Author Topic: Cutting/work table  (Read 167690 times)
Offline overanalyze
Cutting/work table
« on: August 01, 2013, 11:41 PM »
Thought I would post up some pics of my cutting table. It is all assembled with half laps so it breaks down real quick.
EDIT> added spaces  to seperate pictures.
« Last Edit: August 02, 2013, 06:14 PM by SRSemenza »
Offline builderbob
    • RJP Remodeling
Re: Cutting/work table
« Reply #1 on: August 02, 2013, 12:07 AM »
That looks great!  I see some kerf marks, so I'm assuming you've used it...how do you like it?
Kapex, TS55, CMS GE, Carvex 420, Domino DF500, MFK 700, OF 2200, OF 1400, OF 1010, EHL65, RAS 115, RTS 400, RO150, ETS 150/3, ETS 125, CT 22 (2), CXS (2), C-15+3, T-12+3, PSB 300 & more MFT's than i can count!
« Reply #2 on: August 02, 2013, 12:25 AM »
Can you post pics of it broken-down? Is it meant to be moved from job to job?  Regardless, it looks great. I'm looking to build portable job site table and can't decide on design. Are you happy with its stability? Sorry all the questions, david
Offline Motown
« Reply #3 on: August 02, 2013, 02:33 AM »
Really clean design. Do you mind sharing some of the dimensions: height, width, length?
Offline pugilato
  • Pugilato is not really my name... Andy
« Reply #4 on: August 02, 2013, 07:36 AM »
I like it... more info, please
Offline overanalyze
« Reply #5 on: August 02, 2013, 08:03 AM »
Thanks guys! I did steal the basic design from another one I saw and then made quite a few enhancements. It is meant to break down and move from shop to the job site. I can take a picture the next time I break it down.
 I used two sheets of 3/4" luan plywood. It's assembled width is 4' x 8'.  I made a quick jig to route the half laps all the same. This way all the pieces are interchangeable. I made the height match my portable table saw on its stand, so it can double as an out-feed table.
It can hold a ton of weight and it is fairly stable. The half laps are snug but not tight. This does allow for a little "sway" lengthwise, but nothing major.
Offline polarsea1
« Reply #6 on: August 02, 2013, 05:10 PM »
Probably a silly question but did you square the ends of the grooves?
Offline overanalyze
Re:
« Reply #7 on: August 02, 2013, 06:24 PM »
Yep. Used a 3/8" bit to route the groove and then a quick cleanup with the trion. Hit everything with a quick 1/8" roundover and a sander.
Offline JerrySats
« Reply #8 on: August 02, 2013, 07:18 PM »
Nice job on that table .  Do you have pics of the jig you made ?   What's the width of the braces ?  Thanks
Offline overanalyze
« Reply #9 on: August 03, 2013, 12:33 AM »
Here's the jig. Quick and dirty, but it worked well. I had 5-10 minutes in building it and used scrap from the shop.
Offline waltwood
« Reply #10 on: August 03, 2013, 06:29 PM »
This is great! I have been trying to come up with an idea for a cutting table for 2 days and none of them suited me and a couple others I saw on this site I did not really like. This one is perfect for me.  I might get a friend with a CNC machine to cut one out for me because it does those joints with no slop at all and I don't want to dissemble mine. Thanks.
Offline overanalyze
« Reply #11 on: August 03, 2013, 09:55 PM »
Thanks a lot! If you don't want to break it down, then just use some pocket screws to hold it all tight. I will also put a sheet of Dow down first and then put on my sheet goods to get premium dust collection and prevent scratching if it's pre-finished goods.
Offline waltwood
« Reply #12 on: August 04, 2013, 04:59 PM »
By Dow you mean the foamboard? How does that hold up to the saw kerfs. The ply I am cutting is $70 a sheet so scratching it is an issue. Up to now I have been sawing on 2 x 4's across horses and I always have to re-position them according to what cut I am making and with your table it looks like any cut on a 4 x 8 sheet would not pinch the blade or fall in the floor.
Offline overanalyze
Re: Re: Re: Cutting/work table
« Reply #13 on: August 04, 2013, 05:48 PM »
Exactly why I built it. No pinch points and no moving the sheet around. The Dow is the pink or blue or green Styrofoam.  The white stuff isn't a good idea (it low density). If your blade is set correct, one sheet last a while.
Offline JerrySats
« Reply #14 on: August 12, 2013, 10:52 PM »
Thanks for sharing your table , I'm real happy how mine turned out .  I gotta say this thing is strong as can be .
Offline fshanno
« Reply #15 on: August 13, 2013, 01:35 AM »
Do I see the the granite top Ridged table saw in the background?  Mine was recalled and since I was too far to have a technician come to me I had them come pick it up.  I really liked that saw.
