Author Topic: Homemade wall-mounted boom arm  (Read 74014 times)
Offline secutanudu
« on: February 22, 2015, 11:47 AM »
So I made this homemade boom-arm today out of some 1.25" EMT and a few other plumbing parts. I do 90%+ of my hand-held power tool use at my bench, and since the Festool CT-Mini vac can't hold a boom arm, I decided to make my own. Cost me $35.
It pivots just like the festool arm and I can swing it against the wall when I'm not using it. I still need to cap the end (definitely) and paint it (maybe).
Just thought I'd share.
For those interested, the parts were:
1 - 10' length of 1.25" EMT conduit (cut down to about 4 feet)
1 - 1.25" EMT elbow
1 - 1.25" EMT screw coupling
1 - 1" Galvinized flange
1 - 1" Galvinized street elbow
1 - 1" x 4" Galvinized pipe nipple
« Last Edit: February 23, 2015, 07:33 AM by secutanudu »
Offline Wuffles
Re: Homemade wall0-mounted boom arm
« Reply #1 on: February 22, 2015, 12:03 PM »
Fantastic work. I admit when I read plumbing parts I had visions of plastic pipe and it being a disaster.
Anyone know what that pipe is called in the UK?
Tool list updated to reflect knowledge :: hammer, screwdriver, one pozi bit, and another bigger hammer.
Offline secutanudu
« Reply #2 on: February 22, 2015, 12:03 PM »
Thanks! The actual pipe is EMT electrical conduit, not plumbing pipe.
Offline Wuffles
« Reply #3 on: February 22, 2015, 12:05 PM »
My bad, I focussed on the words "plumbing parts".
Offline socaljohn
« Reply #4 on: February 22, 2015, 04:49 PM »
I love that design! Very simple/very efficient.
Offline secutanudu
« Reply #5 on: February 22, 2015, 05:09 PM »
Thanks, John!
Offline NERemodeling
    • New England Remodeling, LLC
« Reply #6 on: February 23, 2015, 12:01 AM »
Nice solution!!
looks like you got yourself a nice warm shop with all that spray foam! isnt that stuff amazing
CT26  -  (2) Midi  - Planex - Kapex -  Domino 500  -  Carvex  -  TS55EQ -  Rails; 800, 1080, 1400(holy rail), 1900, 3000 -  OF1400 - OF1010  - LR 32 - RO 150 - RO90 - RAS115 - ETS125 - DTS400 - LS130 -  EHL65 - HL850 -  MFT1080 - (2) MFT800
Offline JBag09
Re: Homemade wall-mounted boom arm
« Reply #7 on: February 23, 2015, 08:59 AM »
Great job! Looks like that will work perfectly. I had considered doing the same thing awhile back.
Offline secutanudu
« Reply #8 on: February 23, 2015, 09:03 AM »
Love the spray foam!
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
« Reply #9 on: February 23, 2015, 02:34 PM »
simple but very effective design. And you saved a ton of money.
« Last Edit: October 05, 2015, 01:47 PM by GPowers »
Greg Powers
Offline fdeloncker
    • DeLoncker Designs, Inc
« Reply #10 on: February 26, 2015, 10:11 PM »
Looking good. I have wanted a boom arm for a while now, but havent convinced myself yet. It is a lot of money for a simple arm, but great accessory.
Offline BigCountry73
« Reply #11 on: February 28, 2015, 03:23 AM »
I was getting ready to purchase the Festool boom arm until I saw this post. Do you need to use an additional length of hose for it to function properly?
Thanks,
Keith
Offline secutanudu
« Reply #12 on: March 02, 2015, 04:29 PM »
Nope, but I also have a separator on top of the vacuum that makes the hose in with much higher up off the ground, eliminating any possibility that it isn't long enough.
Online Cheese
« Reply #13 on: March 02, 2015, 04:57 PM »
Very clever...and simple. That's the beauty of it.
Offline jacko9
« Reply #14 on: March 02, 2015, 04:57 PM »
Nice solution.
Offline Thunderchyld
« Reply #15 on: March 02, 2015, 05:25 PM »
I like it.  I'll probably wind up making one for myself.  I think I'm going to make one addition to the design and use A T instead of the 90 degree fitting so that I can run either an air hose or an extension cord through it.  Probably want to do some sort of liner as well, to prevent abrasion, possibly PEX tubing.  I'll have to play around with some sizing, see exactly what works best.
Offline Hawkeye1434
« Reply #16 on: March 31, 2015, 10:31 PM »
Awesome job this is going to work perfect in my shop
Offline mdelrossi
« Reply #17 on: April 01, 2015, 07:29 PM »
Nice and simple.
I would put a plastic or foam cap on the end of the pipe [wink]
Offline secutanudu
« Reply #18 on: April 01, 2015, 07:55 PM »
I keep meaning to put a cap on it, but it hasn't been a problem yet. I doubt it will be.
Offline franklin pug
« Reply #19 on: October 04, 2015, 08:15 PM »
Just wanted to say thanks for this awesome idea.  I did exactly as you suggested, and cost me about 60 bucks CDN - here is how mine looks:
Offline secutanudu
« Reply #20 on: November 01, 2017, 09:18 AM »
Ok, 2 years too late - glad to see someone used the design, looks great!
Offline travisj
« Reply #21 on: January 31, 2019, 03:11 PM »
I finally got around to doing this myself.  The simplicity is brilliant and it works like a charm.
Offline travisj
« Reply #22 on: January 31, 2019, 03:13 PM »
Offline secutanudu
« Reply #23 on: January 31, 2019, 03:14 PM »
Awesome!
Offline JimH2
« Reply #24 on: February 02, 2019, 12:25 PM »
Awesome!
Once you go boom you can't go back.
Offline johnesher
« Reply #25 on: February 16, 2022, 08:00 PM »
I took inspiration from this post and finished (at least for now) my version of this arm. I found that I needed an additional flange with a tee fitting installed where the author had his street elbow. Without it when I moved the arm to the left side it loosened the street elbow from the flange and it dropped to the ground.
IMG-3897" border="0 IMG-3898" border="0 IMG-3900" border="0
Offline srs77
« Reply #26 on: February 16, 2022, 09:47 PM »
This is brilliant! Great job!
PS 420 EBQ-Plus
ETS EC 125/3 EQ-Plus
CT MIDI I
Edge Sanding Guide AH-ES-ETS/ETSC
Offline Packard
« Reply #27 on: February 17, 2022, 08:37 AM »
I have this Manfrotto/Bogen boom arm from my old photo studio.  I had not thought to use it for this purpose.  It is probably too expensive to justify its purchase (now $190.00), but Amazon has several knockoffs for about $115.00.
Very sturdy and fully articulate up/down, side/side.
And here is one of the knock-offs.  The originals are made in Italy.  These are probably made in China.
Offline Eiffel
« Reply #28 on: February 25, 2022, 08:12 PM »
I've been using this Manfrotto Boom arm with great success. It is quite sturdy and one can add some lighting and plugs at the end of it, in addition to the usual vacuum hose. Highly recommended.
I can't vouch for the Chinese copies though.
Offline Bob D.
  • Inactive Member
    • My Cordless Workshop
