Author Topic: Domino ladder jig  (Read 3849 times)
Offline ear3
Domino ladder jig
« on: June 22, 2017, 07:47 AM »
So I had to build this small ladder for a child's bunkbed, and deciding to go the domino route, I needed to come up with a way to place a pair of dominoes at a 14.5 degree angle in matched rows on the rails.
I'd seen some demonstrations on the FOG for louvered windows, where the domino itself serves as the spacer, so I decided to adapt the concept and create a single spacer that could be used on both the left and right rails of the ladder.
So I ripped some plywood to the desired inter-rung spacing (9 inches), and then cut it rhombus shaped on the miter saw to width, with the miter angle still dialed in to the 14.5 degrees I had used for the ladder rails.  I cut it about 4 inches wider than the rail, so it would accommodate the two 1 7/8" fences that allowed the jig to butt up against the side of the rail.
Since the angle was the same as the rail, I simply lined up each fence along the edge of the jig, clamped it, and secured it with a nailer:
264670-0
Because I'm using a single jig for both rails, the fences go on opposite sides of the spacer (one on top, the other on the underside). The other important part to getting consistent domino placement was to use small spacer blocks to mark on each side of the jig the mortise center line:
264672-1
I actually made two jigs, a smaller one to set the first rung from the bottom of the rail, which was done by simply lining up the edge of the jig with the bottom of the rail:
264686-2
And then a larger one to set the spacing of the subsequent rungs. Doing the other rungs was straightforward. Once the first mortise were in, I inserted dominoes and butted up the bottom of the jig against them as well as the jig fence to the side of the rail, clamped it down, and plunged the next row of mortises:
264676-3
Rinse wash repeat for the remaining rows, then flipped the jig over to do the other rail:
264678-4
With the completed rails side by side you can see that the mortises line up (both jigs can be seen next to the rails):
264680-5
The rungs were parallel to the floor and evenly spaced when I dry fit the parts:
264682-6
So I clamped it up and am now just waiting for the glue to dry.
« Last Edit: June 22, 2017, 08:13 AM by Edward A Reno III »
Offline Rusty Miller
Re: Domino ladder jig
« Reply #1 on: June 22, 2017, 08:00 AM »
Nicely done!
Rusty Miller
I'd rather be woodworking!
Offline ChuckM
« Reply #2 on: June 22, 2017, 12:44 PM »
Brilliant! Wish you shot a video of using your jig, too.
Thanks for sharing.
« Last Edit: June 22, 2017, 01:09 PM by ChuckM »
Offline Iestyn
« Reply #3 on: June 11, 2019, 03:02 AM »
I know this topic is now way old but i wanted to say a BIG thank you
That is exactly what i needed.  I knew i needed to make a JIG, but the way you created the JIG was brilliant and made it possible for me to crack on and do the exact same layout.
Now to create the ladder rungs/steps.
v-groove they say!!!
Offline ear3
« Reply #4 on: June 11, 2019, 07:54 AM »
Welcome to the FOG!  Post some pics when you're finished @Iestyn