Offline overanalyze
« Reply #16 on: August 13, 2013, 07:08 AM »
Wow! That was fast! Glad you like it. Its crazy how much weight it can hold.
Offline JerrySats
« Reply #17 on: August 13, 2013, 01:05 PM »
Good eye there. Yes your right I added the incra fence systen to it.
Offline JerrySats
« Reply #18 on: August 13, 2013, 01:08 PM »
I thought yhere would be some wobble to it but its rock solid. I did wax the sides and that hepls taking it apart.
« Reply #19 on: August 13, 2013, 11:26 PM »
Your opinion ...would this table be good for portable jobsite table? Looks like when disassembled it could be fairly compact? Do you think daily set up & break down would create slop in joints?
Offline atlr
Re:
« Reply #20 on: August 14, 2013, 06:48 AM »
Could adding UHMW Polyethylene Rubber Adhesive Tape to the the slots (resized for the tape) be helpful for  set-up/breakdown durability?
...Do you think daily set up & break down would create slop in joints?
Offline overanalyze
« Reply #21 on: August 14, 2013, 07:58 AM »
I built this table to be brought to the job. It breaks down and lays flat. I think the table it cheap enough to build if I am wearing out the slots, then it has made me enough money to build another one!
Offline John_
« Reply #22 on: August 14, 2013, 11:05 AM »
Here is another way to do it - using  2 x 4's
These are the Dewalt Saw horses that can be found at Lowes or Home Depot.  They are height adjustable and have two notches at the top to hold the two main 2 x 4's in place.
91116-0
Offline JerrySats
« Reply #23 on: August 14, 2013, 02:50 PM »
John I like that setup.  I made mine to use on jobsites. Wax sure helped me to get it apart easier.
« Reply #24 on: August 14, 2013, 11:14 PM »
good point...if they wear out ,it means your working making $$
Offline LM
« Reply #25 on: August 22, 2013, 03:32 PM »
Nice table how big are the sections? What's the overlap?
Regards
Leigh
Offline JerrySats
« Reply #26 on: August 27, 2013, 08:54 PM »
I thought there would be some wobble to it but its rock solid. I did wax the sides and that hepls taking it apart.
Regards
Leigh
I used 2 - 4x8 sheets of plywood . It works out to be right about 16" and half of that for the overlap . The ends you can make what ever height you want , mine are 37" to match all the tops in my shop .  I just layed everything out on 4x8 sheet of white hardboard . Then transferred all my measurements over to the actual plywood I was using .
Offline jeep jake
« Reply #27 on: August 28, 2013, 11:05 AM »
That's slick. How ment sheets of plywood did it take? Did you do all the half laps and slots with a router?
Offline Bhend18
    • Hendricks Construction
« Reply #28 on: August 28, 2013, 04:29 PM »
What do you use the holes for?
Domino DF 500, CT 36 E, Boom Arm Set, CT MIDI, OF 1400, LR 32, FS 2424/2-LR 32, FS 1400/2 LR32, TS 55 REQ, TS 75 EQ, HKC 55 EB, FS 800, FS 1080, FS 1900, FS 3000, FSK 250, FSK 420, Parallel Guide Set, MFT/3, Kapex KS 120, Kapex UG, CXS, PDC 18/4, Drilling Dust Nozzle, CMS-GE, Carvex PS 420 EBQ, Pro 5 LTD,RO 90 DX, RO 150 FEQ, RTS 400 REQ, RS 2 E, LS 130 EQ, RAS 115 E, HL 850 E-F Plus, MX 1200 E EF, CT Wings, Vecturo OS 400, SysLite KAL-2, SYSRock
Offline overanalyze
« Reply #29 on: August 28, 2013, 07:03 PM »
I used a router and a quick jig to make sure all pieces were interchangeable.
Offline overanalyze
« Reply #30 on: August 28, 2013, 07:03 PM »
So you can clamp material to the table.
Offline JerrySats
« Reply #31 on: August 28, 2013, 08:12 PM »
I did the same thing , made a jig for my router . I used 2 sheets of 3/4 ply .
Offline Joel Harry
« Reply #32 on: September 02, 2013, 01:33 AM »
As far as portable workbenches go, you guys might want to check out the "Ultimate Workbench" from Ron Paulk. You can order a very nice/detailed set of plans from him for a reasonable price ($10). plans. It's a nice cutting surface also using some sacrificial strips.
Offline evilcat
« Reply #33 on: February 25, 2014, 08:55 AM »
Looks good. How sturdy is the table in terms of side or end loads? Does it want to fold much?
Offline JerrySats
« Reply #34 on: February 27, 2014, 05:28 PM »
The table design is solid as a rock. Theres no movement in any direction. The joints are what makes this so solid , keep them tight with no slop and you'll be fine . To help it go together easier , just wax the joints up with furniture wax .
