Author Topic: Homemade guide rail connectors (not your typical ones)  (Read 72659 times)
Online Svar
« on: September 14, 2012, 05:41 AM »
I needed to join two rails and checked out connectors. Wow! $32 for a pair of metal bars with holes in them. You’ve got to be kidding. Profit margin must be over 90% on that thing <end of rant>.
I stopped by the hardware store to pick up a piece of metal about 12x6 mm. They didn’t carry that, but instead (as it turned out later fortunately) had one 12.7x3.2mm. I then realized I could do better than the stock part.
I often read complaints that joined rails don’t stay aligned together. Festool warns not to over tighten the screws, in fact, boasts flat heads to prevent just that. And the connectors are about only Festool item that has bad reviews on Amazon. No wonder they can’t be secured well; steel screws dig into soft aluminum rail.
My solution is to make the connector consisting of two thinner 3.2 mm parts (see picture). The top one has threaded holes with Allen screws (M6, 6mm long). The bottom one has non through (1/3 deep) cone shaped holes that align with the screws. These holes help to fully engage the threads and prevent lateral sliding of two parts. As you tighten the screws the two pieces are pushed apart and firmly press against inside of the slot distributing pressure over large area. You can tighten them very well.
While fitting the connectors I discovered that two t-slots of the guide rail have different width by about 0.3 mm and had to file the bars a bit :-(.
I tested the setup. After joining two rails I moved, rotated, flipped, lifted by one end, and kicked them around. Checked again with a straight edge – perfect.
P.S. Festool, if you like the idea e-mail me a thank you card attached to a banknote or a green tool of your choice :-)  [poke]
55511-0
« Last Edit: September 14, 2012, 05:44 AM by Svar »
Offline Nigel
Re: Homemade guide rail connectors (not your typical ones)
« Reply #1 on: September 14, 2012, 07:03 AM »
Yep, I like the look of that and the allen key heads.I may have to try that if you don't mind?
Offline Richard/RMW
« Reply #2 on: September 14, 2012, 07:36 AM »
Brilliant!
Thanks for posting.
RMW
Offline UncleJoe
« Reply #3 on: September 14, 2012, 08:57 AM »
At first I thought why? really?  Then I read this part " The bottom one has non through (1/3 deep) cone shaped holes that align with the screws." and the light turned on and I said brilliant he has created a wedge affect to really grab the entire slot.  With this design you are distributing pressure on the bottom of the slot and the top of the slot. This should be rock solid. Extremely good concept and design.  It is simple, and it is a large improvement.
Festool should be all over this. I will be making one as soon as time allows. I guess you could easily make it longer with an additional hole or two if desired.
I owe you a beer.  [thumbs up]
I am not young enough to know everything!
Offline PeterK
« Reply #4 on: September 14, 2012, 09:06 AM »
I will definitely try this myself!! This has been a frustrating aspect of the rail design for me as I have dimpled all my rails trying to tighten them and then still am able to knock them out of alignment. Festool should purchase your idea or you need to market this!
Offline Reiska
  • Hackers build things, Crackers break them.
« Reply #5 on: September 14, 2012, 09:39 AM »
If you could somehow add two half attached rivets to the design to keep the halves together but still movable vertically it would make these a serious selling article.
What I mean is that the rivet would be welded to the bottom bar, go through the top one and keep them together with a conical top cap while still allowing the top bar to move vertically with the tightening of the screws.
The sky's the limit in my workshop, literally. [big grin]
Offline VesaS
« Reply #6 on: September 14, 2012, 10:18 AM »
Unfortunately Festool don't pay you, this has been already in use.
Makita rail connector
it would be nice surprise if Festool send you Domino or something like that..
Vesa
Hobbyist with high demands (for tools)
Offline John2532
    • Toolimprovements.com
« Reply #7 on: September 14, 2012, 11:00 AM »
Great idea Svar!  If you wanted to to semi-attach the 2 rails together as Reiska suggested,  you could drill a couple holes in one of the bars and epoxy in a couple of thin rare-earth magnets. That would hold them together for ease of assembly but still allow movement.  It looks like it works great as it is though.
John
Offline Nigel
« Reply #8 on: September 14, 2012, 01:45 PM »
If you store the connectors in the rail there is no need.
