Author Topic: Quick fix for vac hose snag.  (Read 8042 times)
Offline David Stanton
  • Festool Dealer Affiliate
  • Carpenter & Joiner, Photographer, Youtuber.
    • David Stanton
« on: November 21, 2016, 02:16 PM »
I hate it when the hose catches on the edge of a bench. This helps and prolongs the hose life!
Click here for Dave Stanton on Youtube
KAPEX 120, ROTEX 150, TSC55, 800-1400-2700 TRACKS,  PDC 18-4 TEC, DOMINO XL, Domino 500, CXS, TXS, EHL 65, SYSLITE, HKC 55 EB, PSC 420 EB, CTL SYS, SYSROCK, 2 x CT 26, OF 1400, RTSC 400, OSC Vecturo 18V
Offline Bob D.
    • My Cordless Workshop
Re: Quick fix for vac hose snag.
« Reply #1 on: January 10, 2017, 07:18 AM »
I found an online source for cable sleeving in the US with a wide selection and great service.
I've used them for many items and they always ship fast and have an easy to navigate website.
I found their prices reasonable. For instance I looked at 9284K7 - Expandable Polyester Sleeving,
1-1/2" ID(2-1/8" expanded) available in seven colors is about $1/foot.
https://www.mcmaster.com/#cable-jacketing/=15ulf8q
I have no connection with McMaster-Carr other than being a happy customer for over 10 years.
If the link does not work then just go to their site and search on "cable jacketing" , they have
many, many choices in slip-on or wrap-around styles made from various materials including
stainless steel.
Offline ear3
« Reply #2 on: January 10, 2017, 09:38 AM »
I got mine from Toolnut, though its the expandable braided version rather than the heat shrink:
http://www.festoolproducts.com/techflex-1-1-4-gorilla-sleeve-for-27mm-hoses-1-length.html
I found it's good to get one extra foot above the recommended length (15' rather than 14') to accommodate the 27mm hose and cord.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
Offline Mismarked
« Reply #3 on: January 10, 2017, 10:53 AM »
I was going to try the heat shrink to secure the ends but couldn't find a large enough diameter locally.  I tried some of the Rockler extreme tape that I had left over.
http://www.rockler.com/x-treme-tape-for-dust-joints.
It's only been a couple of weeks but is holding up well and isn't sticky.
Offline rst
« Reply #4 on: January 10, 2017, 10:55 AM »
I buy mine from HAVE INC....Techflex PTN1.50 Flexo Pet 1-1/2" (1" - 2 1/8") 40 ft ....$43.56...Neon Green.    I fasten my ends with self sealing silicone tape...Versachem Wrapit Repair 1" x 10'   or   X-Treme Tape TPE-X36ZLB Silicone Rubber Self Fusing Tape, 1" x 36'
« Last Edit: January 10, 2017, 11:03 AM by rst »
Offline Bob D.
« Reply #5 on: January 15, 2017, 07:03 AM »
McMaster-Carr also has heat shrink. You can order with the sleeve.
https://www.mcmaster.com/#heat-shrink-tubing/=15x5xkk
Offline Andrew Wilkerson
« Reply #6 on: January 13, 2022, 04:12 PM »
Hey I also hate when my hose snags on the bench or track.  I hated it so much that I developed a No Hose Snag Dust Port Replacement for Festool Track Saws. The guys I worked with liked it so much that I started printing and selling them on Etsy.  It installs in under 2 minutes.  It also allows for the Festool 27mm Cleantec dust hose to twist-lock into place.
