the flip stop of the fence and squaring up against some veritas dogs.  It squares the fence and gets it set for dimensioned for cutting.
Second, the current hinge mechanism was hard to open and lock from the front of the table. I got inspiration from Sean KS on this forum (thanks).  I replaced the Festool mechanism on the back of the table with a linear guide and a 1020 Extrusion from 8020. its not as pretty as his though. I attached it to the hinge plate for the guide rail.  I added a bolt to the 8020 so at its lowest the guide rail sets right at the fence height when lain flat.  With any wood piece against the fence the guide rail hinges moving the 8020 piece up, perfectly lying flat across the top of the piece to be cut. Most of what I use is ¾” but I have used it up to 2” and tested up to 3”.   It does not need to be locked at height and has no movement side to side riding along the bearing.
I can set up the table from completely clean times in 2.5 minutes.  Since it is new I have checked square and correct dimensions each time.  They both have been perfect each time. I can keep my table pushed back saving several inches and don’t have to lock the guide in place to cut. I can have a clean or set up table with very little effort.  It has been a game changer for me.
« Last Edit: February 13, 2018, 04:41 PM by Halmccoyii »
Offline sprior
Re: MFT 3 ideas for small shop
« Reply #1 on: February 13, 2018, 09:08 PM »
People might have seen this from another thread, but if you have access to a 3D printer I designed these clamp dogs which can be used to align the back fence of the MFT with the dog holes: https://www.thingiverse.com/thing:2754628
Offline Hal M
« Reply #2 on: February 13, 2018, 09:41 PM »
I actually saw them.  They are fantastic. I didn’t have access to a printer so I bought the extra clamp. It did give me a little more cut width. I ended up with 25”.  I wanted to get to 24” for a couple of projects.
The 3D printer is such an amazing tool. Impressive what you did with it. Maybe I will have a chance sometime to use one.
Thanks.
Offline tdwilli1
« Reply #3 on: February 14, 2018, 09:13 AM »
Did you have to trim the Kreg Tape? I have tried 2 or 3 different tapes and it seems like Festool designed the fence to be just shy of 1/2 inch so the tapes either have to be trimmed or you leave a little on one edge or the other.
Offline Sean KS
« Reply #4 on: February 14, 2018, 10:43 AM »
Looking great Hal! Came together really clean and user friendly!
Offline Hal M
« Reply #5 on: February 14, 2018, 06:23 PM »
It does overhang a very little. It doesn’t seem to be a problem yet. I could imagine that it would at sometime in the future. The tape is very rigid and the adhesive feels very strong. If it comes off I will try to trim somehow next time.
Offline Hal M
« Reply #6 on: February 14, 2018, 06:29 PM »
Thanks Sean. Pics aren’t great.  I plan to clean up the connectors on the linear guide (don’t like the nut/bolts) and something better than the bolt to keep it sliding down.
I had planned to trim the hinge plate and put in a lever brake but quite frankly I am not sure I will ever need a brake as it works so well without it.
But it works great and saves space and is so much easier to set up cuts.
Offline mwildt
« Reply #7 on: February 14, 2018, 07:30 PM »
Yeah, looks great.
How easy does it slide up down with the bearings ? I'm guessing that they're some super sliding plastic or nylon ?
Reaching across the cable to adjust always been a pain.
Offline Hal M
« Reply #8 on: February 14, 2018, 11:00 PM »
Yeah, looks great.
It works way better than I ever expected. You can add shims in the bearing to make it very tight if needed. I have it just tight enough that it slides easily but has basically no movement side to side. I lift the guide guide up and then place a board down against and the fence and when I pull the guide rail back down the extrusion moves up the bearing to settle at the perfect height. I see no reason to lock it down in back at all.
I will try to post a short video tomorrow. I’m new to this but I think I could post a YouTube link.
Offline Hal M
« Reply #9 on: February 15, 2018, 10:26 PM »
I hope this video shows how the guide rail self adjusts to the different heights of boards with the new mechanism. At the end I also tried to show that it was very stable side to side. This is without using the front mechanism of the Mft. Obviously when I am using the table to actually cut I support the front.
I used 3-3/4 inch boards to represent different heights of boards and how it adjusts itself. I see no reason at this point to lock the back linear guide.