Online Svar
« Reply #9 on: September 14, 2012, 06:08 PM »
Oh, no! Makita beat me to that!  [doh] I won’t get rich!  [crying]
But are Makita’s handmade, and come with file marks left by a skillful craftsman?!   [big grin]
Thank you all for the comments. Holding screws could be added like so…
55523-0
Also, when not stored in the rail, set screws could be tightened lightly and they won’t get lost. Pin/screw in the middle will hold parts together.
Now I need to build a nice tiny systainer to store the connectors in.
« Last Edit: September 14, 2012, 06:43 PM by Svar »
Offline kfitzsimons
« Reply #10 on: September 14, 2012, 09:25 PM »
Great idea. I'd buy a pair if you made them available. File marks and all!
Offline Stefan23
« Reply #11 on: September 24, 2012, 11:03 AM »
That's brilliant... Thanks for sharing your great idea with us  [smile]
« Last Edit: September 24, 2012, 12:10 PM by Stefan23 »
Offline BrotherBrian
« Reply #12 on: September 24, 2012, 11:09 PM »
Svar, If you're inclined to make another set, please let me know, I will send you a thank you card and a bank note.
Offline fshanno
« Reply #13 on: September 25, 2012, 10:57 PM »
This may be a little too far over the top but how about holes in the inside channel so that you could tighten both sets of connecters from the top?
Offline SRSemenza
« Reply #14 on: September 25, 2012, 11:21 PM »
I like this idea too, that would make it easier to keep them aligned  while tightening.
Offline overanalyze
Re: Re: Homemade guide rail connectors (not your typical ones)
« Reply #15 on: May 04, 2014, 01:52 AM »
Reviving an old thread.  Great great idea! Made a set tonite!
Offline wow
  • Inactive Member
« Reply #16 on: May 04, 2014, 02:02 AM »
Do you think these would work acceptably if made from T6061 aluminum instead of steel? I know the Festool ones are steel but I'd really like to stay away from using a dissimilar metal if aluminum would work? Also it would be easier to work with than steel.
I know it wouldn't be AS strong, but the question is "would it be strong ENOUGH"?
Offline overanalyze
Re:
« Reply #17 on: May 04, 2014, 02:08 AM »
I thought about aluminum but felt the set screws would strip out to easy if over tightened. That and my hardware store didn't stock1/8"x1/2" aluminum. I still had to grind that size down a bit. I am going to either paint these or clear coat them. I am not worried about dissimilar materials for a piece that won't be used that much.
Offline bruegf
  • Michigan
« Reply #18 on: May 04, 2014, 08:59 AM »
Dissimilar metals are not issue as long as they are not in the presence of an electrolyte (e.g. water).  You won't see any galvanic corrosion as long as you keep the rails dry while joined with the steel connector.
Fred
Offline EV
  • Reception Desk Installed in Riyadh, Saudi Arabia.
« Reply #19 on: May 04, 2014, 05:45 PM »
As far as I remember Makita Supplying this type of connector with their track saw. I personally found it fiddly keeping to parts together.
--------------- " If you need to borrow a tool, means you need it, if you need it, go and BUY IT!!! " ---------------
Offline overanalyze
Re: Re: Re: Homemade guide rail connectors (not your typical ones)
« Reply #20 on: May 04, 2014, 05:58 PM »
That's why I attached the two pieces to each other with a small screw.
Offline JZ Bowmannz
« Reply #21 on: September 24, 2014, 10:37 PM »
Made my version tonight following you guy's lead.
Modified to what I think a little better config:
both pieces are 18" long instead of 12";
they are true 12 mm wide stocks - so no more material removal;
one piece is 4.0 mm thick, which will receive all tapping operation to have a better thread engagement;
other piece is 2.0 mm thick, which only has (2) countersink through holes to keep two pieces together;
I did try them, connected much more solidly than my old Festool ones.
Thanks SVAR!
202765-0
202767-1
202769-2
202771-3
« Last Edit: September 24, 2014, 10:42 PM by JZ Bowmannz »
Offline duburban
« Reply #22 on: September 24, 2014, 11:27 PM »
sweet. i'm totally doing this asap. where did you find the stock?
