Author Topic: 2 Meter profiles for MFT/3  (Read 1640 times)
Offline jcrowe1950
  • Festool Dealer Affiliate
    • Woodcraft Chattanooga, TN
« on: June 04, 2020, 01:16 PM »
Hi Folks,
    I was just perusing EKATS and found a listing for the 2 meter profiles under the 495314 MFT/3 listing. The part number listed is 496824 and the price is $252.12 apiece. Interesting, but a fairly pricey upgrade. Of course, one would need to make a top but it looks like it's out there.... [scared]
Festool Specialist at Woodcraft, Chattanooga, TN
Offline Gregor
Re: 2 Meter profiles for MFT/3
« Reply #1 on: June 04, 2020, 01:18 PM »
Or screw them (or pieces) onto things (or walls) you want to attach MW 1000 tables to.
Offline box185
« Reply #2 on: June 04, 2020, 01:47 PM »
Hi Folks,
I ordered these from a Festool parts distributor in the USA. It took about five months for the order to be shipped out to me, but the item was delivered in early May - to one of their customers in New York state by mistake.
I've been working with the distributor to have their NY customer return them, but that does not appear to have happened yet since it's been over three weeks since they were going to be sent over to me in Iowa.
Offline waho6o9
    • Garage Door Handyman.com
« Reply #3 on: June 04, 2020, 02:09 PM »
Maybe use EBAY from Germany, that's how I received a 5 Meter folding ruler and I don't speak German.
Use Google translate and hope for the best.
Offline jcrowe1950
« Reply #4 on: June 04, 2020, 02:13 PM »
Hi Folks,
Sorry to hear about your experience. FWIW, I will attempt to contact Festool USA at some point to ask them about those parts. Pretty busy right now as I'm only very part time at Woodcraft, but I do have some contacts. I reckon if one used either the MFT/3 guide rail mounts and protractor/fence or guide rail clips and dogs with aftermarket accessories, having a bigger table top would be a huge win. I'm thinking here of an ideal cutting station as well as a glue-up for edge joined panels.
Offline Fest_fool
« Reply #5 on: June 23, 2020, 06:06 AM »
Can anyone confirm that when you order part number 496824 that you recieve two profiles in one box? I’m 90% sure you do
Offline GarryMartin
« Reply #6 on: June 23, 2020, 06:12 AM »
Yes.
Offline Fest_fool
« Reply #7 on: June 23, 2020, 06:58 AM »
Thank you Gary!
Offline rst
« Reply #8 on: June 23, 2020, 02:19 PM »
People on the forum have bought the long rails from the UK but I don't remember who.
Online Cheese
« Reply #9 on: June 23, 2020, 02:35 PM »
As rst mentioned, I’ve also purchased Euro only Festool stuff from the UK.
PM me for their name, address and email.
Offline box185
« Reply #10 on: June 23, 2020, 03:17 PM »
I ordered my second pair from the local Festool dealer - ACME TOOLS
Offline rst
« Reply #11 on: June 23, 2020, 05:29 PM »
Box, did you buy the long MFT side rails or the two meter NAINA rails.
Offline box185
« Reply #12 on: June 23, 2020, 06:32 PM »
I bought the two meter ( previously ) NAINA rails.
I found them first at mmTools, but then again later at the local Festool dealer.
Offline box185
« Reply #13 on: June 25, 2020, 06:36 PM »
As mentioned earlier, I ordered these from ACME Tools - the order was placed two weeks ago. One pair arrived today, but were damaged on one end from having been dropped somewhere.
I left the store without the profiles, but these are the two meter long profiles.
Offline Thompmd
« Reply #14 on: June 26, 2020, 08:33 AM »
Could someone provide a photo of the profiles. I’m likely going to purchase my first mft and I’m curious. Thanks in advance
Sawstop Industrial Saw, TS75,2 1400 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160
Offline GarryMartin
« Reply #15 on: June 26, 2020, 10:06 AM »
See https://www.festoolownersgroup.com/festool-jigs-tool-enhancements/mft3-profile-image-and-measurements/msg258160/#msg258160 for the end profile and some rough measurements.
See https://grabcad.com/library/701507 for the 3D profile as CAD files.
Offline Thompmd
« Reply #16 on: June 26, 2020, 11:19 AM »
Thank you Garry!! New to FT, Ekat etc etc trying to learn as quickly as I can. I’m much better as visually seeing things than research.
Offline MikeGE
« Reply #17 on: June 26, 2020, 11:46 AM »
@GarryMartin -  Thanks, Garry!  I am planning a modification to my Minimax SC2 saw to replace the steel tables with a larger MFT-like table. Your diminsioned drawing of the Festool aluminum extrusion helps me find mating extrusion to serve as the interface between my saw and the new table.
Offline GarryMartin
« Reply #18 on: June 27, 2020, 05:53 AM »
@MikeGE There are some good options for 3D printing too; check out Thingiverse. Various Festool bits on there, including options that make use of the profile for brackets etc.
