Author Topic: Latest Woodpecker OTT - Track Square  (Read 48585 times)
Offline jafenske
Re: Latest Woodpecker OTT - Track Square
« Reply #30 on: March 16, 2016, 09:04 PM »
I get that OTT are generally expensive. The OTT I have purchased before are quality tools that have worked well for me. As a community of makers it makes sense that many of you would have made your version of this tool to solve this problem with your work flow. These tools are made in America by Americans and I think that that has value.
« Reply #31 on: March 17, 2016, 11:28 PM »
As discussed earlier there are several versions of this jig floating around, this is the one I would purchase  from Rip Dog tools if it ever becomes available for sale.
Offline fritter63
« Reply #32 on: March 18, 2016, 12:16 AM »
Ironically , I use the big WP red square for this....
Offline Scorpion
« Reply #33 on: March 18, 2016, 09:24 AM »
I like the ripdog design better.  To me it makes more sense to attach to the top slot than beneath because clamps can still be used to affix the rail to the material if desired without removing the attachment.  For the side it also will lay perfectly flat on a surface or against the wall.  Probably the biggest advantage is how far apart the attachments to the rail are which should make it less prone to lose alignment.
Offline Bill L
« Reply #34 on: March 18, 2016, 12:01 PM »
Without something that "locks" the far end of the rail, I would be afraid of drifting out-of-square as I progress down the rail. I suppose you could line it up on the squared end, then gingerly apply a track rail clamp at the far end. But it would be so easy to break square.
Also, I find myself often needing every available cm of length of my 1400 rail. So I would frequently be needing to take the square off, then putting it back on and re-squaring.
Now I will brag to my wife that I just saved $99!
Offline anthonyz
  • Woodrave.com - MFT boring templates
    • Woodrave.com
« Reply #35 on: March 18, 2016, 12:14 PM »
If you are finding drift, clean off your sticky grip strips on the back of your track. I don't have any issue of my track moving, unless I am cutting on something, as smooth as MDF, and I have dust which has reduced the effectiveness of the Grip strips on the back of the tracks.  So, although I see other ways to achieve making your own square, or using a square, to square up your track, the drift thing seems that doesn't really apply to the square. You would still have the room to place a clamp on the other end of the track if for some reason someone has an issue of drift.
Offline Scorpion
« Reply #36 on: March 18, 2016, 06:00 PM »
I use pre-finished ply mostly for cabinets and the grip strips aren't great however with the Gecko I think the square type of accessory would be awesome.
Offline Eden1415
« Reply #37 on: March 18, 2016, 06:50 PM »
Once square,  clamp at the other end.  Melamine has the same problem.
BTW  I though you were suppose to always get a new tool to complete a project for your wife???  Did I get some thing wrong?  Give money back???
Offline Crazyraceguy
« Reply #38 on: March 25, 2016, 04:30 AM »
At least part of the cost is wrapped up in the OTT concept. One which I strongly dislike. I get that it is attempting to generate "buzz" or "hype" but you certainly don't need that with quality tools and the cost could be reduced by spreading the research/development over a greater volume. Everyone that may have been interested gets left out because they didn't know soon enough?
There are several OTTs that I would like to have..... too late now though
Offline jimbo51
« Reply #39 on: March 25, 2016, 09:30 AM »
I am not sure I understand how the new slot on the redesigned tool works. A drawing or picture would have helped.
Did anyone else receive the Woodpecker survey? I did notice that there was not a comment section. I added a comment/complaint in the section on tools used.  Wonder if I will get a reply.
Offline mark60
« Reply #40 on: March 25, 2016, 10:54 AM »
It looks to me like you'd put your clamp in the track then slide the square against your workpiece. The change just made clearance for the clamp.
« Reply #41 on: March 25, 2016, 12:49 PM »
Ya I did, thought is was kind of goofy though...
Woodpeckers questions: Are you willing to pay extra for tools made in the US?