I shouldn't post from my phone with my fat fingers !!
« Last Edit: February 27, 2014, 09:04 PM by JerrySats »
Offline overanalyze
« Reply #35 on: February 27, 2014, 09:53 PM »
My lap joints are a touch bit loose. I do not have very much play or sway in the setup. I have had ours at our current job for the last few weeks and it has been great. We keep a piece of 1" Dow on it now to cut on for better dust collection. Also, like any flat surface on a job, it makes a great work table in general. We also had a large project to do that required us to site cut a bunch of ACM panels. This was perfect to break down, transport, and use on the road.
Offline overanalyze
« Reply #36 on: April 04, 2014, 05:27 PM »
I had a want/need for a smaller table. I just realized that by making all my components universal as far as the location of the half laps I can use 2 of the 4' cross members and the legs and make a smaller 4x4 table. Now for an MFT top for it...
Offline overanalyze
Re:
« Reply #37 on: April 10, 2014, 08:50 PM »
Hey guys, I drew up a set of detailed plans and instructions for my cutting table. I am charging a small fee. If anyone is interested,  PM me for details. Thanks!
Offline overanalyze
« Reply #38 on: April 13, 2014, 10:27 PM »
Here is the model of my lastest addition to this design. I am working on an add on mft style top for my small version of this table.
« Reply #39 on: April 15, 2014, 12:34 AM »
I like your choice to keep table parts universal... My friend and I both agree that this design makes a great jobsite cut table..however, we are coming up with ideas on how to make the table base collapsible or stacking all the parts for easy transport. Basically trying to fold up the parts together.
Offline overanalyze
« Reply #40 on: April 15, 2014, 08:08 AM »
Very cool! I can't wait to see what you come up with!
Offline overanalyze
« Reply #41 on: May 01, 2014, 01:45 PM »
I know a guy with a cnc. He made me a 4'x4' mft top for my small version of my table. This should be perfect to take on site. I am deciding how I want to attach the top.
Offline Domino
« Reply #42 on: May 12, 2014, 04:16 PM »
I wanted to build an transportable workbench for months now. I've seen a lot of designs, but most were too heavy, too big after breaking it down.
But this...
THIS IS GENIUS!
I love how you can build a small table with the same parts!
I'm definitely going to build this!
CXS; TS 55 R; Rotex RO 90; OF 1010; BHC 18; CTL Midi, Kapex KS 120 R, Domino DF 500.
Offline overanalyze
« Reply #43 on: May 12, 2014, 06:52 PM »
Definitely glad people are liking the table. I have ours on site right now building a custom fireplace surround and for a kitchen remodel. We also used it last week as a material support table and work surface cutting a bunch of exterior trim.
Offline realpdm
« Reply #44 on: September 25, 2014, 04:22 PM »
I just completed mine based on the plans. Thank you for providing those. This is going to really make life easier cutting down plywood in my limited space.
Anyone else built this and put a finish on it? Seems like it would help keep it survive many assemblies and disassemblies.
Offline overanalyze
« Reply #45 on: September 25, 2014, 08:22 PM »
Nice job!!
Offline wow
  • Inactive Member
« Reply #46 on: September 25, 2014, 09:22 PM »
So I have to ask...
what did you do with the circle cut-out? There has to be a GREAT use for it.
« Reply #47 on: September 25, 2014, 09:41 PM »
 Getting ready to build this table also.
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #48 on: September 26, 2014, 08:06 AM »
I made this one. The joints are left a little loose so it is easier to assemble in the field.
Offline Wooden Skye
« Reply #49 on: September 26, 2014, 08:49 AM »
That is a great cutting table.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino ETS 150/3, RO 90, CT 26, OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline mike_aa
« Reply #50 on: September 26, 2014, 10:21 AM »
+1!
How are the feet attached?
Offline wow
  • Inactive Member
« Reply #51 on: September 26, 2014, 10:39 AM »
Tom:
Love the guide rail storage!!! I am SOOOooo stealing that idea!
Do the looser joints cause any issues, like table wobbling or whatever? Or asked another way - would you build it the same way (loose joints) if you made another one?
BTW, thanks for posting that. I'm sure you will inspire many others to finally build a table...
Online elfick
« Reply #52 on: September 26, 2014, 10:53 AM »
Are the feet HDPE?
Offline GOT8SPD
« Reply #53 on: September 26, 2014, 11:26 AM »
I think they're speed holes.  I've seen them on Honda Civics and stuff  [big grin]
JK...cool design!
« Reply #54 on: October 02, 2014, 08:31 PM »
Just got done building mine.
 Scott G.
