Author Topic: Cheaper alternative to anti-static 36MM hose?  (Read 6069 times)
Offline mbs
« on: October 24, 2018, 01:23 PM »
I'm looking for a much cheaper alternative to the Festool brand anti-static vacuum hose.  I want to connect it from my festool vacuum to the Kapex 36 mm od fitting.  Any ideas?
Online DynaGlide
Re: Cheaper alternative to anti-static 36MM hose?
« Reply #1 on: October 24, 2018, 01:51 PM »
Festools-online / Beaver tool just sold me the old style ribbed hose for 87.50. Already arrived today.
Instagram @matts.garage
Online sheperd80
« Reply #2 on: October 24, 2018, 02:00 PM »
The Bosch 35mm hoses fit Festool nicely. I think they're anti-static. Available on Amazon for much less than Festools hoses.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Offline mbs
« Reply #3 on: October 24, 2018, 02:05 PM »
Does the end go over the 36mm capex saw connection ?
Offline sprior
« Reply #4 on: October 24, 2018, 02:58 PM »
I just did this about a month ago.  You can get the Bosch hose and replace the end with the Festool 487721 Hose Sleeve, Reducing Sleeve For Antistatic D 36 Hose.  I'm using that now on my Kapex.
Offline mbs
« Reply #5 on: October 25, 2018, 06:41 PM »
While these solutions are much less expensive that Festool, it still seems like a lot to pay for a hose.  Thanks for your responses.
Offline gnlman
« Reply #6 on: October 25, 2018, 08:32 PM »
I've had my bosch 35 mm hose for years and it's still in great shape. I did eventually buy the festool hoses anti static green ones, but I still use my bosch hose and prefer it, it is more flexible. It was a lot cheaper when I bought it, seems like everything else, they have gone up too.
Greg
Offline sprior
« Reply #8 on: October 26, 2018, 12:27 AM »
https://beavertools.com/festool-24/festool-sales-closeouts.html
That 50mm2.5M hose on closeout sounds really great for the Kapex - if I didn't already have something in place I'd be all over that.
Offline GarryMartin
« Reply #9 on: October 26, 2018, 03:11 AM »
The 50mm hose doesn't work so well on the Kapex. You need the right combination of airflow and volume. The 36mm is optimum.
Offline ben_r_
« Reply #10 on: November 02, 2018, 03:34 PM »
Oneida-Air. Much cheaper alternatives there. They have a popular 2.5" that should fit the Kapex for around $25 shipped.
Offline RKA
« Reply #11 on: November 02, 2018, 03:53 PM »
@mbs
You're right, it is a lot.  The non-AS Bosch 35mm hose works fine, you don't need an AS hose.  That brings the price down a bit
https://www.amazon.com/Bosch-16-4-Foot-Vacuum-VAC005/dp/B0000AV78B/ref=sr_1_3?ie=UTF8&qid=1541187858&sr=8-3&keywords=bosch+hose
Near as I can tell, this hose is exactly the same stuff Festool uses for their non-AS hoses.  Cut it down to a 5ft length and replace the tool end connector (easy to swap them out) with the Festool hose sleeve mentioned above.  I think that puts you around $60 all in.
-Raj
Offline ben_r_
« Reply #12 on: November 03, 2018, 07:05 PM »
@mbs
Great suggestion! I forgot about that Bosch one!
Offline mbs
« Reply #13 on: November 06, 2018, 06:03 PM »
I like the bosch hose option EXCEPT I want the small end to fit on the OUTSIDE of the Kapex so it needs to be 38 mm ID on the small end.  Has anyone found a conversion fitting to go from the bosch hose to a 38mm ID fitting?
Offline sprior
« Reply #14 on: November 06, 2018, 06:33 PM »
Offline RKA
« Reply #15 on: November 06, 2018, 08:15 PM »
@mbs
Here is the Bosch hose with the Festool 36mm fitting on the back of my kapex. Easy to pull off the factory Bosch fitting and attach the Festool fitting.
And for reference, a shot of the Festool 36mm non-AS hose and fitting from the CMS. Identical as far as I can tell.