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline JZ Bowmannz
« Reply #23 on: September 25, 2014, 08:37 AM »
Duburban,
Stocks came from Alro Steel here locally in Ann Arbor, Michigan area. We are in automotive world, and it's easier to get stuff in metric locally than the rest of the country I think.
http://www.alro.com/
Offline duburban
« Reply #24 on: September 25, 2014, 10:34 AM »
Thanks. This type of material is not something I've spent much time shopping for.
Offline Rusty Miller
« Reply #25 on: September 25, 2014, 12:07 PM »
McMaster-Carr has 2mm x 12 and 4mm x 12 for like $10 for 2 3ft pieces. Just ordered some.
Rusty
Rusty Miller
I'd rather be woodworking!
« Reply #26 on: September 30, 2014, 09:09 AM »
Just received the steel from McMaster-Carr and it is a perfect fit.  Won't have to do any sizing just a file swipe on the sharp edges.  Now to drill for the set screws and I'll be ready.
Rusty Miller
Offline promark747
« Reply #27 on: September 30, 2014, 09:14 AM »
Rusty,
What was the part number from McMaster-Carr?
Let us know how it goes drilling the set screws.
« Reply #28 on: September 30, 2014, 09:26 AM »
Low carbon steel 4mm x 12mm x 3'  6775T43  $5.84
Low Carbon steel 2mm x 12mm x 3'  6775T23 $4.69
With shipping it was less than $20
I'll post a couple pics after I get them drilled and together. One piece of each cut in half will yield a set of connectors.
A special thanks to Mr. Bowmannz for the sizes of the steel.  It wasn't hard to find the right size at McMaster-Carr.
« Last Edit: September 30, 2014, 09:31 AM by Rusty Miller »
Rusty Miller
Offline JZ Bowmannz
« Reply #29 on: September 30, 2014, 09:54 AM »
Rusty,
I used only #8 for connecting two piece together, and #10 x 1/4" set screws.
Figure if use M6 set screws, more than half width of the material would be drilled out on the 4 mm piece, not sure that will effect the total strength of the connectors. And 1/4" long set screws will stay below the suface of the rail in the slots.
Hope that helps.
Offline promark747
« Reply #30 on: September 30, 2014, 10:13 AM »
JZ/Rusty,
Thanks...that was the last part I was wondering about -- which size set screws to use, and whether to use the conical type.
Offline JZ Bowmannz
« Reply #31 on: September 30, 2014, 10:34 PM »
The hex hole for the Allen Wrench in #10 set screws was too small,and I was afraid to strip it when I crank it, so I found these with slot at local hardware store, they have slots just like the Festool ones.
« Reply #32 on: October 03, 2014, 02:32 PM »
Just finished one connector.  Still have to add the little screws to hold the bottom piece to the top piece and finish the second connector.  But I must say the connector locks up in the rail quite nicely.  Looks like it is going to work perfectly.
BTW, I used 10x32 1/4 setscrews and they work great.
I hope to cut some ply this weekend so I'll be putting two 55" rails together so we'll see how they really work.
« Last Edit: October 03, 2014, 02:36 PM by Rusty Miller »
Rusty Miller
Offline greymann
« Reply #33 on: October 04, 2014, 12:34 PM »
I really like this design over the standard connectors.  Hope Festool will finally take notice.
If you are looking for a place to store these while not connecting two rails together, here's a suggestion.
I use the 1900 rail a lot on my homemade tables and find that it has more flex than I would like, especially when resting the saw on a portion hanging over the end of the table.  I have taken to using the standard connectors in the underside slot as stiffeners and have been pleased with the results.  I believe your longer bars will be even more effective.  I usually put one near the close end of the rail and the other nearer the center.
I also never have to remember where I put them.
Dick Perry
"But for the sky, there are no fences facing."
Offline Slartibartfass
  • How'ur'duin'......
    • The Accidental NAINA Store Email List
« Reply #34 on: March 05, 2015, 09:00 PM »
Here are mine. Roughly 15" long.
Offline Pizza Steve
« Reply #35 on: March 26, 2015, 07:05 AM »
@Slartibartfass- that's a nice looking drill press/milling vice.  What model is it?
