Author Topic: Festool Clamps compatible with T Track brands  (Read 175038 times)
Offline guitarchitect
Re: Festool Clamps compatible with T Track brands
« Reply #60 on: August 02, 2018, 10:26 AM »
Does anyone know if there's a router bit that will cut a compatible T-Slot in one pass? I did a tonne of searching yesterday and couldn't find the goldilocks bit based on my measurements. 5/16" throat, 1/4 deep by 1/2" wide T-slot. I'm going to try a Lee Valley keyhole bit - unless there's one hiding out there somewhere!
Offline RKA
« Reply #61 on: August 02, 2018, 10:42 AM »
No idea, but I can check my festool clamps tonight to see if they fit in a 1/2" dovetail groove.  I normally use the microjig dovetail clamps in that, but it's possible the Festool clamps would fit?  I suspect the Festool clamps would bind as the walls of the dovetail angle in before clearing the profile of the clamp.
-Raj
Offline rst
« Reply #62 on: August 02, 2018, 11:50 AM »
Usually tee slots are cut in two passes, a straight walled dado to the make clearance neck and a second  for the slotting bit.  Depending on what your cutting, you're going to get a lot of burning.
« Reply #63 on: August 02, 2018, 12:11 PM »
Brilliant! I hadn't thought of that. I'm cutting my grooves in plywood so I was focused on trying to keep the edges of the grooves as thick as possible... but I bet with a tiny easing of the dovetail shoulder it'd be just as good. I'm sure I have a 1/2" dovetail bit, I'll check that on my next shift in the shop!
EDIT: Sadly, it didn't work. The dovetail wasn't wide enough. I did a second pass to take another 2mm off the width and it was pretty sloppy.
« Last Edit: August 02, 2018, 04:22 PM by guitarchitect »
« Reply #64 on: August 02, 2018, 04:37 PM »
It wasn't bad actually. When I tried a dado stack/bit approach I wasn't able to properly center the bit in the slot and it ended up very sloppy... it doesn't help that I needed to do two passes in the router bit to get the proper width. I suspect that if I used a dado router bit at the right width and then just swapped the bits out it would be better, but I wasn't able to try that out. The system I ended up using made a very precise but loose enough slot that the clamps stay standing up but move freely in the 4' groove.
See the attached pics, don't mind the wavy plies of the HD plywood :D
Offline GoingMyWay
« Reply #65 on: August 02, 2018, 04:51 PM »
That looks pretty good.  Is it strong enough to hold the clamp in while clamping something?
Inquiring Minds Want to Know
Offline ben_r_
« Reply #66 on: August 02, 2018, 05:16 PM »
Looks pretty good! But MAN is that plywood some high quality stuff!
Offline RKA
« Reply #67 on: August 02, 2018, 07:28 PM »
That is not going to hold.  That ply will separate right below that third layer.  (Or maybe you were just testing on the ply, in which case, never mind)
I did test the Festool clamp on a 1/2” dovetail slot and it did bind.  If you took two passes to widen the dovetail, the clamp would likely pull out of the slot with very little pressure.  It’s not worth bothering.  But I would recommend the microjig clamps intended for this purpose.    [wink]. They have a trapezoidal profile that matches the dovetail slot.
-Raj
« Reply #68 on: August 02, 2018, 09:13 PM »
Absolutely. I clamped a piece of 5/4 hard maple, lined it up against the fence, and ripped a perfect 1.5mm strip off the right side of it (the jig is meant to act like a sliding table on the left side of the blade).
@RKA to your point, consider that the clamp is using the whole length of itself, not just a point load. Even on this cheap junk it holds very, very strong. I clamped the maple down as hard as I could and didn't hear any telltale cracking - since stock is being clamped flat to the surface it prevents the clamp from having too much pull upwards. I think the bigger issue is how long the edge will last if it's being constantly abused by sliding clamps.
Since it has worked so well I will probably use it on my upcoming workbench and assembly tables (from Timothy wilmots system workshop) for which I will use hard maple... It should last a long time!
EDIT: Just took a look at the Microjig site - that's really funny as they're basically demoing all the stuff I'm trying to do! Unfortunately their clamps aren't the quick clamp type though, just the screw-downs... having had the quick clamps for a while now I just have no interest in anything else! Hopefully the keyhole bit I try out will make for a simple two-pass process
« Last Edit: August 02, 2018, 10:02 PM by guitarchitect »
Offline RKA
« Reply #69 on: August 02, 2018, 10:15 PM »
Well, heed rst’s advice about hogging out the channel with a straight bit first before switching to the keyhole.  These dovetails and keyhole bits have a weak spot at the neck and plowing them right into wood can cause them to break.  If you’re going to do it just make sure you’re clear of flying metal bits as it enters or exits.  Mid cut it should be captured under your work piece.
-Raj
Offline taylord22
« Reply #70 on: September 06, 2018, 11:05 AM »
Does anyone know if the 15 or 40 series extrusion fit both Kreg and Rockler track clamps/holding solutions?
I'm considering running some 80/20  around the perimeter of my custom MFT top (in hopes that TSO's potential track holder becomes an option  ;)), and then also running two sections of t-track across the horizontal 12-18" in from both edges (in between pattern, 1/8 below surface). The reason I'm interested is that I find a few of Rockler's t-track clamps appealing.
I planned to use Incra track for those horizontal runs. But wanted to double check that the 8020 (1530S or 4080, unless there's a better option) that I will be running can handle all 3 without a grosse amount of slop.
