Author Topic: 80/20 Parallel Guides  (Read 5010 times)
Offline Route24Design
    • My Personal Blog
« on: April 10, 2018, 04:53 PM »
Made a set of parallel guides out of 80/20
https://www.woodworktech.com/home/diy-80-20-parallel-guides
« Last Edit: August 12, 2018, 04:26 PM by DIY WoodWerx »
Festool TS 55 REQ-F-PLUS
Festool OF 1400 EQ-F-PLUS
Festool CT MIDI HEPA
Festool CT Sys HEPA
Festool Domino DF 500 Q-PLUS
Festool PRO 5 LTD (ETS 125 REQ)
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Festool FS 1400/2 (x2)
Festool FS 1400/2-LR 32 Guide Rail
Festool LR32 Router Hole Drilling Set
Offline cubevandude
Re: 80/20 Parallel Guides
« Reply #1 on: April 10, 2018, 08:27 PM »
They look pretty nice.  Any chance you can supply a list of part numbers you used?
Offline jobsworth
  • Festool Baby.....
« Reply #2 on: April 10, 2018, 08:34 PM »
pretty nice idea.
    • My Personal Blog
« Reply #3 on: April 10, 2018, 08:43 PM »
(2) 3356 - used to attach guides to rail
(2) 4165 -
(2) 4167
(2) 2012 - 24” length
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline ben_r_
« Reply #4 on: April 10, 2018, 09:23 PM »
(2) 4165 -
(2) 4167
Whats the total cost of that parts list?
    • My Personal Blog
« Reply #5 on: April 11, 2018, 06:37 AM »
(2) 4165 -
(2) 4167
Around $40 plus some 1/4-20 screws of choice.  I had some laying around.
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline egtlover74
« Reply #6 on: April 11, 2018, 03:26 PM »
What kind of screw is the chrome thumb screws?  They look awsome. [cool] I was just looking at seneca jig for $120 plus dollars
    • My Personal Blog
« Reply #7 on: April 11, 2018, 03:28 PM »
1/4-20 x 1/2” knurled thumb screw.  I believe I got 10 pieces for $9 on eBay
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline GoingMyWay
« Reply #8 on: April 11, 2018, 03:48 PM »
Nice looking parallel guides and for a very affordable price.  Correct me if I'm wrong, but it doesn't look like you can make any cuts narrower than the the width of the track.  Is that correct?
Inquiring Minds Want to Know
    • My Personal Blog
« Reply #9 on: April 11, 2018, 05:15 PM »
That’s correct.  Seems to be the downside I’ve noticed so far.  Might utilize the LR32 guide stops for narrow cuts.  Have to test it out.
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline Richard/RMW
« Reply #10 on: April 11, 2018, 09:54 PM »
Somewhere I have an old rip guide setup doc that shows how to create a spacer of the same thickness material as what's being cut to let you cut stock narrower than the guide rail.
All you do is set the stops tight against the guide rail bracket & then cut your spacer material. Next move the stops left to the width of the part you want to cut and using the spacer cut your stock. Presto, narrow stock guide, save the spacer for later use.
Will try to find the setup guide and post it. (EDIT: Posted below)
RMW
PS - nice job on the guides, I like that they are totally DIY and don't require any machining.
« Last Edit: April 11, 2018, 10:15 PM by Richard/RMW »
    • My Personal Blog
« Reply #11 on: April 11, 2018, 09:56 PM »
RMW
That would be cool.  Thanks
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline Richard/RMW
« Reply #12 on: April 11, 2018, 10:14 PM »
RMW
Found it. Geeze I've got a lot of junk on my computer.
Now I recall this started as a calibration cut & then I realized I had made a spacer. Hope it's of some use.
RMW
Offline cubevandude
« Reply #13 on: April 12, 2018, 11:31 AM »
After looking at the INCRA 24 T-TRACK in the instructions provided  this track would allow one to make narrow rips as it has the t-track facing both ways.
One could possibly use this bracket to attach: https://8020.net/shop/4150.html
« Last Edit: April 12, 2018, 11:39 AM by cubevandude »
Offline GoingMyWay
« Reply #14 on: April 12, 2018, 12:52 PM »
RMW
Thanks for sharing this!  I have the Precision Parallel Guides, which have a spacer that slides under the track.  Your PDF peeked my interest and got me to thinking about my Precision Parallel Guides.  I took another look at the manual and discovered that I somehow missed the part that says the spacer is optional and can be removed.  Without the spacer they'll work just like you've shown in your PDF.
I'm not crazy about how the spacer goes under the track so I'm going to try using them without the spacer and see how that works out.
Offline Richard/RMW
« Reply #15 on: April 12, 2018, 05:45 PM »
Another byproduct of using the spacer is that the guide rail is fully supported during the cut. I believe all the aftermarket guides have the same issue where the rail needs to be supported when making narrow cuts.
RMW
Offline GoingMyWay
« Reply #16 on: April 12, 2018, 06:29 PM »
Having the rail full supported is very nice indeed!
Offline box185
« Reply #17 on: April 12, 2018, 11:08 PM »
RMW
I like this idea - thank you for sharing your guide, and pointing out the benefit of having the guide supported.
Offline rich1
« Reply #18 on: March 09, 2019, 01:09 AM »
Brilliant! thanks for this
