Author Topic: Construction of Homemade Work Centre  (Read 31031 times)
Offline jonny round boy
« on: March 11, 2011, 02:18 PM »
Further to my post in Paul's excellent WCR 1000 review thread, this thread documents the build of my own version of a vac-based work centre.
Firstly, this idea came directly from Paul's review, and the fact that he's mounted his on the systainer 'platform'. I would like to take full credit, but I can't I'm afraid. It's a blatant rip off of Festool's design, and Paul's input. [embarassed]
I drew an outline design in SketchUp to get the general dimensions. I'll be mounting this on a CT26, with a sys2. With the work centre on top, access to the systainer is limited slightly, but this systainer is used purely to store spare bags for the CT so that's not an issue (since the work centre would have to be removed to change the bag anyway). Based on the height of this combo, I decided to make my WCR at 600mm high:
33916-0
33918-1
33920-2
I decided to use 18mm WBP ply for the construction. It's lighter, stronger and takes paint better than MDF, and I had plenty of offcuts I could use!
The construction is very simple. First, I had to make the end pieces. I wanted a nice curve on them, and I wanted them to be identical, so firstly I made a template. I printed the shape of the curve from SketchUp at 1:1 scale, and used photo-mount spray to fix them to a piece of 9mm MDF for the template:
33922-3
The straight cuts were done with my TS55, and the curves roughed out with my jigsaw before being sanded smooth & to the line:
33924-4
I then used the template to draw out the sides & rough cut them with the jigsaw:
33926-5
before screwing the template to each side in turn:
33928-6
and trimming them with a bearing guided bit in my router table:
33930-7
The pieces for the bottom and the vertical section were cut to size, and the timber trim fixed to the bottom board, then the assembly was glued & screwed together. The vertical section is not centered on the uprights - it's flush at one side.
Then the small shelf was added & trimmed, along with the top. Then all the screw holes were filled, and the whole thing sanded ready for painting:
33932-8
33934-9
It was then painted in the same way as my Kapex Stand, which is painted with emulsion paint (straight onto the bare ply) then finished with a single coat of water-based varnish. When I did this on the Kapex stand I wondered how resilient it would be, and I was happy with the result. It's a lot easier than priming/undercoating then overpainting with oil-based eggshell, especially when it comes to clean-up!
I had some non-slip rubber matting that I bought long ago (designed for holding pieces to a bench whilst routing & sanding) so I cut a piece to fit on the bottom, and one for the top shelf. These were glued in place with a spray adhesive:
33936-10
I also added some small cheap screw-in hooks to the 'flush' side of the vertical divide for holding sanding disks.
The main 'add-on' I wanted to copy from the Festool design was the large hose/tool hook on the front end( the hose on my CT26 is the main thing that gets in the way in my small workshop!). It is available as a separate part (497474) and it would screw directly to the upright, but I couldn't justify spending that amount of money on a piece of wire (!) so I decided to try to make my own.
I bought a length of 5mm diameter steel rod from a DIY shed, and then set about trying to bend it where I wanted it to bend - not as easy as it sounds! I didn't really plan what I was going to do with it too carefully, I just sort of made it up as I went along. I made a small jig to help with the bending process:
33938-11
Initially, I wanted to bend both of the 'legs' to the centre, in order to mount it to the upright (as per my original SketchUp model). About half-way through the process however, I realised it would be far easier to mount it to the sides of the top shelf so the rod was bent double, and screwed on with four M6x50mm coach screws into 5mm pilot holes:
33940-12
This front 'hook' is perfect for holding the sanders, and also works as a 'handle' to guide the vac around:
33942-13
Here's some more pics of the finished article:
33944-14
33946-15
33948-16
33950-17
This design isn't as 'adaptable' as Festool's, but for the cost (virtually nothing) it's fine. I haven't added all the hooks, baskets, extra shelves etc. that I envisaged at first; I decided I'd leave it quite bare and add bits to it over time, thus the design will 'evolve' in a more natural way. Plus I won't have to try & guess where I might want things in the future!
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - PDC18/4 drill - PSC420 jigsaw - OFK500 trimmer
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
Re: Construction of Homemade Work Centre
« Reply #1 on: March 11, 2011, 02:25 PM »
Bravo! [thumbs up]  Now let's see that shake test. [tongue]
« Reply #2 on: March 11, 2011, 02:49 PM »
I think I'll pass on that one [eek]
Same with wrestling it to the ground - I don't have the hockey gear (though I am blessed with natural padding!).
Offline justinmcf
  • Queensland Builder
« Reply #3 on: March 11, 2011, 04:51 PM »
beautiful job jonny.
i hope you dont mind me ripping off your design!
looks like i will be busy today......
justin.
Offline Scott Rollins
« Reply #4 on: March 11, 2011, 07:51 PM »
What is the black sleeve on the vac hose?  I would love something like that!  BTW very nice work.  I might "borrow" some ideas!