It seems a little difficult to get the extrusion into the linear bearing but I had the phone in one hand and tried to watch through the phone screen.
« Last Edit: February 20, 2018, 06:40 AM by Halmccoyii »
Offline suds
« Reply #10 on: February 16, 2018, 11:19 AM »
Great thinking!!  That has always been a gripe of mine that I had to reach across the table and fiddle with the clamp to raise the rail. I just took mine off and use dawgs.
MFT's, Kapex, TS 55, Vac, 150 Rotrex, 300 Trion, Domino
Offline mwildt
« Reply #11 on: February 16, 2018, 08:11 PM »
Great stuff. Thanks for posting the video.
Offline neilc
« Reply #12 on: February 16, 2018, 09:46 PM »
Great ideas!  Do you have part numbers or a link to the 80/20 linear unit you used?
Offline arso_bg
« Reply #13 on: February 17, 2018, 12:56 AM »
Brilliant Ideas! Thank you for sharing!
Offline Hal M
« Reply #14 on: February 18, 2018, 04:53 PM »
The 8020 parts were:
Linear bearing 6424 (it came with several shims, maybe 20+. I used 4).
https://8020.net/6424.html
Extrusion 1020 - cut to 9”
https://8020.net/1020.html
I bought a couple of T-nuts. 25-3382
https://8020.net/25-3382.html
I used a couple of 1/4-20 carriage bolts that I filed down to use to attach the linear bearing to the table with a couple of hex nuts. I need to order a T-nut and and maybe a couple of socket cap bolts to replace them. Would make it easier to remove the linear bearing from the table. I couldn’t find anything better locally.
Hope that helps.
Offline RobBob
« Reply #15 on: February 18, 2018, 07:03 PM »
That's brilliant.
Offline Dick Mahany
« Reply #16 on: February 18, 2018, 07:44 PM »
Simply excellent execution on this modification.  Kudos to you for crediting the source for your inspiration and also for taking the phone video in the horizontal mode.  Well done  (and soon to be duplicated on my MFT  [big grin])
« Last Edit: February 19, 2018, 03:59 PM by Dick Mahany »
Offline talk-tools
« Reply #17 on: February 19, 2018, 03:54 PM »
Thank you for this, and the part numbers. I'm going to do it if I can just get over my analysis paralysis of trying to use linear bearing solutions - which admittedly are overkill. This is for a custom 4x8 cutting table I'm working on that has been inspired by various projects I've seen on FOG.
Offline Gregor
« Reply #18 on: February 20, 2018, 03:53 AM »
Overkill, when leading to getting the job done, is a good thing.
Offline Mismarked
« Reply #19 on: February 20, 2018, 12:09 PM »
What a great idea.  Thanks for posting.
Offline Rob Z
« Reply #20 on: February 20, 2018, 12:30 PM »
Thanks for posting the video--very nice.
Offline Gregor
« Reply #21 on: February 20, 2018, 01:11 PM »
One thing I noticed in the video is that the rail moves the workpieces slightly.
I think this could be avoided by removing a part of the black anti-slip strips, just 1-2cm at the back where the edge of a high workpiece contacts the rail while it's still tilted.
Offline Hal M
« Reply #22 on: February 20, 2018, 06:43 PM »
I did see that on the video. The boards were very slick and slid on each other and I wasn’t holding them   When I have used it, it has not been a problem as I am normally holding the boards against the fence. Most of the stuff I have cut has been 3/4” so it doesn’t move at all.  On boards > 2” I just noticed the rail just dropped slower but I was holding the boards.
That being said, I think if I was cutting a lot of taller boards I would cut a tiny but of the foam out. I may do it anyway.
Thanks for the thought.
Offline eddomak
« Reply #23 on: February 20, 2018, 07:33 PM »
Thanks for sharing - that's great! And thanks for sharing the part numbers.
I am assuming you still need to adjust the front to height (which is far more convenient to do)?
I find that I really need to use the front to keep the rail at 90 degrees to the holes, as when I drop the rail down "naturally" it is far from 90 degrees. This is also evidenced by the fact that when I drop the rail onto the locating pin on the front support there is tension (which admittedly takes the slop out).
