Author Topic: Kapex and a light ?  (Read 6033 times)
Offline JerrySats
Kapex and a light ?
« on: January 29, 2017, 07:43 PM »
Being old stinks  I can't see like I used too , anyone add a light to their Kapex  ?   Not so much for the shop , but having some close up lighting on a job site would be great .  I have some idea's on an LED snake light I use around the shop for machines  but would like to hear some other ideas .
 Jerry
Offline six-point socket II
  • formerly @the_black_tie_diyer
Re: Kapex and a light ?
« Reply #1 on: January 29, 2017, 08:10 PM »
Hi Jerry,
have you thought about the Syslite or Syslite Duo?
Kind regards,
Oliver
Kind regards,
Oliver
Offline JerrySats
« Reply #2 on: January 29, 2017, 08:35 PM »
Hi Oliver
 No i haven't given that any thought , looks like a great set up but I would like something more compact like task lighting .  The dewalt saws are coming with lights and from what I've seen it helps a ton with seeing the cut line .
« Reply #3 on: January 29, 2017, 09:14 PM »
Hi Jerry,
Oh, I understand. I'm sorry, I have no idea then.
Kind regards,
Oliver
Kind regards,
Oliver
Offline Throwback7r
« Reply #4 on: January 29, 2017, 10:27 PM »
Here is what I found for cheep and dirty lighting EBBARED Light just clip them to where you need them and you are golden.
Offline #Tee
« Reply #5 on: January 30, 2017, 12:58 AM »
I just drop the blade on the mark for the most precise alignment, LED lights and lasers i got over it.
When youre feeling depressed just treat yourself to a systainer even if its a mini systainer its ok.
IG: tee212
Offline fignewton
  • "Fine Quality Sawdust"
« Reply #6 on: January 30, 2017, 08:44 AM »
I do this too to be sure the cut is exact, clamp the piece, and then move the flip stop up to set.  The prob, which I encountered yesterday and is the root of the OP's problem, is that it's pretty dark trying to see the tooth edge on the cut line. The head casts a shadow over the kerf line.  I had a DW that I sold when I bought the Kapex, and the LEDs were a nice feature to be able to place the blade.
TS55, MFT3+, OF1400, C12, CT-26, LR-32 system, Domino 500, RO125, MFK 700, Carvex w/ accsy, Sys-roll,  CXS, Kapex, UG with extensions, RO90
Offline Bert Vanderveen
« Reply #7 on: January 30, 2017, 04:20 PM »
I use LED snake lights that clip on from IKEA (called JANSJÖ), that are around 10 bucks. For that price you can clip on a few…
http://www.ikea.com/us/en/catalog/products/20315674/
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set (pending…) … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Offline RKA
« Reply #8 on: January 30, 2017, 05:29 PM »
I use the gooseneck LED light below.  It can run off a cord or on batteries (I do the later using rechargables).  My only gripe is it's only going to light on side of the blade and sometimes I need to line up a cut on the other side.  Adding another lamp is a nuisance.
https://www.amazon.com/Ivation-Multipurpose-Gooseneck-7-LED-Dimmable/dp/B00GM477G8/ref=sr_1_9?s=pc&ie=UTF8&qid=1485815060&sr=1-9
On that note, it's a little irritating that manufacturers haven't figured this out already.  LED's have been around long enough, they are bright, cheap, consume little power.  Anytime you're designing a tool that a user needs to sight down very precisely, don't make them squint!  Put a light in there!!  They have this covered with drills across the board, but everything else seems to require some higher level of thinking to implement!
-Raj
Offline JerrySats
« Reply #9 on: January 30, 2017, 10:10 PM »
I just made a mount for these LED lights in picked up at HD . I use them around the shop on different machines,they work great as task lighting.
Offline Laminator
« Reply #10 on: January 30, 2017, 10:48 PM »
I don't have a pic but I mount a syslight on a hacked tripod top when I need to really see.
Offline mjh2157
« Reply #11 on: March 15, 2019, 09:45 PM »
I was giving this some thought tonight.  I was wondering if you ordered the handle off ekat for the ks60 or ks88, could it be used to replace the handle on the ks120 so you could have the shadow light feature?  Has anyone tried that?
-Matt
« Reply #13 on: March 16, 2019, 09:06 AM »
Or could this be fitted onto the ks120, has anyone tried that?  https://www.festool.com.au/products/accessories-and-consumables/sawing-oscillating/saw/attachments-guides-stops/sliding-compound-mitre-saws-kapex/led-spot-light-for-ks60_500120
- Matt
I bought something like that but it cost about 3 times as much. Still, it was a pretty good value since it included a well integrated cordless miter saw. Milwaukee 2733-20
« Last Edit: March 16, 2019, 09:10 AM by Michael Kellough »
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
« Reply #14 on: March 16, 2019, 10:16 AM »
I use this with my SCMS - And another one with my Dovetail Jig. [thumbs up]
Magnetic Multi-Task LED Light with 20 Daylight LEDs - 12" Mount-Anywhere Flexible Gooseneck Work Lamp with Magnet Base for Crafts, Sewing, Workbench - - Amazon.com
https://www.amazon.com/Magnetic-12-Inches-Gooseneck-Multifunctional-Worklight/dp/B01ACIFPYA
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: PDC 18/4 Li QuaDrive Cordless Drill Set, C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIG: D4R 24 Pro Dovetail Jig, | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
Offline ChuckM
« Reply #15 on: March 16, 2019, 04:19 PM »
Like Joe, I use a sewing machine light from eBay when extra light is needed -- see attached image. When LV comes out with a corded version, I will get this:
http://www.leevalley.com/en/wood/page.aspx?p=71189&cat=1,43349
Offline Wareagle Todd
« Reply #16 on: March 18, 2019, 01:57 PM »
I bought one of these and integrated it into the blade guard of the 12" Bosch Glide.  it mounted in a way so that when you bring the blade down to cut the wood, thew blade provides a shadow identifying the cut line.
