Hello, - Surely, someone is using an UDD on a newer CT26???
I have a CT22 that I have used an UDD on for over 10 years. l am retiring at the end of the year and am replacing a few of my older tools now while I have money ;-) I just received a CT26 Hepa vac and began assembly last night. It appears I my have some difficulty mounting my older UDD on the new vac. To that end I called Oneida and was told there is only one UDD bucket so this one should fit my new CT26. He sent me the instructions to modify the lugs on the UDD case to fit a mini or midi which I may need to do but it looks the the front and rear locks on the CT 22 are on the lefty side and the front rear locks on the CT26 are on the right. Flipping the case 180 degrees would fix it but I would need a longer tube to attach the suction to keep the interior bag open. I obviously taking the UDD off and sitting it on the 26 would give me more info but I would rather have a plan in place before I disassemble my CT22 setup as it is central to my shop. Ha anyone here mount a UDD on a new CT26 and if so what modifications did you need to make? A pic or two would be great!
Jack
