Author Topic: Another Kapex + Sawstache Dust Collection Improvement  (Read 1809 times)
Offline Goldserve
« on: March 03, 2021, 08:53 PM »
Hello all, I just wanted to post some of my pictures of the saw stache dust collection improvement.
First I bought an extra boot so if I have a need to use my aux fence for tear-out free cuts, I can swap in the original dust boot.
- Festool 200215 Kapex Replacement Dust Extraction Boot
- Fastcap Saw Stache, 2in, 1-ft (https://www.fastcap.com/product/saw-stache)
- 3 x M3 - 10mm screws and nuts
- 3 x M3 washer
- 1/2 Alunimum Flat Bar at 1/16 thickness
- 1/8 Drill Bit
« Last Edit: March 03, 2021, 10:06 PM by Goldserve »
Offline Rick Herrick
Re: Another Kapex + Sawstache Dust Collection Improvement
« Reply #1 on: March 03, 2021, 11:16 PM »
The pictures look great.  Did it get you want you wanted?  I have the items to do the same but haven't done it yet.
Offline Goldserve
« Reply #2 on: March 03, 2021, 11:22 PM »
Yes. As you can see, there is no where for the dust to escape. I’m in the process of upgrading to a 36mm moose as well.
« Last Edit: March 04, 2021, 02:43 AM by Goldserve »
« Reply #3 on: March 03, 2021, 11:59 PM »
Excellent!  I need to get this done.  Thanks for sharing.
Offline 08G8V8
« Reply #4 on: March 15, 2021, 05:00 PM »
I recently got the Kapex REB and want to order a separate Apron to have one setup with the Saw Stache and also keep the stock one intact. I have seen the 200215 part number for the REB saw, but 471316 for the older EB saw.  They look identical. Do you think they actually created a brand new part number which is unique, or simply gave it a new part number with it being the same?
Only reason I ask is I can’t find the 200215 in stock, but have seen the 471316. And, the old part number is like $6 vs $20 for the newer.
Offline jimk1963
« Reply #5 on: April 14, 2021, 06:25 PM »
Great photos and parts list. Special Thanks for providing the parts detail, all too often missing from new posts. Re: 200215, I see it in stock on Tool Nut  for $30. In the world of Festool that's about as cheap as anything gets...
Offline 08G8V8
« Reply #6 on: April 24, 2021, 06:56 PM »
Update:
So I ordered a 471316 Apron which was $6 + $5 shipping and just got it and when I compared it to the original they are identical.....and my original as stamped with the 00471316 part number.  Guess I would have known awhile back if I had just pulled off the apron to begin with, and I would have seen the part number then.
Order the 471316.
Offline Goldserve
« Reply #7 on: April 24, 2021, 08:26 PM »
Thanks for the tip. Loving the kapex plus the improved dust collection. A short 36mm hose helps too! I can now do very quick cuts in my garage with the miter station against the wall and not kick up a storm.
Offline DynaGlide
« Reply #8 on: April 24, 2021, 10:59 PM »
Update:
Order the 471316.
I just opened mine up and the stamped part numbers are different but they are otherwise identical. Glad we took a chance on the cheaper part. Saw stache should get here in a few days.
Instagram @matts.garage