Offline Pizza Steve
« Reply #37 on: April 01, 2015, 08:56 AM »
Would these homemade connectors also work as MFT connectors?
Offline sgt_rjp
« Reply #38 on: April 01, 2015, 09:51 AM »
Speaking of MFT connectors, are there any threads concerning them(yours or others)?  I just ordered a second MFT/3 and was already thinking about doing something with 8020 when I saw yours.
Offline JZ Bowmannz
« Reply #39 on: April 01, 2015, 09:58 AM »
The MFT connectors are 14mm x 9mm.
You would need some different stocks for that purpose.
I would try layer of 12mm x 9mm stock plus a layer of 2mm x 9mm stock.
There are something called "Key Stock" available that are 14mm x 9mm. You have to do some machining of course.
http://www.mcmaster.com/#key-stock/=wk9rww
Online Bohdan
« Reply #40 on: April 01, 2015, 10:03 AM »
When I made my rail connectors I used 12 x 3 mm stainless steel so I don't have to worry about rusting.
I also made them 500mm long and they line up the rails perfectly.
Offline sgt_rjp
« Reply #41 on: April 01, 2015, 04:07 PM »
When I mentioned MFT connectors, I was actually referring to Slartibartfass's.  I was wondering if you could use longer lengths of 8020 and have gaps between the tables.  Maybe even another work surface between them?
« Reply #42 on: April 01, 2015, 04:16 PM »
To use these style of connectors (not my idea btw) you would just need to up-size them.
As to using 80-20 you can hang them on the MFT/3 profile between tables to act as a support.... works with the 8020 T Slot Aluminum Extrusion 15 S 1515 ULS profiles.
i've done that to hang some Festool clamps or small extension tables to the MFT/3 (also not my idea....power of the FOG at work....).
Offline SPM in King
« Reply #43 on: August 17, 2015, 02:22 PM »
Thanks to all who contributed to this thread.  Great idea - the 2 pieces - 2 and 4mm.  I made 2 sets (3 rails) last week and while they are not as perfect looking as some, they work well.  I made them 18" long and used 1/4" 24TPI set screws.  Used McMaster steel because I could not find a metric supplier here in Canada - land of metric!!
Here's hoping that the good folks at FT get the message - the standard ones don't do the job!  I was getting at least 1/8" play in the track.  That makes for some very poor cuts, especially when using the TS for hardwood glue ups.
Steve
TS 75 EQ, RO 150 FEQ
Offline jcoby
« Reply #44 on: August 18, 2015, 03:55 PM »
I made two sets of these with a few changes: 1) a punch mark in the middle to make sure they are centered between the two tracks 2) I used a 1/16" roll pin at each end to keep them together and 3) filed the ends with a very slight taper and rounded the ends a bit to make them easier to insert into the slot in the track.
They work great. I broke down a dozen sheets of 3/4" ply without any movement and everything was within ~0.5mm. My only regret was not making them a bit smaller so they fit into the TS55 systainer. The ones I made barely fit diagonally in a systainer.
Online Bohdan
« Reply #45 on: August 18, 2015, 07:33 PM »
Mine were also too long so I just leave them in the middle of the longer track. That way you always have them on hand and the screws don't get lost.
Online mike_aa
« Reply #46 on: August 18, 2015, 08:08 PM »
That is one great idea!  Thanks  ;D
Mike A.
Offline chris s
« Reply #47 on: October 15, 2015, 09:05 AM »
I just made a pair. They are the greatest
Offline Chris99
« Reply #48 on: October 16, 2015, 06:36 PM »
The hockey puck shimming up the MFT is particularly genius.  [big grin]
(Attachment Link)
« Reply #49 on: October 16, 2015, 07:10 PM »
It's not a hockey puck but individual round rubber slices you use to level a billiard table. Bought 'me on Amazon.com if I remember correctly in various thickness.
Here is a link to one size: http://www.amazon.com/Imperial-16-Inch-Rubber-Shims-Per/dp/B005GVIL9A/ref=sr_1_9?ie=UTF8&qid=1445037069&sr=8-9&keywords=Level+billiard+table
Offline mrFinpgh
« Reply #50 on: March 12, 2017, 10:59 PM »
I'm reviving a dead horse here, after being reminded of this on @UncleJoe 's thread.
