Hey all,
This thread prompted me to investigate building a benchtop domino jig, both to hold the domino and the material to be mortised.
I liked the design Carmonius Finsnickeri (
) came up with, but realized it's not height adjustable. I.e. I frequently work with 1/2" and 3/4" stock, and the 10mm cutting height is fine for 3/4" but not so much for 1/2".
Would be curious if anyone has ideas to enable height adjustment on this.
I came up with three:
1. Cut a pocket to recess the Domino machine in that design for the thinnest stock size (say 1/2"), then shim it up to other desired thicknesses (i.e. have a shim ready for 3/4" thickness, fabricate other thicknesses as needed). Will this be accurate/repeatable?
2. Have multiple jigs for multiple thicknesses...seems crazy duplicative / wasteful / $$$ but probably most accurate and minimizes setup time and human error...doesn't seem reasonable
3. Have interchangeable bottom pieces (that holds the domino) for variable thicknesses - i.e. have one thickness cut for 1/2", one for 3/4", be able to fabricate more as needed. Use Domino connectors or something like that to connect the two pieces of the jig . Concern about accuracy with the connectors (getting repeatable heights).
Would welcome any feedback/thoughts - thanks!
