Author Topic: 3D printer filament brand/color that comes closest to matching Festool green?  (Read 4848 times)
Offline sprior
This is one of those crossover questions that gets me blank stares, but has anyone found a brand/color of 3D printing filament which comes pretty close to matching Festool green?
Offline Brian Puccio
I'm a big fan of colorFabb ngen ... it's my go-to filament.
They have a service where you can get any color you'd like:
https://colorfabb.com/color-on-demand
But I haven't tried it.
Offline Trevin
I was just looking at the ColorFabb site yesterday.  I also have started using their nGen material lot.  With there custom color service do you know if you can get nGen?  They do have RAL 6018 (Festool Green) under their RAL colors that are available.
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline justaguy
I'm using Inland 1.75mm Peak Green PLA which is just a bit lighter shade. Side by side 6 inches away the difference is pretty apparent. Five feet away is just barely noticeable. I'll try to post a picture later.
Offline sprior
Thanks for the info!  Just a couple of years ago on the FOG I mentioned having a 3D printer and people told me there wasn't (yet) much crossover between Festool owners and 3D printer owners.
Inland is the Microcenter house brand and their filament is made by eSun which I like, I also like the price.  It's too bad that they haven't moved this particular color from their PLA to their PLA+ yet (you can tell by the recommended temperature range), but they'll get there eventually.
Offline briankb
looks like eSun has that color in PLA+ now
PLA+
https://www.amazon.com/eSUN-1-75mm-Printer-Filament-Pantone/dp/B01EKEMQ0S
ABS
https://www.amazon.com/eSUN-1-75mm-Printer-filament-2-2lbs/dp/B00MVIPL5I
Has anyone found a better color match for festool green than the one above?
Offline sprior
I'm not sure it's EXACTLY the same color, but esun makes the house brand filament (Inland) for Micro Center which sells it cheaper than esun.
https://www.microcenter.com/product/504221/Premium_175mm_Neon_Green_PLA_3D_Printer_Filament_-_1kg_Spool_(22_lbs)
Offline ben_r_
Bumping this thread as I am looking to pick up a spool of whatever most closely matches the Festool green.
Anyone have any more/better recommendations or is the eSun Peak Green PLA+ still the best option?
Offline sprior
The Microcenter Inland Peak Green PLA+ is pretty close, PLA+ is a good filament in general, and it's quite cheap.  As I mentioned above Inland is the Microcenter house brand and they source it from eSun.
Offline ben_r_
This one looks promising too, but from the pictures along its hard to tell. LINK