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
« Reply #5 on: March 11, 2011, 08:28 PM »
looks great and very useful. I like the cost compared  to the real workcenter [big grin]
Greg Powers
Offline Holzhacker
    • www.aic-chicago.com
« Reply #6 on: March 11, 2011, 09:00 PM »
Very nice. So do I buy a WCR or copy yours? If only there were more hours in the day.
Actually though my wife keeps threatening to buy me a WCR, she thinks it come out in June. I don't feel comfortable with her buying me tools. She feels the WCR is the Festool version of the Barbie playhouse.
« Last Edit: March 11, 2011, 09:02 PM by Holzhacker »
Offline LostInTheWood
« Reply #7 on: March 11, 2011, 09:20 PM »
Where's the cup holder?   [poke]   [big grin]
Offline rookie08
« Reply #8 on: March 11, 2011, 09:41 PM »
Nicely done! [thumbs up]
In the link to your kapex stand I saw you have an mft top on your blue framed bench in the background.  Is the top 2 mdf replacement tops placed next to each other? Or, did you drill your own?
I want to build my own in mft shop assembly table but want it square 1200x1200 - 48" by 48" so I'd need to construct my own mdf table top but I still want the 96 on center 20 mm holes so I can use the qwas dogs and clamps.
any advice would be welcome!
Thanks!
« Reply #9 on: March 12, 2011, 06:48 AM »
Scott,
It's an expandable polyester sleeving that carries the hose and a plug-it cord. The ends are sealed with adhesive-lined heatshrink tubing. I did the same with the hose in my mini when I bought that, about 4 1/2 years ago, and it's still holding up (if a little tatty in places!).
« Last Edit: March 12, 2011, 02:17 PM by jonny round boy »
« Reply #10 on: March 12, 2011, 06:58 AM »
Don't worry, I made sure the top shelf was wide enough to hold my 'Top Gear' mug...
34024-0
« Reply #11 on: March 12, 2011, 07:03 AM »
Thanks!
Rookie,
I cut the top myself. I used a Festool top (actually half of an MFT1080 top) as a template, then routered it. The process is detailed in this post.
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #12 on: March 12, 2011, 10:01 AM »
[big grin]
She has a point there.
I'll wager that most everyone who buys the WCR is going to build a few customizations for it.  I'm already thinking in that line.
I like to have 'mini kits' of related stuff.  For instance, I'll probably make a little box to hold the domino cutters and wrench and another for the OF1400 collets, wrench, etc.
Offline Frank Pellow
  • Toronto, Ontario and Lake Pivabiska, Ontario
« Reply #13 on: March 12, 2011, 10:33 AM »
It looks really good Jonny!  Thank for the idea and for the construction detail photos.
I know that, if I were to purchase a WCR from Festool, that I would make lots of mods and enhancements to it.
So, when I get around to it, I will probably do as you have done, and start off with a clean slate and simply build a WCR that exactly meets my needs.
Cheers,
               Frank (Festool connoisseur)
Offline woodguy7
« Reply #14 on: March 12, 2011, 11:28 AM »
Hey Jonny, thats pretty cool.  I Wonder if Shane will remove this thread as Festool will probably lose out on a few sales due to this  [poke] [bite tongue]  Just joking.
Does the sleeve on the hose help with it not catching on stuff ?  With regards to the heat shrink sleeve on the ends, how is it applied ?  I have never tried it.  I do have a Makita heat gunn, would this be of use & do you have a link to the sleeve.  I think i will order some for my 3 Festool hoses.
Cheers Jonny.
Shirt size medium
Offline rookie08
« Reply #15 on: March 12, 2011, 12:05 PM »
Thanks for the link Jonny! [big grin]
« Reply #16 on: March 12, 2011, 02:26 PM »
Cheers Jonny.
The sleeving does help with stopping the hose catching, but if the edge you're dragging it over is really sharp then the braiding will catch. The heatshrink was some I had left over from the first one I did, so I don't have a link for it. You have to heat it with a heat gun, but the problem is that both the hose and the braiding melt really, really easily. You have to be VERY careful.
The old one is fine, but this last one I ended up melting the hose slightly at one end. It didn't melt completely, but it does look pretty bad:
34109-0
Oooops... [eek]
« Reply #17 on: March 12, 2011, 02:29 PM »
Well, if you're going to screw up and melt the hose you did it a good place.  You can easily cut it off and you won't lose too much.
« Reply #18 on: March 12, 2011, 02:37 PM »
Brice, I don't need to cut it off - although it looks bad it's still physically intact (it didn't melt through) so works fine. If I did cut it off, I'd then have to shorten the braid & re-seal it anyway, so there's really no advantage in doing so.
« Reply #19 on: March 12, 2011, 02:45 PM »
This is the heatshrink tubing I used - I bought it from eBay but there doesn't seem to be anyone selling it in that size at the moment.