Offline rst
« Reply #71 on: September 06, 2018, 01:52 PM »
15 series works fine, bolt heads slide easier if you ease the horizontal edges.  I used 15 series 3034 as the tracks in my drill press table.
« Reply #72 on: September 06, 2018, 02:42 PM »
I'm considering running some 80/20  around the perimeter of my custom MFT top, in hopes that TSO's potential track holder becomes an option.
If you're talking about the Rockler clamps with the 5/16" T-bolts, they fit both the 15 & 40 series extrusions.
Here's a shot of some I ran around a work bench.
Offline Bernmc
« Reply #73 on: December 17, 2018, 11:06 PM »
I have one of these waiting to try at home: https://www.axminster.co.uk/axcaliber-tee-slot-cutter-for-track-clamps-101972?sel=101972
Will let you know what happens...
Offline Bernmc
« Reply #74 on: December 20, 2018, 03:08 AM »
Here are a few pics of a slot I milled into a piece of scrap today with the cutter I mentioned above.
Perfect fit. Has a depth of up to 22.5mm, so that should give enough wood for the clamp to bite on. This slot is 15mm deep.
Clamp is an Axminster equivalent to the Festool quick clamps
289308-0
289310-1
289312-2
289314-3
289316-4
289318-5
Offline kitui
« Reply #75 on: June 04, 2019, 05:47 PM »
FYI, I have the Veritas Quad by LeeValley and it fits the Festool Screw clamp only on the narrower t-track.
Offline tomp
« Reply #76 on: June 04, 2019, 07:39 PM »
Has anybody looked to see whether the long arm of the Festool and Microjig clamps to see how closely they match? Visually, they look very similar, wondering if the hole in the sliding jaw can be modified to allow using the Festool Quick jaw on the Microjig dovetail shaft. Not a cheap solution, but may be worth it if it works and that's what you must have.
Offline Grev
« Reply #77 on: June 05, 2019, 09:44 AM »
They do work ... here are a couple photos of the Festool ratchet assembly on the micro-jig arm.  I've used the Infinity t-slot bit to cut slots that will fit Festool and other clamps, but the 14 degree dovetail bit for the micro-jig is much easier and better for slots in wood, with a stronger hold.  For the dovetail slots, I usually cut a slot first with a straight bit, then clean out with a final pass with the dovetail bit.   FYI ... if you need t-track to fit all the clamps, go with the Orange Aluminum. All the clamps work and I believe it is the most inexpensive around.
Offline tomp
« Reply #78 on: June 05, 2019, 10:00 AM »
That's great, thanks for checking. I was going to check compared to the regular Festool screw clamp, saved from having to do that. Downside is that now I have to buy one (or more, more is better, right?) of those expensive clamps.
I've become a big fan of the dovetail clamps, and have been incorporating them into my work-holding fixtures - just finished cutting a new miter fence extension with dovetail slots, but will be using the new Dovetail Hardware that Microjig just released.
Microjig Dovetail hardware
I just bought the dovetail router bit that Microjig sells; it cuts a radius on the outside corners and should make the slots less likely to get damaged.
« Reply #79 on: November 18, 2019, 11:59 AM »
aw man, when did they come out with this? would have loved to have it when I was doing my stuff! problem of course is that axminster shipping to canada is mega $$$, it's basically an $80 router bit for me!
strongly considering the matchfit kit at this point - when I want to bang out a jig it takes ages to properly set everything up just for some small passes - and forget about ever doing it hand-held!
« Reply #80 on: November 18, 2019, 12:13 PM »
how do you find the "slop" between the little dovetail pieces and the slot - and does the material you're cutting the slot in make a difference? I'm building a TS sled right now and i'm strongly considering using the matchfit system!
Offline williamduncan
Has anyone checked Powertec tracks?
« Reply #81 on: April 04, 2020, 03:21 PM »
This thread is ancient and hugely useful.  Thank you everyone.
I've got plenty of options for my workbench ideas from what is already here but I see that Powertec tracks are widely available and seem to be widely used.  Do those work as well?
Offline tazprime38
« Reply #82 on: April 19, 2020, 07:44 AM »
What is the ideal dimensions of the t slot in a t track that would allow both types of festool clamps to work with?
« Reply #83 on: April 19, 2020, 11:09 AM »
I got this UJK bit https://www.axminster.co.uk/axcaliber-tee-slot-cutter-for-track-clamps-101972, recommended above, and it's measurements are perfect.  Hard to improve upon.
Offline SteveL
« Reply #84 on: February 24, 2021, 12:05 AM »
Anyone know of a similar router bit to the Axminister option that’s available in the US?
« Reply #85 on: February 24, 2021, 11:30 AM »
Just Google T-slot router bit. Amana, Whiteside, Infinity, Rockler, MLCS, CMT...there's a ton of them out there.
Offline Paul_HKI
« Reply #86 on: February 28, 2021, 05:21 PM »
For anyone shopping for T-Track in Europe, Fine-Tools (Dieter Schmid, in Germany) have an affordable Juuma branded version.  This accepts both the screw and cam type Festool/Bessey clamps.
https://www.fine-tools.com/juuma-t-nutschiene.html
TSC 55, TS 55, DF 500, DF 700 (XL), OF2020EB+, OF900E, CXS, TXS, T18+3, PDC 18/4, RO 150, RAS 115.04e, RTS 400, ETS 125, ETS 150/5 EQ, CTL MIDI, FESTO SR151 E-AS, CTL-Sys, MFT/3, Sys-Roll etc.
