Author Topic: FS rail positioning jig  (Read 5746 times)
Offline Boris Beaulant
    • L'Air du Bois
« on: March 16, 2015, 07:23 AM »
In a current projet I would like to use this kind of joinery to build boxes under a desk :
I would cut the bevel on panels with my TS55 plunge saw.
But, in order to cut them, I build a small jig to place correctly my FS plunge saw rail.
This jig permit a first cut at 90° with the table saw and after cut the 45° bevel with the plunge saw without changing the panel width.
You can view it in action in this video. But sorry, it's in French.
« Last Edit: March 16, 2015, 02:22 PM by Boris Beaulant »
Offline Charlie Mac
Re: FS rail positioning jig
« Reply #1 on: March 16, 2015, 02:07 PM »
Je ne sais pas ce que vous venez de dire, mais vous avez une très belle zone de travail et je ai fait un gabarit bien pensé. (appareils)
Merci de poster ce sujet.
-Charlie
    • L'Air du Bois
« Reply #2 on: March 16, 2015, 02:35 PM »
Thank you Charlie. It's right that it's a pleasure to work in my workshop.
Offline bionicus
« Reply #3 on: March 16, 2015, 09:41 PM »
Nice. I made a simple pair of these years ago after struggling with the exact same problem. Mine don't have any moving parts but are the same otherwise and give me perfect mitres. I tried using the edge stops included with the LR32 kit but they never seemed to be as accurate. Working with really thin veneer ply there's almost no room for error.
Your YouTube channel is great. Really nice workpieces.
    • L'Air du Bois
« Reply #4 on: March 17, 2015, 02:50 AM »
Thank you Bionicus ;)
The moving part permit to consider the blade width variation or to have a positive or negative translation of the cut line. In this case the jig is a little more versatile.
Offline mwildt
« Reply #5 on: March 17, 2015, 11:35 PM »
Just awesome.
I could see that jig ending up as one of Woodpecker's 'onetime tools'. You should send them an email. Who knows maybe they like it.
« Last Edit: March 17, 2015, 11:37 PM by mwildt »
Offline NuthinFancy
« Reply #6 on: January 19, 2020, 07:43 PM »
I realize this thread is older, but I'm adding this in case others are still interested in the original topic.
A fellow named Huy in Alabama (he has a YT channel "The Alabama Woodworker") with a number of interesting videos, including one for what he calls his MOAT: , which has track/rails built into the long sides of the table.
While not a "build" video, he does provide details, including specifications, about the Misumi parts used for the rails.
An interesting approach that I'm considering for my (first) assembly, etc. table.
"If the women don't find you handsome, they should at least find you handy."  Red Green
« Reply #7 on: January 19, 2020, 09:07 PM »
Has anyone found the single channel Series 6 extrusion he used?
Offline Mario Turcot
« Reply #8 on: January 20, 2020, 01:32 AM »
@Michael Kellough
Mitsumi Extrusion
Mario
« Reply #9 on: January 20, 2020, 10:00 AM »
@Michael Kellough
Mitsumi Extrusion
That’s an ordinary 4 channel extrusion. He used a single channel extrusion on the side and top of that heavy hardwood band around the perimeter of the table.
« Reply #10 on: January 20, 2020, 10:14 AM »
@Michael Kellough
Mitsumi Extrusion
Single Slot Extrusion series 6
Mario
« Reply #11 on: January 20, 2020, 10:19 AM »
Thanks Mario but that is still not what he has in his table. Did he saw away all the stuff that surrounded the channel? Why didn’t he just use ordinary T-track instead?
In the video, look at the close-up at 1:15.
« Reply #12 on: January 20, 2020, 10:30 AM »
My bad, I didn't notice untill you point out the video  [embarassed]
« Last Edit: January 20, 2020, 10:32 AM by Mario Turcot »
Mario
« Reply #13 on: January 20, 2020, 10:36 AM »
The extrusion he used is only about 18mm x 12mm. Didn’t see anything close to that in Series 6
« Reply #14 on: January 20, 2020, 12:17 PM »
I wrote Huy and got an immediate reply.
“ I bought the extrusion directly from Misumi. I included part numbers and links in my "Precision Miter Saw Fence" video. Check that out and your questions will be answered. ”
I’ll check that out later.
