Author Topic: Homemade guide rail connectors (not your typical ones)  (Read 70253 times)
thudchkr and 1 Guest are viewing this topic.
Offline promark747
Re: Homemade guide rail connectors (not your typical ones)
« Reply #30 on: September 30, 2014, 10:13 AM »
JZ/Rusty,
Thanks...that was the last part I was wondering about -- which size set screws to use, and whether to use the conical type.
Offline JZ Bowmannz
« Reply #31 on: September 30, 2014, 10:34 PM »
The hex hole for the Allen Wrench in #10 set screws was too small,and I was afraid to strip it when I crank it, so I found these with slot at local hardware store, they have slots just like the Festool ones.
Offline Rusty Miller
« Reply #32 on: October 03, 2014, 02:32 PM »
Just finished one connector.  Still have to add the little screws to hold the bottom piece to the top piece and finish the second connector.  But I must say the connector locks up in the rail quite nicely.  Looks like it is going to work perfectly.
BTW, I used 10x32 1/4 setscrews and they work great.
I hope to cut some ply this weekend so I'll be putting two 55" rails together so we'll see how they really work.
« Last Edit: October 03, 2014, 02:36 PM by Rusty Miller »
Rusty Miller
I'd rather be woodworking!
Offline greymann
« Reply #33 on: October 04, 2014, 12:34 PM »
I really like this design over the standard connectors.  Hope Festool will finally take notice.
If you are looking for a place to store these while not connecting two rails together, here's a suggestion.
I use the 1900 rail a lot on my homemade tables and find that it has more flex than I would like, especially when resting the saw on a portion hanging over the end of the table.  I have taken to using the standard connectors in the underside slot as stiffeners and have been pleased with the results.  I believe your longer bars will be even more effective.  I usually put one near the close end of the rail and the other nearer the center.
I also never have to remember where I put them.
Dick Perry
"But for the sky, there are no fences facing."
Offline Slartibartfass
  • How'ur'duin'......
    • The Accidental NAINA Store Email List
« Reply #34 on: March 05, 2015, 09:00 PM »
Here are mine. Roughly 15" long.
Offline Pizza Steve
« Reply #35 on: March 26, 2015, 07:05 AM »
@Slartibartfass- that's a nice looking drill press/milling vice.  What model is it?
Offline Pizza Steve
« Reply #37 on: April 01, 2015, 08:56 AM »
Would these homemade connectors also work as MFT connectors?
Offline sgt_rjp
« Reply #38 on: April 01, 2015, 09:51 AM »
Speaking of MFT connectors, are there any threads concerning them(yours or others)?  I just ordered a second MFT/3 and was already thinking about doing something with 8020 when I saw yours.
Offline JZ Bowmannz
« Reply #39 on: April 01, 2015, 09:58 AM »
The MFT connectors are 14mm x 9mm.
You would need some different stocks for that purpose.
I would try layer of 12mm x 9mm stock plus a layer of 2mm x 9mm stock.
There are something called "Key Stock" available that are 14mm x 9mm. You have to do some machining of course.
http://www.mcmaster.com/#key-stock/=wk9rww
Offline Bohdan
« Reply #40 on: April 01, 2015, 10:03 AM »
Do you think these would work acceptably if made from T6061 aluminum instead of steel? I know the Festool ones are steel but I'd really like to stay away from using a dissimilar metal if aluminum would work? Also it would be easier to work with than steel.
I know it wouldn't be AS strong, but the question is "would it be strong ENOUGH"?
When I made my rail connectors I used 12 x 3 mm stainless steel so I don't have to worry about rusting.
I also made them 500mm long and they line up the rails perfectly.
Offline sgt_rjp
« Reply #41 on: April 01, 2015, 04:07 PM »
When I mentioned MFT connectors, I was actually referring to Slartibartfass's.  I was wondering if you could use longer lengths of 8020 and have gaps between the tables.  Maybe even another work surface between them?
« Reply #42 on: April 01, 2015, 04:16 PM »
To use these style of connectors (not my idea btw) you would just need to up-size them.
As to using 80-20 you can hang them on the MFT/3 profile between tables to act as a support.... works with the 8020 T Slot Aluminum Extrusion 15 S 1515 ULS profiles.
i've done that to hang some Festool clamps or small extension tables to the MFT/3 (also not my idea....power of the FOG at work....).
Offline SPM in King
« Reply #43 on: August 17, 2015, 02:22 PM »
Thanks to all who contributed to this thread.  Great idea - the 2 pieces - 2 and 4mm.  I made 2 sets (3 rails) last week and while they are not as perfect looking as some, they work well.  I made them 18" long and used 1/4" 24TPI set screws.  Used McMaster steel because I could not find a metric supplier here in Canada - land of metric!!
Here's hoping that the good folks at FT get the message - the standard ones don't do the job!  I was getting at least 1/8" play in the track.  That makes for some very poor cuts, especially when using the TS for hardwood glue ups.