I purchased the materials to make these, but I don't have a drill press.   I've drilled through metal plenty of times with my hand drills, but it seems like precision may be more critical here.
Is it possible to do these without a drill press?  Or should I be looking to find time in a shop that has one I can use?
Thanks,
Adam
Online Svar
« Reply #51 on: March 13, 2017, 12:23 AM »
I did it without a drill press.
Offline Bob D.
« Reply #52 on: March 17, 2017, 06:44 AM »
Great idea! I'm glad this thread has resurfaced.
I am going to order the materials to make a set for my DeWalt tracks.
Offline mrFinpgh
« Reply #53 on: March 17, 2017, 08:24 AM »
Neat.  I'm going to have to put a pair of these together.  I don't feel like the Festool connectors are very stable when it comes to a lot of lifting and replacing the guide rail.
Thanks,
Adam
Offline magellan
« Reply #54 on: March 17, 2017, 03:07 PM »
I made a set of these today.  These are a great idea.  Thank you fellows for posting your ideas here    I ordered the materials from McMaster-Carr.  I used 1/4x20 set screws with a point on them.  The screws that hold the pieces together I got locally.  Could not find short no.8's so I used m4 x 70x 6mm  screws   They worked perfectly
Online ben_r_
« Reply #55 on: March 17, 2017, 05:55 PM »
Me too! Very cool!
Offline jasen
« Reply #56 on: February 06, 2018, 04:07 AM »
Thanks to everyones ideas & input and @Bohdan for the info.
To the metric guys out there and especially Australians 12mm x 3mm stainless steel is available at most stainless steel merchant
I bought 4m bar from merchant :( as that was there minimum supply plus $4 a cut!
Would have been cheaper from these guys inc $13 delivery http://allthingsstainless.com.au/virtuemart/stainless-steel-flat-bar/304-12mm-x-3mm-stainless-steel-flat-bar-per-metre.html
500mm x 4 bars (all 3mm thick). They fit nice and snug. 8 x M5 6mm set/grub screws from any nuts & bolts shop $2 for 8 or if you're desperate - Bunnings for $6.48 for 10
I bought a Tap & Die set last week from Aldi for $29.00 as I knew I needed one for this project. It worked a treat as I'd never done this stuff before. I didnt bother with the 2 screws to hold it together as the bars are clamped nice and tight.
One note that they do sell Mild steel but was 13mm x 3mm - it might fit and would be easier to cut and a lot cheaper.
HTH anyone who is thinking of making them - well worth it and the bonus as we all know - save money and the possibility of damaged rails
Cheers
Offline mattman
« Reply #57 on: March 13, 2018, 09:38 PM »
At 12mm wide and 18" long, are these connectors sufficient to align the two tracks without assembling with a straightedge?  It would be easy to upgrade to 36" long, but if 18" gets the job done...
Offline JZ Bowmannz
« Reply #58 on: March 29, 2018, 10:10 PM »
The end of the rails are not necessarily square; and there will be slop in the channel for 12mm connector, so you would need a straight edge to align the rails. I use Betterley straightline.
Betterley Straightline
Offline cubevandude
« Reply #59 on: April 14, 2018, 06:33 AM »
Here is a repost of the original picture as it is gone.
https://i.pinimg.com/564x/60/c5/cc/60c5cc33839ab01d6c860ddeab6aa300.jpg
« Last Edit: February 21, 2019, 04:38 PM by cubevandude »
Offline Mixxedupmedia
« Reply #60 on: April 23, 2018, 10:56 AM »
Great ideas! I just joined the site ...should have done this before buying the stock connectors.😕
Bad decisions make the best stories.
Offline mwest
« Reply #61 on: August 29, 2018, 02:06 PM »
In the original picture/posting, there are some 80/20 brackets hanging on the side of the MFT side rails. Are these modified to hang on the Festool MFT "extrusion"? I want to hang some small boxes for clamps and dawgs, etc. Any recommendations?
Offline brentasmith
« Reply #62 on: September 07, 2018, 11:08 PM »
I noticed Festool is extremely quiet on this thread...
(Attachment Link)
« Reply #63 on: September 08, 2018, 12:02 AM »
And FWIW...I don’t think Festool will weigh in on this one. From a corporate standpoint, they have way bigger fish to fry (from a class action suit perspective) with the Kapex self immolation issues.
