Author Topic: MFT 3 ideas for small shop  (Read 29508 times)
Offline TheSergeant
Re: MFT 3 ideas for small shop
« Reply #30 on: March 24, 2018, 02:11 PM »
THese are some great mods. The fact that they're necessary really frustrates me.  I've owned 3 MFTS, which all gone now, as I made an MFTC that is much, much better.  These mods also really highlight the major issues with the MFT3 and the need for a major redesign/upgrade.  $720 for something that you have to modify the heck out of is crazy.   I'm tempted to go off on a rant here but won't.
Excellent work OP for adapting the system to suite your needs.
« Last Edit: March 24, 2018, 02:13 PM by TheSergeant »
Offline Mgildersleeve
« Reply #31 on: March 24, 2018, 06:19 PM »
A great upgrade.  Nice work.
« Reply #32 on: March 25, 2018, 08:18 AM »
@TheSergeant   What mods do you think are necessary?
The MFT is a portable work table that facilitates using the tracksaw at a job site. No modifications are required for that.
Did you expect to use the MFT for a different purpose?
Offline cubevandude
« Reply #33 on: March 25, 2018, 01:11 PM »
I really like this idea.  I do not have the Festool hinge for the track as I have a Makita.  Does anyone have an idea how to make a hinge to work with this if they do not have the Festool setup as shown?
I spent a little time on 8020 working up a hinge with a plate. After using the Festool plate and hinge I never ordered anything. You might consider ordering the parts from Festool parts catalogue.  I can’t seem to copy the link from my iPad but google Ekat Festool.  Lookunder Workplace organization then MFT3.
Do you think something like this would work?  15 Series Universal Standard Structural Pivot
https://8020.net/shop/4356.html
I see your pieces are 10 series though.
Offline Hal M
« Reply #34 on: March 25, 2018, 01:16 PM »
I am happy to reach out to my 8020 salesman and ask him for an idea for the hinge if you would like this week.  I used the 10 series because I was trying to minimize space.
Offline cubevandude
« Reply #35 on: March 25, 2018, 01:30 PM »
I would appreciate that.  I do see these are available in 10 series also.  A plate on the top with a way to attach the track and it might work.
10 Series Universal Structural Pivot Nub, Part Number: 4186
10 Series “L” Structural Pivot Arm, Part Number: 4149
Here it is assembled:
10 Series Universal Standard Structural Pivot, Part Number: 4156
https://8020.net/4156.html
« Last Edit: March 25, 2018, 01:56 PM by cubevandude »
Offline Sean KS
« Reply #36 on: March 25, 2018, 10:41 PM »
I think this pivot would be an option as well.
https://8020.net/shop/14011.html
It would allow you to attach and hinge the Festool rail without any further modifications.
The one thing I don’t know is the height from the top of the linear bearing to the top of the MFT. The pivot I’m recommending  could be too tall. Not sure, and I don’t have an actual MFT to check? It’s just shy of 2in tall when the Festool rail is lowered for a cut.
« Last Edit: March 25, 2018, 10:46 PM by Sean KS »
Offline Hal M
« Reply #37 on: March 26, 2018, 06:58 AM »
I actually considered that hinge.  My concern was getting more than one connection to the rail so it had a better chance of keeping the rail square. I also thought the wider profile would help it stay square in the vertical plane in the bearing. After using it for a while it may make no difference. I will ask my sales rep today if he is working.
Offline Jig
« Reply #38 on: November 27, 2018, 05:28 PM »
Hal M:  Thanks for thinking this up as I am ready for this modification to my MFT table.  I had forgotten just where this tread was and looked for ever!  You can only imagine my frustration of searching the FOG high and low..........!!
Thanks for sharing all your efforts! 8)
Jig
Offline John1102
« Reply #39 on: November 27, 2018, 06:12 PM »
Great idea!  8020 parts are great!
Offline tmm286
« Reply #40 on: November 29, 2018, 12:03 AM »
If you have the CNC file you should Contact the guys at Vonmod - http://vonmod.com/ .  They have a huge CNC for a modest fee I'm sure they would crank one our for you in a material of your choosing.