Steve
TS 75 EQ, RO 150 FEQ
Offline jcoby
« Reply #44 on: August 18, 2015, 03:55 PM »
I made two sets of these with a few changes: 1) a punch mark in the middle to make sure they are centered between the two tracks 2) I used a 1/16" roll pin at each end to keep them together and 3) filed the ends with a very slight taper and rounded the ends a bit to make them easier to insert into the slot in the track.
They work great. I broke down a dozen sheets of 3/4" ply without any movement and everything was within ~0.5mm. My only regret was not making them a bit smaller so they fit into the TS55 systainer. The ones I made barely fit diagonally in a systainer.
Offline Bohdan
« Reply #45 on: August 18, 2015, 07:33 PM »
Mine were also too long so I just leave them in the middle of the longer track. That way you always have them on hand and the screws don't get lost.
Offline mike_aa
« Reply #46 on: August 18, 2015, 08:08 PM »
That is one great idea!  Thanks  ;D
Mike A.
Offline chris s
« Reply #47 on: October 15, 2015, 09:05 AM »
I just made a pair. They are the greatest
Offline Chris99
« Reply #48 on: October 16, 2015, 06:36 PM »
The hockey puck shimming up the MFT is particularly genius.  [big grin]
(Attachment Link)
« Reply #49 on: October 16, 2015, 07:10 PM »
It's not a hockey puck but individual round rubber slices you use to level a billiard table. Bought 'me on Amazon.com if I remember correctly in various thickness.
Here is a link to one size: http://www.amazon.com/Imperial-16-Inch-Rubber-Shims-Per/dp/B005GVIL9A/ref=sr_1_9?ie=UTF8&qid=1445037069&sr=8-9&keywords=Level+billiard+table
Offline mrFinpgh
« Reply #50 on: March 12, 2017, 10:59 PM »
I'm reviving a dead horse here, after being reminded of this on @UncleJoe 's thread.
I purchased the materials to make these, but I don't have a drill press.   I've drilled through metal plenty of times with my hand drills, but it seems like precision may be more critical here.
Is it possible to do these without a drill press?  Or should I be looking to find time in a shop that has one I can use?
Thanks,
Adam
Offline Svar
« Reply #51 on: March 13, 2017, 12:23 AM »
I did it without a drill press.
Offline Bob D.
« Reply #52 on: March 17, 2017, 06:44 AM »
Great idea! I'm glad this thread has resurfaced.
I am going to order the materials to make a set for my DeWalt tracks.
Offline mrFinpgh
« Reply #53 on: March 17, 2017, 08:24 AM »
Neat.  I'm going to have to put a pair of these together.  I don't feel like the Festool connectors are very stable when it comes to a lot of lifting and replacing the guide rail.
Thanks,
Adam
Offline magellan
« Reply #54 on: March 17, 2017, 03:07 PM »
I made a set of these today.  These are a great idea.  Thank you fellows for posting your ideas here    I ordered the materials from McMaster-Carr.  I used 1/4x20 set screws with a point on them.  The screws that hold the pieces together I got locally.  Could not find short no.8's so I used m4 x 70x 6mm  screws   They worked perfectly
Offline ben_r_
« Reply #55 on: March 17, 2017, 05:55 PM »
Me too! Very cool!
Offline jasen
« Reply #56 on: February 06, 2018, 04:07 AM »
Thanks to everyones ideas & input and @Bohdan for the info.
To the metric guys out there and especially Australians 12mm x 3mm stainless steel is available at most stainless steel merchant
I bought 4m bar from merchant :( as that was there minimum supply plus $4 a cut!
Would have been cheaper from these guys inc $13 delivery http://allthingsstainless.com.au/virtuemart/stainless-steel-flat-bar/304-12mm-x-3mm-stainless-steel-flat-bar-per-metre.html
500mm x 4 bars (all 3mm thick). They fit nice and snug. 8 x M5 6mm set/grub screws from any nuts & bolts shop $2 for 8 or if you're desperate - Bunnings for $6.48 for 10
I bought a Tap & Die set last week from Aldi for $29.00 as I knew I needed one for this project. It worked a treat as I'd never done this stuff before. I didnt bother with the 2 screws to hold it together as the bars are clamped nice and tight.
One note that they do sell Mild steel but was 13mm x 3mm - it might fit and would be easier to cut and a lot cheaper.
HTH anyone who is thinking of making them - well worth it and the bonus as we all know - save money and the possibility of damaged rails
Cheers
Offline mattman
« Reply #57 on: March 13, 2018, 09:38 PM »
At 12mm wide and 18" long, are these connectors sufficient to align the two tracks without assembling with a straightedge?  It would be easy to upgrade to 36" long, but if 18" gets the job done...
Offline JZ Bowmannz
« Reply #58 on: March 29, 2018, 10:10 PM »
The end of the rails are not necessarily square; and there will be slop in the channel for 12mm connector, so you would need a straight edge to align the rails. I use Betterley straightline.
Betterley Straightline
Offline cubevandude
« Reply #59 on: April 14, 2018, 06:33 AM »
Here is a repost of the original picture as it is gone.
https://i.pinimg.com/564x/60/c5/cc/60c5cc33839ab01d6c860ddeab6aa300.jpg
« Last Edit: February 21, 2019, 04:38 PM by cubevandude »