There was a great thread about manufacturing your own connectors by another FOG member Malte. I can’t remember his web name... [crying]
Offline Peter Halle
« Reply #64 on: September 08, 2018, 07:42 AM »
Festool doesn't comment on many threads anymore.  I suspect that a thread that started 6 years ago and is about an accessory won't be noticed or rise to the top of the list.
Just my 2 cents.
Offline oberlin1
  • Larry
« Reply #65 on: January 09, 2019, 04:19 PM »
Finally finished my set...no one will mistake me for a machinist but they work and they seem to stow okay in my shorter rail.   [wink]
CXS, ETC-125, TS-75, CT-26E, LS-130, RO-150 FEQ
Offline cubevandude
« Reply #66 on: February 21, 2019, 04:30 PM »
https://www.mcmaster.com
Thanks for sharing this info.  I ordered 4pc @12" of each of the 4mm and 2mm and made 4 sets of connectors.  I also got a bag of 100 - 10-32 X 1/4" setscrews off ebay from Hong Kong.
https://www.ebay.com/itm/10-32-x-1-4-Thread-Hexagon-Socket-Set-Cup-Point-Alloy-Steel-Grub-Screw-100-Pcs-/391548169756?hash=item5b2a16ee1c
I put one setscrew in the middle of each, in from the back, so the head is flush to hold them together.  They work great and I was able to make 4 for the price of 1 Makita connector.  I'll post pictures when I get a chance.
« Last Edit: February 25, 2019, 01:58 PM by cubevandude »
Offline cubevandude
« Reply #67 on: February 22, 2019, 10:58 AM »
Here are the pics.  My dollar store screwdriver (Felo Smart Clone).  I sanded some of the mill scale off with 220 grit sandpaper which made them nice and smooth.
Once I cut the ends of the Makita tracks square, things should line up really nice.
Update: Got around to cutting the ends of the Makita rails square.  The 55" rails weren't bad, but the 75" rail was really bad on both ends.
« Last Edit: August 15, 2020, 07:17 AM by cubevandude »
Online BarrySumpter
« Reply #68 on: July 19, 2020, 07:56 PM »
DIY Festool Rail Connectors
18” = 457mm
3’ = 914mm
My Festool Battery Tracks Saw Systainer - 390mm wide
In Melbourne, Victoria  Australia
George Archer Metals
4 * 500mm x 3mm x 12mm
1 * 4m length - Grade 316 - $9AU +$15 Couriers Plus Delivery +GST
Less than $30AU delivered
For 8 sets of two bars
Might make two at 390mm to fit systainer
« Last Edit: July 20, 2020, 10:36 PM by BarrySumpter »
May Yesterdays Tears Quench the Thirst for Tomorrows Revenge
Offline TSO_Products
    • TSO Products LLC
« Reply #69 on: July 19, 2020, 08:43 PM »
for those on this FOG thread who would rather do woodworking than make their own Guide Rail Connector you might consider this:
https://tsoproducts.com/accessories/grc-12-self-aligning-guide-rail-connectors/
Nothing home made about this one. TSO has done the homework for you, including custom enngineered "set screws" that don't ding your guide rails [wink]
Read the reviews
Hans
Offline Bob D.
« Reply #70 on: July 20, 2020, 10:11 AM »
Read the reviews
Hans
It's tough to beat the TSO guide rail connectors.
When I bought my TSC55 and rails I also bought the FT guide rail connectors, they work and at the time might have been the best solution out there but they are not the best today.
I also tried many of the other fixes that others came up with and told us about on the FOG. I bought a set of the Bosch connectors, didn't like them. I bought the parts for and made the DIY connectors. The finished product was fine but still not what I was looking for.
When TSO came out with their guide rail connectors I decided to take one more chance and bought a pair. I am so glad I did because none of the others come close. I only wish they had been around when I bought my rails, I could have saved myself a lot of aggravation and money.
Offline cubevandude
« Reply #71 on: July 31, 2020, 08:36 AM »
Hans
Those are really nice!  At one time a man who worked as carpenter made almost everything he needed.  Nothing can beat a creative mind.
