Author Topic: Fix Festool SZO20 Z  (Read 897 times)
Fix Festool SZO20 Z
« on: July 27, 2019, 08:20 AM »
Hello!
Had a crash and got a hole/bump in my SZO20 Z template. Anybody know how to fix this?? Is it possible to use a 2 Component glue, or any other Products which will get hard and stable??
Offline ScotF
Re: Fix Festool SZO20 Z
« Reply #1 on: July 27, 2019, 09:47 AM »
You could try JB Weld - the putty might be the best for this application, or you could use tape to hold the liquid stuff in place until it sets and hardens. You then need to sand and shape it to the right dimension - so might be tricky to get it exact.
Offline TinyShop
« Reply #2 on: July 27, 2019, 10:02 AM »
What about filing the void with a piece of hardwood glued or epoxied in place or even a a piece of steel of the same thickness glued in place? Obviously, wood would be easier to shape versus steel. The bottom could be reinforced with a piece of sheet metal glued in place - increasing the thickness at the underside of the finger has no negative ramifications, right? In this vein, with a plate glued in place on the underside, polyester resin (Bondo) would work fine and is simple to shape/sand.
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline TSO Products
    • TSO Products
« Reply #3 on: July 27, 2019, 10:09 AM »
how about a brazing or silver soldering repair followed by filing under a magnifying viewer?
Depending on material a TIG welded repair.
Hans
TSOproducts.com
Offline Alex
« Reply #4 on: July 27, 2019, 10:38 AM »
Above mentioned fixes will break quickly. Want it done right, go to a welder to lay some drops of metal on it, and use a vile or angle grinder to bring it back to the correct shape.
