Author Topic: Custom MFT/Table Saw Extension Table  (Read 54102 times)
Offline guyswoodshop
« on: July 01, 2013, 05:55 PM »
Hey Everyone! This is my first post the FOG. I guess I waited to post something until I had something that I felt could really contribute to the community. Anyhow, I started using Festool a little while ago, and always wanted an MFT/3 for working with sheet goods and also the clamping options as a general work surface. The problem was I didn’t want to have another work area taking up more valuable floor space when working. I know it’s been done before, but here is my take on the combination MFT/Table Saw Extension that I have seen a few others here make. The video explains quite a bit, however if you have any questions, please feel to ask.
« Last Edit: July 01, 2013, 06:04 PM by guyswoodshop »
Offline Alan m
Re: Custom MFT/Table Saw Extension Table
« Reply #1 on: July 01, 2013, 06:13 PM »
welcome to the fog.
great mft.
i like that fence
« Reply #2 on: July 01, 2013, 06:19 PM »
Thanks Alan. I have yet to use the fence for a project, however in testing it seems to appear solid and stable enough.
Offline erock
« Reply #3 on: July 01, 2013, 06:52 PM »
Guy,  Welcome!
I watched your video earlier today, before you posted it and was going to share it on the FOG.
I'm glad you posted it.   A lot of guys still use a table saw and I'm sure this will get some ideas flowing in some of those table saw users heads.
Nicely done.  I like the fact that the MFT can be used as a out feed table for you.   If I still had my table saw I would try to copy what you have done.
Please post more great ideas that you have!
Eric
« Reply #4 on: July 01, 2013, 07:14 PM »
Eric,
   I don't think I could ever give up my table saw. Other than the cabinet projects, I do build fine furniture. So I still feel I have a need for traditional power and hand tools. However I am finding ways with every project to use the TS 55 and guide rail systems in every project. And it will only get better for me with the MFT in my arsenal.
   Cleveland, Oh. Huh? I grew up there and moved to Indianapolis about 13 years ago. There are some things I really miss about that city.
Offline NERemodeling
    • New England Remodeling, LLC
« Reply #5 on: July 01, 2013, 08:34 PM »
Guy, First off let me say  [welcome] to FOG
Glad you became a member!  with ideas like that you will be no doubt be able to contribute a lot and help many people.
Your MFT is great!!! It is obvious that you took your time and thought through all the details. Your reward, a very functional and durable workbench that you will get a lot of great use out of.
Thanks for posting!
John
CT26  -  (2) Midi  - Planex - Kapex -  Domino 500  -  Carvex  -  TS55EQ -  Rails; 800, 1080, 1400(holy rail), 1900, 3000 -  OF1400 - OF1010  - LR 32 - RO 150 - RO90 - RAS115 - ETS125 - DTS400 - LS130 -  EHL65 - HL850 -  MFT1080 - (2) MFT800
Offline neilc
« Reply #6 on: July 01, 2013, 09:11 PM »
Welcome to the FOG, Guy.  That's several good ideas in how you adapted an 'MFT-like' table to your saw with the guiderail and flexibility.
Is the frame open under the top for clamping, or did you do any kind of supports beyond the legs?
Thanks for sharing!
neil
« Reply #7 on: July 01, 2013, 09:59 PM »
Neil,
  The frame underneath the MFT top is almost completely open. The top sits on a frame, and then the rail attaches to the frame. The legs have pivot points all the way in the corners so they fold up underneath the table for storage. So I guess while not 100% clear underneath, only the outermost corners have a little restriction.
Offline erock
« Reply #8 on: July 01, 2013, 10:27 PM »
Eric,
HAHAHA!  I'm so glad you didn't have a Cleveland Browns shirt on when you made the video.....or else I would have sent you hate mail for days!
 [tongue]   [big grin]   [smile]   [tongue]
Eric
« Reply #9 on: July 14, 2013, 05:39 PM »
I’ve gotten some emails asking for the specifics and dimensions of the rail for my extension table. The T track is Incra, and can be used with the Festool clamps. The aluminum stock is ¾” by 1/8” thick. To make the stops for the rail positioning mechanisms, I used a slide from Incra that slides into the track, and then it tightens down using a cap screw. The pictures below show the assembled rail, and also the dimensions that everything fits in/on to.
90064-0
90066-1
Offline CarolinaNomad
« Reply #10 on: July 30, 2013, 06:14 PM »
Thanks for sharing!  I'm liking the idea of incorporating your design with Ron Paulks Workbench.