What are your favorite woodworking tool manufacturers?
I don't know how my answer of early Powermatic products (pre-Jet) will help them much.  [huh]
Offline Scorpion
« Reply #42 on: March 26, 2016, 11:37 PM »
It's gathering data which they will then analyze and potentially make decisions on.  Without the data they're just guessing.  I think it's very clever.
« Reply #43 on: March 27, 2016, 01:42 AM »
[quote author=Scorpion link=topic=45595.msg450465#msg450465 date=1459049859
[/quote]
I guess you probably need to see all of the questions they asked. Don't get me wrong, I'm a huge fan of Woodpeckers and own a ton of their OTT tools, but this survey was strange to say the least. I never did divine in which direction they were heading and what information exactly they were trying to ferret out.
Actually, after completing the survey and submitting it, I just sat and thought, what were they really looking for and how will this survey benefit their cause?
Time will tell...
Offline Scorpion
« Reply #44 on: March 27, 2016, 08:55 PM »
Time will tell...
[/quote]
I took the survey too.  I also felt the questions and intended purposes weren't obvious but am used to data mining activities because of what I do.   N their mind the answer to the questions likely hep them understand something they think they want to know about...like feedback from a group f buddies during a bench racing session.   To your point, unless we know what the intent was, we may not get it.
Offline jimbo51
« Reply #45 on: March 27, 2016, 11:05 PM »
Woodpecker should be very careful how they analyze the data they are gathering.
Many years ago I read a book in which the author argued that the downfall of RCA as a major American company was greatly hastened by the huge amount of money that the company wasted on the development of the video disc. The disc and player never sold very well and was soon totally destroyed as a product by the VCR. Even before the VCR, the major problem was that each side of the disc only held about 30 minutes of pre-recorded material. A 2 hour movie meant changing a disc 3 times.
A retrospective analysis of the pre marketing research reveled that the research had been hugely biased in favor of positive ratings for the video disc. Proper research might have revealed that the demand for the product was going to be small and RCA could have invested the money in something else that might have kept the company going for a much longer time.
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #46 on: April 04, 2016, 12:33 AM »
http://www.woodpeck.com/tracksquare.html
I pre-ordered this item today.  Tomorrow (4/4/2016), is the last day for purchase before orders close.   Delivery in mid-August (gives me time to purchase my Festool TS 55 REQ + MFT/3 MultiFunction Table Package).
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline Shane Holland
  • Festool Dealer
« Reply #47 on: April 04, 2016, 12:49 AM »
Free shipping if you order from us.  [big grin]
877-866-5688
« Reply #48 on: April 04, 2016, 01:09 AM »
Shane,
Image of my FestoolProducts.com shopping cart:
Festool PT3561556 TS 55 REQ + MFT/3 MultiFunction Table Package   $1,258.50
Just waiting for the money to magically appear in my bank account!
Offline TSO Products
    • TSO Products
« Reply #49 on: May 11, 2016, 11:24 PM »
for those of you interested in a real solution to the concerns in this thread I invite you to keep an eye out for a new post with pictures from me on this subject later in June  [wink]
TSOproducts.com
Offline ear3
« Reply #50 on: May 12, 2016, 07:18 AM »
@Klemm Interesting....keep us posted
    • TSO Products
« Reply #51 on: June 12, 2016, 11:19 PM »
several examples of the new GRS-16 Guide Rail Square are already in the hands of several craftsmen around the country for evaluation at this time.
Hint: no more re-squaring after removing or even after installing the first time [smile]
more news to follow
TSOproducts.com
Offline jrichardson6
« Reply #52 on: January 02, 2017, 04:19 PM »
    Here's my way of using the parallel guide with a rail to make nice square crosscuts.
Offline Alan m
« Reply #53 on: January 02, 2017, 04:26 PM »
that works great in the shop.
i used to do this untill i bought the tso version.
the problem with this is that you cant put it in the systainer