Offline Hal M
« Reply #24 on: February 20, 2018, 08:24 PM »
I always adjust the front height and use the support when cutting.
I was able to adjust it on the guide hinge plate so it falls basically at 90 degrees now. Before this, I had more slop in the guide rail until locked.
The only thing I try to do when cutting narrow boards is add a piece of similar thickness near the front of the table so when the guide falls it has more support.  Since I moved the guide back, which helps with the hinge effect also, I have more cutting space but also greater span.  I think the support helps.  I can basically use this as a miter / chop saw as I cut some fairly small pieces. The other day I cut some 1.5”x3” pieces with a 30% cut on one side. The piece up front under the guide made it very solid.
« Last Edit: February 20, 2018, 10:33 PM by Halmccoyii »
Offline Route24Design
    • My Personal Blog
« Reply #25 on: March 24, 2018, 06:45 AM »
Thanks for sharing your idea, making a video, and listing the parts.  Helped me put it to use on my new Kreg workbench/MFT.
Festool TS 55 REQ-F-PLUS
Festool OF 1400 EQ-F-PLUS
Festool CT MIDI HEPA
Festool CT Sys HEPA
Festool Domino DF 500 Q-PLUS
Festool PRO 5 LTD (ETS 125 REQ)
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Festool FS 1400/2 (x2)
Festool FS 1400/2-LR 32 Guide Rail
Festool LR32 Router Hole Drilling Set
Offline cubevandude
« Reply #26 on: March 24, 2018, 08:59 AM »
I really like this idea.  I do not have the Festool hinge for the track as I have a Makita.  Does anyone have an idea how to make a hinge to work with this if they do not have the Festool setup as shown?
Offline Hal M
« Reply #27 on: March 24, 2018, 09:54 AM »
I spent a little time on 8020 working up a hinge with a plate. After using the Festool plate and hinge I never ordered anything. You might consider ordering the parts from Festool parts catalogue.  I can’t seem to copy the link from my iPad but google Ekat Festool.  Lookunder Workplace organization then MFT3.
 I know Sean KS on this thread used 8020 and machined some parts for the front piece. I do not have equipment for that. He also obviously has more skills than I do.
Hope that helps.
Offline Hal M
« Reply #28 on: March 24, 2018, 09:56 AM »
That looks fantastic. Wish I had the space.  Well done.
Offline jobsworth
  • Festool Baby.....
« Reply #29 on: March 24, 2018, 10:45 AM »
I also have a small shop. Not as small as the OPs but small.
What i did to give me more room was to build sysports that fit under the MFTs. I found I could fit 4 per a MFT. Doing this cleared the 3,  8 ft long shelves I used out of spur shelving to stack my systainers on. Nothing fancy, I build for function in these cases. Though I did use edge banding on the boxes to dress them up a bit. Castors can be added if you want to move the boxes/cabinets around even outside if its warm and you have space. I build the boxes 29" high and used 3 1/2 inch castors from Harbor Freight (red wheels) . Gives me enough height to just fit under the MFT and even add a small drawer on the one holding 2 sortainers.
Doing this, I basically freed up the entire back wall of my small garage shop. Where I can more cabinets for storage or a work bench or move my miter saw w/stand to free up more work space on the side of my shop. Oh because of the extra space I reaquired I did use some small bit of wall space, with some of the spur shelve (2 risers) to set my CMS  modules mostly all home made they are now right near my CMS giving me better access to them. I dont have photos of it yet as I just did it yesterday.
The photos arent to good as its a small shop and a tight fit for my fat butt to move around in.
But it will give ya the idea
One is of the 3 shelves which in the photo are almost empty and now are empty
the rest are of the under MFT storage before i started drssing them up. I did add 12" blum euro drawer slides to make it easier to pull the systainers out and on pull out to set my TS 55 on in between cuts. You can see that barely in one of the photos.
This is nothing special but it works for me
« Last Edit: March 24, 2018, 10:48 AM by jobsworth »
Offline TheSergeant
« Reply #30 on: March 24, 2018, 02:11 PM »
THese are some great mods. The fact that they're necessary really frustrates me.  I've owned 3 MFTS, which all gone now, as I made an MFTC that is much, much better.  These mods also really highlight the major issues with the MFT3 and the need for a major redesign/upgrade.  $720 for something that you have to modify the heck out of is crazy.   I'm tempted to go off on a rant here but won't.