I work for a GC in Denver and contract them frequently for custom work.  I recently picked up an MFT and it's already my plan to ask them to make me a new top when mine wears out as I don't feel it's worth my time to do it myself.
Offline cubevandude
« Reply #41 on: November 29, 2018, 08:31 AM »
I was wondering if anyone has made this out of the 8020 aluminum instead of using the festool hinge?  I ended up going with the UJK Technology Dog Rail Clips and Veritas SS Parf dogs for my Makita saw and Slab top.
I don't have any easy access to 8020.
« Last Edit: November 29, 2018, 08:35 AM by cubevandude »
Offline Grev
« Reply #42 on: November 29, 2018, 08:33 AM »
This has been covered in other posts .. but just in case you don't have the .dxf files, you can get them via TSO Products for free.  TSO offers files for several different sizes of tops, while Seneca woodworking only has the MFT3 replacement top file.  Good luck.
Seneca woodworking MFT file
TSO Products MFT files
Offline tmm286
« Reply #43 on: December 16, 2018, 06:40 PM »
Thank you!  ;D I assumed they were floating around.  Appreciate the link though!  My current MFT top is taking a beating at the moment.  Still got the whole other side though.
Offline simonh
  • Hobbyist / Maker of the VCS-R
« Reply #44 on: December 17, 2018, 03:28 AM »
That's pretty slick use of the 80/20 stuff.
-Simon
Offline thedevme
« Reply #45 on: January 18, 2019, 12:38 PM »
Great ideas!  Do you have part numbers or a link to the 80/20 linear unit you used?
The 8020 parts were:
Linear bearing 6424 (it came with several shims, maybe 20+. I used 4).
https://8020.net/6424.html
Extrusion 1020 - cut to 9”
https://8020.net/1020.html
I bought a couple of T-nuts. 25-3382
https://8020.net/25-3382.html
I used a couple of 1/4-20 carriage bolts that I filed down to use to attach the linear bearing to the table with a couple of hex nuts. I need to order a T-nut and and maybe a couple of socket cap bolts to replace them. Would make it easier to remove the linear bearing from the table. I couldn’t find anything better locally.
Hope that helps.
@Hal M  First of all, thank you for sharing how you built it.  I was curious if you ever updated this with the T-nut and socket cap bolts?  If so would you mind sharing how you did it and possible show a pic.
Offline Hal M
« Reply #46 on: January 18, 2019, 09:45 PM »
Actually I never ended up changing it. I have not taken the bearing off very often. I had actually forgotten that I was going to change them.
Offline dlu
« Reply #47 on: January 19, 2019, 12:09 AM »
Part numbers for the Festool MFT rail hinge and front support and the MFT frame profiles, in case anybody is looking:
  • 497022 Support - front rail support
  • 497023 Support unit - rear rail support and hinge
  • 472862 Profile - MFT short (side) extrusion
  • 472862 Profile - MFT long (front and back) extrusion
« Last Edit: January 19, 2019, 01:52 AM by dlu@canishe.com »
Offline thedevme
« Reply #48 on: January 19, 2019, 12:44 AM »
Part numbers for the MFT rail supports and profiles, in case anybody is looking:
You mean in addition to the ones from 8020?
Offline dlu
« Reply #49 on: January 19, 2019, 01:53 AM »
Yes - those are the Festool numbers for the hinge and front support for cross cutting on an MFT.
Offline thedevme
« Reply #50 on: January 25, 2019, 05:59 PM »
@Hal M Thank you I got my parts and implemented with no issues even used socket cap bolts instead to make it easier to remove from the MFT table.
Offline Jack01
« Reply #51 on: February 01, 2019, 09:40 PM »
Hal
Great project, Impressive.
I'm not familiar with 80/20 are they comparable to MFT side tracks( T channels) ?
Can I buy the 2 Guide Rail support from festool and use it on 80/20 tracks.?
Offline Jack01
« Reply #52 on: March 27, 2019, 10:57 AM »
Did you get in touch with Vonmod ?
I am also interested in getting MFT top .