Jeff
resides in NAINA
Offline Crox G
« Reply #11 on: August 01, 2013, 10:14 PM »
Guy and this thread inspired me to make one of my own, and I shamelessly took his ideas:
90587-0
The sides are 2-bys, with grooves routed in the sides for Incra tracks, and the tracks mounted on the top perimeter to hold the top in place.  The top is a 1080 replacement, which is cheaper than an MFT/3 and about the same size.  The legs are 2-bys, ripped and glued up in an L-section to maximize the corner space underneath.  I fastened the legs to the sides with flat-head 5/16" machine screws in tee nuts.  I tapered the legs and chamfered the edges.  The levelers are 5/16" carriage bolts in tee nuts, which I find are easy to adjust with a small wrench. The frame seems to be plenty stiff and stable.  No braces under the top, yet.
90589-1
I have the table next to my table saw for use as an outfeed support. I decided not to groove it for the miter gage in order to preserve its strength.  I don't expect to use a cross-cut track, so I didn't provide for it.
Mistakes I confess:  (1) I didn't wait to have the top in hand before I made the table--I was too eager to get it done. I found out that the 1080 isn't exactly 28" x 43" or whatever the literature says.  As a result, I had to trim a bit in order to make it fit. Good news: clamps in the holes near the edge still have plenty of range of motion. (2) I didn't allow enough space for the countersunk screw heads. They come too close to the side tracks. (3) I didn't allow enough space for the tee nuts on the inside of the legs. They fit, but just barely.
Quas dogs are on the way from Bob Marino.  Can't wait!
What a difference between this and the holey homemade rig I've been using.  Thanks, Guy!
Crox
« Last Edit: August 01, 2013, 10:22 PM by Crox G »
CT Midi, ETS 150/3, OF 1400, TS 55, CXS, RO 90, MF-TB, Syslite, necktie, T18 + 3, Carvex PSC 420 EB, Ti15, Domino XL 700, Vecturo
« Reply #12 on: August 09, 2013, 07:22 AM »
Looks great Crox! I thought about attaching mine horizontally also. It just worked out better for me and my needs doing mine the way I did.
Offline gbsnplr
« Reply #13 on: April 15, 2015, 07:30 AM »
(Attachment Link)
(Attachment Link)
The drawing for the rail is gone any chance you can upload the drawing again?
« Reply #14 on: April 15, 2015, 05:47 PM »
I don't know how that happened. Anyhow, here it is again. Let me know if you have any questions..
Guy
Offline gbsnplr
« Reply #15 on: April 16, 2015, 08:08 AM »
Thank you :)
Offline Mr Heavy
  • Clamps? Who needs clamps?
« Reply #16 on: May 01, 2015, 07:21 PM »
^^^^  +1
Nicely done project.
Sys4 with cheese sandwich, a small pork pie with Tabasco sauce, a nice bottle of dry, vintage Prosecco and three reusable ice packs. Olives with pimento and a capon, roast in Dijon mustard. Several slices of fresh pineapple, a scale model of the Eiffel tower made from noodles, black forest gateau and a gingham table cloth for the MFT-3. A block of Parmesan and a Stanley 2" chisel for grating.
Sys3 with a half bottle of La Fée Absinthe, a spoon and vodka-soaked mint with Rothenberger blow-torch.
125 year old balsamic vinegar in spray bottle.
Ibuprofen and a pair of handcuffs. 2 loaves, 5 (very) small fishes, some bread, broken. A goblet of blood-red wine, a hammer... nails
Offline 6u892
« Reply #17 on: November 12, 2017, 09:13 AM »
I'm impressed with your DIY MFT design.  My intention is to copy your idea for my shop.  Now that you've had it for a few years, how is it working?  Anything that you would do different?
Offline whgmkeller
« Reply #18 on: July 17, 2018, 09:00 AM »
Hi there. I've got no idea if this topic is still followed by people, or maybe I should better ask my question in a new topic?
I'm building a custom workbench, 1 x 2 meters wide by 90cm high. Half of the top will be solid wood, the other half will be in mft/3 style. I want rails on the sides of the mft/3 half, and I'm considering possibilities:
- buy original Festool mft/3 rails and cut them to desired length;
- make (or order) custom rails like Guy has done.
The design drawing that Guy has shown is in inches and I live in Netherlands where we use cm's, mm's, and so on. I am wondering how exact the measures need to be?
For example:
3/4 inch = 19mm sounds like something I can have made, but...
1/8 inch = 3,175 mm is probably too exact.
Is there a tolerance?
Cheers,
Willem
« Last Edit: July 17, 2018, 09:58 AM by whgmkeller »
Offline nicholam77
« Reply #20 on: April 02, 2020, 11:56 AM »
Hey Guy, love your MFT implementation, I'm planning to replicate. I don't have the Festool guide rail supports in hand yet -- could you tell me the height/width of the aluminum flat bar you used? I know you said it was 1/8" thick but just wondering the other dimension. Thanks!
CT15 | ETS 125 REQ