-Raj
Offline mbs
« Reply #16 on: November 06, 2018, 09:18 PM »
Thanks for the pic.  Based on the information in this thread it appears that these are the options:
Anti-Static option
a) Festool 3.5meter @ 36mm hose for $175
b) Bosch 5 meter @ 35mm ANTI Static with the festool 487721 hose sleeve for ($89 + $27) = $116.  Compared to Festool, its a longer hose for $59 less money.  The Bosch hose is 58% of Festool's price.
Static hose option
c) Festool 3.5meter @ 36m  hose for $110
d) Bosch 5 meter 35mm with the festool 487721 hose sleeve for ($37 + $27) = $64.  Compared to Festool, the Bosch is a longer hose for $56 less money.  The Bosch hose is 66% of Festool's price.
I looked at the Oneida option but I couldn't figure out if the Festool sleeve would fit the hose.
There is enough information to make a decision now.  I was hoping for a $25 option but it probably doesn't exist.  I appreciate your input.
Offline Corwin
« Reply #17 on: November 06, 2018, 10:21 PM »
When I purchased a Kapex a few years ago, I also purchased a 'Kapex hose' from Bob Marino. It is a D36-AS hose that is rather short, something like 1.5m or so -- a perfect length for using with the Kapex. I don't see it listed on his website, but you might call and ask. It was much cheaper than getting a longer Festool hose.
Offline Peter_C
« Reply #18 on: November 07, 2018, 12:48 PM »
You must have missed the link I posted above with the Festool hoses on 50% off sale??
https://beavertools.com/festool-24/festool-sales-closeouts.html?product_list_limit=all&product_list_order=price&product_list_dir=desc
Anti-Static option
How about $87.50
https://beavertools.com/festool-24/festool-sales-closeouts/452882-festool-hose-d36x3-5m-as-ct.html
You will also need the dust collector side fitting with the blue Bosch anti-static hose. I know I have one that I caught on sale for $33, and wished I had bought two. Festool 452893 is the part number.
That makes the Bosch hose $142.
Recalculating  [big grin]
Static hose option
Here is a 5 meter Festool static hose for $65, that could be easily cut down to any length desired.
https://beavertools.com/festool-24/festool-sales-closeouts/452883-festool-hose-d36x5m-ct.html
Fixed it for you!
d) Bosch 5 meter 35mm with the festool 487721 hose sleeve for ($37 + $27) = $64.  Compared to Festool, the Bosch is the same length hose for $1.00 less money.  The Bosch hose is .016% less than Festool's price.
(Note: shipping costs may be a factor.)
Offline mbs
« Reply #19 on: November 18, 2018, 08:22 PM »
I appreciate you responding to the thread but when I follow the links I don't see the prices you're quoting.  The links show full pricing.
Anti-Static option
How about $87.50
Static hose option
Fixed it for you!
Offline RKA
« Reply #20 on: November 18, 2018, 08:58 PM »
@mbs Unforunately you missed the boat, the Festool hoses were available when he posted.  They were both 50% off list price.  The AS hose has been superseded with a newer hose earlier this year so retailers slashed the prices and unloaded them.  To my knowledge the non-AS hose wasn’t superseded, so maybe that was a pricing error that was corrected?
-Raj
Offline Peter_C
« Reply #21 on: November 18, 2018, 09:00 PM »
You snooze, you loose... I tried to give you two opportunities. Make that three.
Offline mbs
« Reply #22 on: November 18, 2018, 09:08 PM »
I looked at your first post when you posted it and the only hose available was the 50mm which I wasn't interested in.  I missed hte second post.
thanks,
Offline Peter_C
« Reply #23 on: November 18, 2018, 09:55 PM »
thanks,
First post had them all...
You can do the Bosch hose as you showed above, but also include the part number I gave you. I have the Bosch and use it almost daily.
Edit: The same store has two websites. They have a 5m hose for $102. Just buy that one and be done.
https://festools-online.com/festool-sales-closeouts/452884-festool-hose-d36x5m-as-ct.html
https://beavertools.com/452884-festool-hose-d36x5m-as-ct.html
« Last Edit: November 18, 2018, 10:44 PM by Peter_C »
Offline mbs
« Reply #24 on: November 19, 2018, 09:43 AM »
thanks,
I guess I was looking at the wrong website but I followed the link.  Hmmm.  That hose will work!  Thanks Peter.