Offline Hal M
« Reply #53 on: March 28, 2019, 03:31 AM »
Hal
By comparable, they are very sturdy and straight. They channels do not line up exactly but I have seen online where people make there own mft tables using 8020 extrusions. You can about build anything with them.
I am sure you can buy the guide support pieces from Festool.
Good luck.
« Last Edit: April 19, 2019, 10:13 AM by Hal M »
Offline koenbro
« Reply #54 on: March 29, 2019, 12:00 AM »
Brilliant ideas, thank you. I have just ordered the 8020 parts to make my own.
MFT/3 • TS 55 REQ • Carvex PS420 EBQ + Accessories • OF1400 + LR32 + MFS400 • Domino DF500 • AvidProCNC 24x48" • ETS EC150/5 EQplus • DTS 400 REQplus • CXS • CT 26E • Fuji Q4 + 3M PPS
Offline ChiknNutz
« Reply #55 on: August 13, 2019, 08:45 AM »
The 8020 stuff is great for the structure, another option for linear guides and related stuff is IGUS.  Similar to the 8020 guides, the IGUS drylin linear rails have no moving parts and are good for dirty environments. https://www.igus.com/drylin/linear-guide.  Just providing the info in case folks don't know about them.
-Chris
Rotex 150/5 FEQ, CT 36 E, ETS EC125/3, TS75, Domino XL
Offline promark747
« Reply #56 on: May 23, 2020, 09:37 PM »
Another shoutout to Hal M for the great idea.  I just did the same thing to my custom 80/20 MFT and it's awesome.
Offline Hal M
« Reply #57 on: May 24, 2020, 06:03 PM »
Thanks.
I did notice today that finally it seems to not slide up and down quite as easily as it used to. I think a tiny bit of dust got in it.  Pulled it out and blew it off and it’s back to just like new.
Hope it works out well for you.
Offline John Huh
    • Tidbits
« Reply #58 on: April 11, 2021, 12:24 PM »
I have a small 8’x12’ shop in a shed.  I have used the MFT3 and TS55 as my primary saw.  I keep dust down with a Pro5 sander, a Trion Jigsaw and Domino. The  Festool system has allowed me to have a relatively dustless efficient space.   I made some changes to the MFT3.  I use the MFT as my primary workspace and need to have a clean space on the table and keep as much space left in my shop.
First, I basically never use the protractor and wanted to both maximize my cutting space and keep the table pushed close to the back wall.  I ordered another fence clamp and use two clamps to hold the fence on the table.  I added a Kreg scale on the front, so I can use a flip stop for measurement. i set up using a carpenter’s square at exactly 12.5” on the flip stop of the fence and squaring up against some veritas dogs.  It squares the fence and gets it set for dimensioned for cutting.
Second, the current hinge mechanism was hard to open and lock from the front of the table. I got inspiration from Sean KS on this forum (thanks).  I replaced the Festool mechanism on the back of the table with a linear guide and a 1020 Extrusion from 8020. its not as pretty as his though. I attached it to the hinge plate for the guide rail.  I added a bolt to the 8020 so at its lowest the guide rail sets right at the fence height when lain flat.  With any wood piece against the fence the guide rail hinges moving the 8020 piece up, perfectly lying flat across the top of the piece to be cut. Most of what I use is ¾” but I have used it up to 2” and tested up to 3”.   It does not need to be locked at height and has no movement side to side riding along the bearing.
I can set up the table from completely clean times in 2.5 minutes.  Since it is new I have checked square and correct dimensions each time.  They both have been perfect each time. I can keep my table pushed back saving several inches and don’t have to lock the guide in place to cut. I can have a clean or set up table with very little effort.  It has been a game changer for me.
I tried the same thing with two fence clamps. It has a tendency to move slightly as it has a small gap. Was wondering if you have the same issue.
Offline Hal M
« Reply #59 on: April 11, 2021, 02:40 PM »
I made a post a while back on how I changed the back fence.  I was having issues with the back clamps not holding well enough.   He changes I made have worked great. I am copying the link.  I hope it works.
https://www.festoolownersgroup.com/festool-jigs-tool-enhancements/small-shop-new-mft-fence/msg609141/#msg609141
