Author Topic: I have an idea for 3d printers  (Read 2145 times)
Offline Crazyraceguy
« on: May 04, 2021, 08:32 PM »
Would it be possible to make some kind of adapter to convert the oval shaped dust port of the OF1010 to round, were the hose slides into it like it does in a tracksaw or MFK700?
It is much easier to use the OF1400 dust port than the OF1010.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Installers set
Centrotech organizer set
Offline Cypren
Re: I have an idea for 3d printers
« Reply #1 on: May 04, 2021, 08:44 PM »
Making a physical adapter for this isn’t difficult, but anchoring it into the router is likely to be. Most 3D printer plastics are fairly rigid, so they can’t stretch and grip with friction like the vacuum hose end does on the 1010. There are flexible polymers you can print, but they’re notoriously difficult to work with and error-prone. It might be possible to arrive at a solution which uses a multi-material print with a flexible nose cone that wraps around the router outlet and a rigid connector for the hose outlet itself: this is essentially what Festool’s own hoses do.
I’ve got a 1010 myself, so this might be something I look into down the line. If I can come up with a working design, I’ll post it here.
Offline Svar
« Reply #2 on: May 04, 2021, 08:58 PM »
Cypren, just slip a rubber sleeve (piece of bike tube, etc.) on the router receptacle to act as a cushion, and printed adapter over it. A set screw will work too.
« Last Edit: May 04, 2021, 09:00 PM by Svar »
Offline Cypren
« Reply #3 on: May 04, 2021, 09:19 PM »
But… but… I want to use my fancy electronic toys, not make a sensible solution with common household materials!
In all seriousness, really good idea.
Offline Bob D.
    • My Cordless Workshop
« Reply #4 on: May 04, 2021, 10:44 PM »
there is a soft, pliable filament available for 3D printers. I don't
know the name but I remember reading about it recently. If it
would work to make an adapter like you envision I also don't know.
Offline dupe
« Reply #5 on: May 05, 2021, 12:19 AM »
Ninjatek
MFT.1080    CT.Midi    DF.500    DTS.400    ETS.EC150/3    RO.150    RO.90    CXS 10.8    RAS.115
Offline Cypren
« Reply #6 on: May 05, 2021, 12:39 AM »
The general category name is “thermoplastic elastomers” (TPE), of which thermoplastic polyurethane (TPU) is probably the most commonly used. Ninjaflex is a particular brand of TPU.
TPEs tend to be quite difficult to work with because they need high temperatures to print and have a great deal of trouble adhering to the printer bed. In addition, you have to be very careful with how you design parts for the print process, because their elastic nature makes them sag, twist and jiggle as the printer moves around. Getting good TPE prints usually requires either a very high-end printer with an extremely rigid, vibration-damped structure and a heated chamber, or a ton of fiddling with a lower-end printer, advance preparation of the bed, a room with controlled temperatures and a very slow print speed that carefully controls motion and potential for flex.
Online JD2720
« Reply #7 on: May 05, 2021, 07:20 AM »
It has already been done.
oval dust port adapter
Offline morts10n
« Reply #8 on: May 05, 2021, 09:44 AM »
Any idea if 36mm hose fits over the top of this green adapter?
Offline tsmi243
« Reply #9 on: May 05, 2021, 09:47 AM »
I have one.  Love it.  It even has the bayonet pieces inside, so you can twist to lock the hose.
I really wasn't expecting the plastic to grip well on the aluminum, but it does somehow.  A+, excellent piece.
Offline tsmi243
« Reply #10 on: May 05, 2021, 09:50 AM »
No dice.  They're almost exactly the same size, so if you have anything that will fit the OD, you could probably use it as a coupler.
Offline rmhinden
« Reply #11 on: May 05, 2021, 12:27 PM »
The seller also has one listed specifically for the OF1010, see:
https://www.ebay.com/itm/265073864218?hash=item3db7a22e1a:g:N4oAAOSwsVtgPpwp
Looks interesting, I have had the hose come off my 1010, this might be an improvement.
Bob