Excellent work OP for adapting the system to suite your needs.
« Last Edit: March 24, 2018, 02:13 PM by TheSergeant »
Offline Mgildersleeve
« Reply #31 on: March 24, 2018, 06:19 PM »
A great upgrade.  Nice work.
« Reply #32 on: March 25, 2018, 08:18 AM »
@TheSergeant   What mods do you think are necessary?
The MFT is a portable work table that facilitates using the tracksaw at a job site. No modifications are required for that.
Did you expect to use the MFT for a different purpose?
Offline cubevandude
« Reply #33 on: March 25, 2018, 01:11 PM »
Do you think something like this would work?  15 Series Universal Standard Structural Pivot
https://8020.net/shop/4356.html
I see your pieces are 10 series though.
Offline Hal M
« Reply #34 on: March 25, 2018, 01:16 PM »
I am happy to reach out to my 8020 salesman and ask him for an idea for the hinge if you would like this week.  I used the 10 series because I was trying to minimize space.
Offline cubevandude
« Reply #35 on: March 25, 2018, 01:30 PM »
I would appreciate that.  I do see these are available in 10 series also.  A plate on the top with a way to attach the track and it might work.
10 Series Universal Structural Pivot Nub, Part Number: 4186
10 Series “L” Structural Pivot Arm, Part Number: 4149
Here it is assembled:
10 Series Universal Standard Structural Pivot, Part Number: 4156
https://8020.net/4156.html
« Last Edit: March 25, 2018, 01:56 PM by cubevandude »
Offline Sean KS
« Reply #36 on: March 25, 2018, 10:41 PM »
I think this pivot would be an option as well.
https://8020.net/shop/14011.html
It would allow you to attach and hinge the Festool rail without any further modifications.
The one thing I don’t know is the height from the top of the linear bearing to the top of the MFT. The pivot I’m recommending  could be too tall. Not sure, and I don’t have an actual MFT to check? It’s just shy of 2in tall when the Festool rail is lowered for a cut.
« Last Edit: March 25, 2018, 10:46 PM by Sean KS »
Offline Hal M
« Reply #37 on: March 26, 2018, 06:58 AM »
I actually considered that hinge.  My concern was getting more than one connection to the rail so it had a better chance of keeping the rail square. I also thought the wider profile would help it stay square in the vertical plane in the bearing. After using it for a while it may make no difference. I will ask my sales rep today if he is working.
Offline Jig
« Reply #38 on: November 27, 2018, 05:28 PM »
Hal M:  Thanks for thinking this up as I am ready for this modification to my MFT table.  I had forgotten just where this tread was and looked for ever!  You can only imagine my frustration of searching the FOG high and low..........!!
Thanks for sharing all your efforts! 8)
Jig
Offline John1102
« Reply #39 on: November 27, 2018, 06:12 PM »
Great idea!  8020 parts are great!
Offline tmm286
« Reply #40 on: November 29, 2018, 12:03 AM »
If you have the CNC file you should Contact the guys at Vonmod - http://vonmod.com/ .  They have a huge CNC for a modest fee I'm sure they would crank one our for you in a material of your choosing.
I work for a GC in Denver and contract them frequently for custom work.  I recently picked up an MFT and it's already my plan to ask them to make me a new top when mine wears out as I don't feel it's worth my time to do it myself.
Offline cubevandude
« Reply #41 on: November 29, 2018, 08:31 AM »
I was wondering if anyone has made this out of the 8020 aluminum instead of using the festool hinge?  I ended up going with the UJK Technology Dog Rail Clips and Veritas SS Parf dogs for my Makita saw and Slab top.
I don't have any easy access to 8020.
« Last Edit: November 29, 2018, 08:35 AM by cubevandude »
Offline Grev
« Reply #42 on: November 29, 2018, 08:33 AM »
This has been covered in other posts .. but just in case you don't have the .dxf files, you can get them via TSO Products for free.  TSO offers files for several different sizes of tops, while Seneca woodworking only has the MFT3 replacement top file.  Good luck.
