Guest
Login
Register
Home
Help
Search
Contact
Login
Register
Festool Websites
Festool USA
Festool UK
Festool Canada
Festool Australia
Festool Netherlands
Festool Germany
Festool International
Additional Websites
Abrasives Selector
Register a Tool (US)
Spare Parts Catalog
Owners Manuals
Festool Roadshow (US/CA)
Festool Recon (US)
Festool.tv
Festool Owners Group
FESTOOL DISCUSSIONS
Festool Jigs & Tool Enhancements
(Yet another) Domino 500 jig...design input/question
« previous
next »
Print
Pages:
1
2
3
4
All
Go Down
Author
Topic: (Yet another) Domino 500 jig...design input/question (Read 15754 times)
jbarr
Re: (Yet another) Domino 500 jig...design input/question
Reply #90 on:
August 02, 2022, 11:39 PM »
Probably Microjig's dovetail clamps would work as well.
Chuck I'm impressed that your mortising 5mm stock when the smallest tenon is just under 4mm. Not a lot of wiggle room. I guess this jig makes that possible. BTW I use my home made carmonius version (and soon to buy this jig) for doing small boxes so I also mortise into faces as well as edges. I use an L shaped push block to keep the piece vertical and hard up against the fence using one of the clamping elements clamps. I obviously needed a 20mm hole which I drilled in the middle of the jig. Just another use which works perfectly not shown in any of the videos
ChuckS
Reply #91 on:
August 03, 2022, 11:27 AM »
John,
I've done Dominoes with 5mm stock before:
https://www.festoolownersgroup.com/member-projects/sorting-trays-(5mm-ply)-done-with-df500-4mm-tenons/msg662850/#msg662850
The joinery table will use a shim on the table instead of a shim on the machine, with improved accuracy. The set-up will also be simpler.
Adamsse
Reply #92 on:
August 03, 2022, 10:13 PM »
Chuck, Thanks for alerting us to 5mm capability. I just tried that on the Veritas table. The .093 acrylic + 2 sheets of paper did it. If you have additional posts or photos on how you have applied this in the past, we would appreciate it. Sandy
ChuckS
Reply #93 on:
August 04, 2022, 11:00 AM »
Sandy,
The sorting trays are the only project I used 5mm ply on, but I saw the potential of the Veritas joinery table to do similar tasks that require precision and more.
Print
Pages:
1
2
3
4
All
Go Up
« previous
next »
FESTOOL DISCUSSIONS