Offline joiner1970
« Reply #20 on: March 12, 2011, 02:59 PM »
Nice one Jonny  [big grin]
As Bono sang "even better than the real thing"  [laughing] and cheaper too I imagine  [laughing]
Offline Alan m
« Reply #21 on: March 12, 2011, 03:07 PM »
love the workcenter.. nice sander hanger. seeing your thread inspired me to make 1 my self. i saved a lot of money aswell .
heres a few pics
34113-0
34121-1
34123-2
<< edited by Shane Holland to assist in correcting photo orientation >>
« Last Edit: March 12, 2011, 04:12 PM by Shane Holland »
Offline richard.selwyn
« Reply #22 on: March 12, 2011, 03:28 PM »
[/quote]
A couple of years ago to avoid all of that I bought the combined hose. It lasted about 2 weeks before it got too close to one of my halogen work lights over the bench which melted right through it. Being in the middle of the hose it is pretty much scrap now - although I did patch it. During the short time I used it I found the reduced interior dimension a nuisance.
Jonny has now motivated me to make my own for the mini VAC I take to site. First question - will the cable and wrap make the hose too difficult to coil to fit in the hose space on the top of the VAC?
Second question, would self blending (don't know what it's really called) electrical tape be a safe replacement for the heat wrap?
Nice job by the way Jonny. Any idea how long it took to build from start to finish? My problem is that as I am busy at the moment I too easily convince myself that it's viable to buy some overpriced thing that I could easily make myself ( I just got some Bowclamps from the US)
Richard.
« Last Edit: March 12, 2011, 03:32 PM by richard.selwyn »
Offline 2ooladdict
« Reply #23 on: March 12, 2011, 05:03 PM »
Very nice ideas here. I might try to do something similar and try integrate some kind of boom arm in it as well.
« Reply #24 on: March 12, 2011, 05:11 PM »
No, it will still coil. I have a Mini, and did the first hose for that. There's still room in the top for the hose with plug-it cable and the vac power cord, too.
Do you mean self-amalgamating tape? That black sticky rubber-like stuff? That would probably do, but I don't know if it remains sticky afterwards. Might be a bit messy...
I didn't keep an eye on the time, and did it a bit at a time over several days, but I reckon probably somewhere between 4 and 6 hours total for the woodwork. Probably anouther 2-3 hours for the painting and bending the wirework. The shaped end pieces took the longest time. Other than that, it's actually very straightforward. Two shaped ends, 4 rectangular pieces, and 9 pieces of softwood edging.
Offline Alan m
« Reply #25 on: March 13, 2011, 06:14 AM »
i built mine in about 4 hours but its not sanded or painted yet, althow this involved setting everything up in the shop and designing this ad hoch as i went allong. ihad no fancy augmented reality testing done. i am happy with it  so far . still neads a sander hanger and finishing and a few hooks here and there. i realy like the dc hose support thing i found at ikea on friday, realy tidys up the hose.
Offline CJ'60
« Reply #26 on: March 13, 2011, 07:36 AM »
heres a few pics
Great concept! I particularly like your abrasives store: a coffee filter hanger. [thumbs up]
Another piece of work to do for me. The creativeness of this forum causes headaches, my to do list keeps growing  [scratch chin]
I see you let your work centre is standing over the systainer. How do you connect the WC to the systainer and/or the CT?
AT-65 EB/1 Plus, CTL Mini, PS 300 EQ, OF1010 EBQ, Domino Set
Offline Alan m
« Reply #27 on: March 13, 2011, 08:06 AM »
the WC is not attached to the sys yet it is just sitting there. i let the sides down to give more support front to back and i will put a piece the size of the sys at the back. i will put a sortainer instead of the systainer and put a piece across the front if posible and still let the drawers open.
Offline CJ'60
« Reply #28 on: March 13, 2011, 08:49 AM »
I've got a CTL Mini.
I think I might carry the design a step further, partly because the Mini might not be stable enough due to having a smaller wheelbase, partly because the casters of the Mini might suffer from the amount of weight the WC will be carrying,
So I think of a WC that sits on casters on the floor, and has place to store the Mini+cyclone. Further I think about including detachable holsters, like the ones in some other threads to hang a TS55 or Trion on the MFT. The backside of the WC can store the holsters with the unused tools, the front side will allow for one or two holsters for the used tools. Because the base becomes larger than the Mini, I can include a boom arm as well. I've seen the magnet strip on Alan's version.
Whow, I get completely carried away by this thread and by my own ideas. [eek]
It's getting into the direction of those tool-carts used by mechanics in a garage.
« Last Edit: March 13, 2011, 03:04 PM by CJ'60 »
« Reply #29 on: March 13, 2011, 09:33 AM »
For those that are interested, I've modified my original SketchUp drawing (the design changed slightly as I went along) and I've posted it on the SketchUp Warehouse. Here's the final design, along with an exploded view:
34155-0
34157-1
Also attached below are PDF files for the template of the curves on the end pieces for anyone interested. Just be sure when printing to set 'page scaling' to 'none' in Adobe Reader.