Seneca woodworking MFT file
TSO Products MFT files
Offline tmm286
« Reply #43 on: December 16, 2018, 06:40 PM »
Thank you!  ;D I assumed they were floating around.  Appreciate the link though!  My current MFT top is taking a beating at the moment.  Still got the whole other side though.
Offline simonh
  • Hobbyist / Maker of the VCS-R
« Reply #44 on: December 17, 2018, 03:28 AM »
That's pretty slick use of the 80/20 stuff.
-Simon
Offline thedevme
« Reply #45 on: January 18, 2019, 12:38 PM »
Hope that helps.
@Hal M  First of all, thank you for sharing how you built it.  I was curious if you ever updated this with the T-nut and socket cap bolts?  If so would you mind sharing how you did it and possible show a pic.
Offline Hal M
« Reply #46 on: January 18, 2019, 09:45 PM »
Actually I never ended up changing it. I have not taken the bearing off very often. I had actually forgotten that I was going to change them.
Offline dlu
« Reply #47 on: January 19, 2019, 12:09 AM »
Part numbers for the Festool MFT rail hinge and front support and the MFT frame profiles, in case anybody is looking:
  • 497022 Support - front rail support
  • 497023 Support unit - rear rail support and hinge
  • 472862 Profile - MFT short (side) extrusion
  • 472862 Profile - MFT long (front and back) extrusion
« Last Edit: January 19, 2019, 01:52 AM by dlu@canishe.com »
Offline thedevme
« Reply #48 on: January 19, 2019, 12:44 AM »
Part numbers for the MFT rail supports and profiles, in case anybody is looking:
You mean in addition to the ones from 8020?
Offline dlu
« Reply #49 on: January 19, 2019, 01:53 AM »
Yes - those are the Festool numbers for the hinge and front support for cross cutting on an MFT.
Offline thedevme
« Reply #50 on: January 25, 2019, 05:59 PM »
@Hal M Thank you I got my parts and implemented with no issues even used socket cap bolts instead to make it easier to remove from the MFT table.
Offline Jack01
« Reply #51 on: February 01, 2019, 09:40 PM »
Hal
Great project, Impressive.
I'm not familiar with 80/20 are they comparable to MFT side tracks( T channels) ?
Can I buy the 2 Guide Rail support from festool and use it on 80/20 tracks.?
Offline Jack01
« Reply #52 on: March 27, 2019, 10:57 AM »
Did you get in touch with Vonmod ?
I am also interested in getting MFT top .
Offline Hal M
« Reply #53 on: March 28, 2019, 03:31 AM »
Hal
By comparable, they are very sturdy and straight. They channels do not line up exactly but I have seen online where people make there own mft tables using 8020 extrusions. You can about build anything with them.
I am sure you can buy the guide support pieces from Festool.
Good luck.
« Last Edit: April 19, 2019, 10:13 AM by Hal M »
Offline koenbro
« Reply #54 on: March 29, 2019, 12:00 AM »
Brilliant ideas, thank you. I have just ordered the 8020 parts to make my own.
MFT/3 • TS 55 REQ • Carvex PS420 EBQ + Accessories • OF1400 + LR32 + MFS400 • Domino DF500 • AvidProCNC 24x48" • ETS EC150/5 EQplus • DTS 400 REQplus • CXS • CT 26E • Fuji Q4 + 3M PPS
Offline ChiknNutz
« Reply #55 on: August 13, 2019, 08:45 AM »
The 8020 stuff is great for the structure, another option for linear guides and related stuff is IGUS.  Similar to the 8020 guides, the IGUS drylin linear rails have no moving parts and are good for dirty environments. https://www.igus.com/drylin/linear-guide.  Just providing the info in case folks don't know about them.
-Chris
Rotex 150/5 FEQ, CT 36 E, ETS EC125/3, TS75, Domino XL
Offline promark747
« Reply #56 on: May 23, 2020, 09:37 PM »
Another shoutout to Hal M for the great idea.  I just did the same thing to my custom 80/20 MFT and it's awesome.
Offline Hal M
« Reply #57 on: May 24, 2020, 06:03 PM »
Thanks.
I did notice today that finally it seems to not slide up and down quite as easily as it used to. I think a tiny bit of dust got in it.  Pulled it out and blew it off and it’s back to just like new.
Hope it works out well for you.