« Reply #15 on: January 20, 2020, 12:25 PM »
There you go Flat Extrusion (V-Channel Track)
The 15mm one have two holes at the end. I guess those holes are running along each sides no matter the length. One of the use for the holes is capping
Caps
They also have the same track with shoulders Track with shoulders
« Last Edit: January 20, 2020, 12:29 PM by Mario Turcot »
Mario
Offline sandy
« Reply #16 on: January 23, 2020, 09:39 AM »
What am I missing?  Can’t you just slide the rail and feel the edge of the board to be mitered and align it with the cut strip on the rail?
Sandy
Offline Svar
« Reply #17 on: January 23, 2020, 09:59 AM »
Sandy
I can't speak for the OP, but I think most track saws cut slightly away from splinter guard when tilted 45 deg. This is especially true for Mafell MT55. The jig might compensate for that offset.
« Reply #18 on: January 23, 2020, 12:29 PM »
Sandy
Also compensates for a worn down splinter guard and can be set to allow a specific thickness of stock to remain above the bevel. But all that can be achieved with a combination square registering between the stock’s edge and the right side of the rail spine. Except if you want the bevel to be well below the top of the stock. Then you’d need the jig and add a shim or spacer to allow the jig to slip under the rail.
Offline sandy
« Reply #19 on: January 23, 2020, 03:33 PM »
My understanding, and my experience, has been that the TS55 when "tilted" to make a bevel cut will cut along the splinter guard the same as when it is set to 90 degrees.  I understand that if you are using a "worn down" splinter guard you may need to adjust something, but that would also be true if you use the same worn splinter guard to make a 90 degree cut, so the (obvious) solution is to replace the splinter guard.
To the extent that you want the bevel to not extend all the way to the top of the piece being cut, you can readily do the offset by simply making a couple of marks on the surface of a sacrificial  board having the same thickness, and using the sacrificial to push the board to be cut under the trim edge of the rail.
Unfortunately, to me, anyway, this is a "solution" to a non-existent problem.
Sandy
« Last Edit: January 24, 2020, 04:53 AM by sandy »
Online Cheese
« Reply #20 on: January 23, 2020, 05:37 PM »
My understanding, and my experience, has been that the TS55 when "tilted" to make a miter cut will cut along the splinter guard the same as when it is set to 90 degrees.
You are correct...here's a shot, in order, of the TSC, HKC & Mafell MT 55 adjusted to 45º on a Festool rail. Both Festool saws touch the splinter strip while the Mafell is 2-3 mm away from it.
« Reply #21 on: January 23, 2020, 08:03 PM »
And if you then ran a TS 75 on the same rail your splinter guard would be cut back about 1mm. If you then set the TS 75 to cut a 45* bevel it would cut about a half mm away from the freshly cut splinter guard.
I think it scandalous that the TS 75 doesn’t match the TS 55 straight from the factory but it’s shocking that the much revered Mafell saws have such an imprecise relationship with the splinter guard at maximum bevel. From what I’ve read, the Mafell saws of the same model don’t even match, at max bevel.
Online Cheese
« Reply #22 on: January 24, 2020, 10:01 AM »
1. And if you then ran a TS 75 on the same rail your splinter guard would be cut back about 1mm. If you then set the TS 75 to cut a 45* bevel it would cut about a half mm away from the freshly cut splinter guard.
2. I think it scandalous that the TS 75 doesn’t match the TS 55 straight from the factory but it’s shocking that the much revered Mafell saws have such an imprecise relationship with the splinter guard at maximum bevel.
3. From what I’ve read, the Mafell saws of the same model don’t even match, at max bevel.
1. Interesting information Michael ...as I don't own a TS 75.
2. I agree, my TS 55, HKC & TSC arrived at 3 different settings. The TSC & HKC were close but the TS 55 was way out. I've never understood in the age of lasers & vision systems why these tools couldn't be set to within .010" (.25 mm) of each other. If they were factory set within .010", that'd probably be good enough for 80% of the users.
3. I was really surprised when I first noticed that the Mafell "fell away from the splinter strip" when the blade was beveled.  [eek]  Every other feature on the saw is killer it's just too bad about the bevel situation.  [mad]