« Reply #55 on: October 02, 2014, 08:49 PM »
I laid out the half laps and cut them with a jig saw (trion). The end of the notch I made a block of wood so I could plunge down square with the oscillating saw. Turned out strong.
 Scott G.
Offline overanalyze
« Reply #56 on: October 02, 2014, 08:59 PM »
Turned out great Scott!
Offline tjbnwi
« Reply #57 on: October 02, 2014, 09:55 PM »
I did not see the questions until now. Sorry for the delay.
Bryan, thanks for the compliment. I appreciate it.
The feet are HDPE, I chose the product for the feet because I plan to use this as an easy to transport field table. No qualms about setting it up in a dew soaked lawn this time of year. They are attached with 2- 5 mm Dominos in each of the feet.
Over, it does wobble slightly. The ease of assembly and disassembly make it worth the slight wobble. I wouldn't hand plane on it but every other operation the table has performed very well.
A side benefit of the height of the stretchers is my clamps work with them.
Offline jmac80
« Reply #58 on: December 08, 2015, 11:05 AM »
Thanks for that idea @John_
We have the exact same saw horses here in the Uk but they are branded "stanley fatmax" or were till i took the sticker off  ;D
Also had to shave the 4"x2" to fit in the recess on the saw horse, UK 4x2 are bigger than USA ones I believe!
Quick and nasty effort i made this morning but will do the trick for me just fine... SO much better than doing it on the ground.
« Last Edit: December 08, 2015, 01:25 PM by jmac80 »
James
Offline joiner1970
« Reply #59 on: December 08, 2015, 11:12 AM »
(Attachment Link)
If you ever want some more sturdy stools for that let me know. I've got a pair of hardly used Toughbuilt ones. They're metal but have that same 4x2 hook on the ends. I'm looking to sell them as I bought the dewalt horses.
Offline jmac80
« Reply #60 on: December 08, 2015, 11:20 AM »
Thanks @joiner1970
I did look at them but decided i didn't really need them.
This is actually extremely sturdy  [big grin]
James
Offline joiner1970
« Reply #61 on: December 08, 2015, 11:26 AM »
I'd take £50 for them if you change your mind. Theyre almost like new as I haven't really used them. I was buying the dewalt ones and saw these half the price of the dewalt ones. Then ended up buying the dewalt anyway.
Offline jmac80
« Reply #62 on: December 08, 2015, 11:46 AM »
@joiner1970
what model are they?
James
Offline joiner1970
« Reply #63 on: December 08, 2015, 12:09 PM »
These
£45 each in toolstation
Offline jmac80
« Reply #64 on: December 08, 2015, 12:24 PM »
Thanks for the pic @joiner1970 .
To be honest I really don't need them as I'm quite happy with the Stanley/DeWalt ones.
Bang them in the classifieds? or maybe UKW classifieds if your on there?
Cheers
James
Offline joiner1970
« Reply #65 on: December 08, 2015, 12:33 PM »
Yeah they're on the ukw, but I'm not pushing to sell them they're just sitting in my workshop and if someone wants them they're gone. :)
I've got a few things to sell , a job for the new year :)
Offline jmac80
« Reply #66 on: December 08, 2015, 01:24 PM »
@joiner1970 Pm me other items your selling lol   [big grin] [scared] [big grin]
James
Offline overanalyze
« Reply #67 on: July 15, 2017, 05:26 PM »
We still use this table a ton for shop work and on site fabrication. I have started to call it my VFT table (VariableFunctionTable). Thanks again to all my FOG friends who have bought the plans and let me know how they liked it!
Having a 4x4 MFT style top has been awesome too.
Sent from my SM-G920V using Tapatalk
Offline BasZor
« Reply #68 on: September 07, 2017, 01:43 PM »
Thanks for the inspiration!
Build a smaller variant of the table with scrap wood lying around.
Also functions nice as a base for the DIY table saw / working area!
building the saw table
« Last Edit: September 07, 2017, 02:28 PM by BasZor »
Offline overanalyze
« Reply #69 on: September 08, 2017, 06:50 AM »
Nice! Glad you found it useful!
Offline kevreh
« Reply #70 on: December 19, 2017, 10:32 AM »
I like the 2x4 approach since I just don't have too much room in my shop for the larger size supports shown in the beginning of this thread. One improvement I might make is to glue up 3/4" baltic birch or regular plywood to get 1.5" thickness to sit in those sawhorses. Or maybe order LVL 2x4's. Saw them recently on This Old House. Wonder if LVLs or plywood wood be more rigid and stable vs regular pine 2x4s. ?
Offline cuddysteph
« Reply #71 on: August 24, 2018, 11:02 AM »
does anyone got plan for this work table small model and long ? please  i need  to do my stair and i have nothing working
