I bought some 8/4 Hard maple over the weekend for a workbench project. The boards were all about 10' long and 10-10.5" wide. I was able to get them oversized for the lengths I need but now I need to rip them. I was going to use the TS55 but after checking, they're all over 2", maybe 2 1/8".
I would like some of the boards to end up at 1 7/8" for leg glue ups/laminating together but it isn't 100% necessary. The legs finish out at 3.5" after gluing two boards together so there is a little wiggle room. The rest of the boards finish out at 1 3/4" for frame pieces/stretchers on the base of the workbench.
My initial feeling was I should do everything I can to not face joint the wide boards on the planer w/ a sled as that would possibly result in removing too much material. I wanted to rip them first to get the two parts out of each board (i.e. a leg blank and a stretcher), then start face jointing/planing to oversized thickness.
As I see it I can
A) Plunge about an inch or more with TS55, flip board and carefully line up to finish the cut, leaving the width well oversized. I believe I have enough width to do this and still get both parts from each board oversized in width.
B) Start face jointing/planing until the thickness is below 2", then rip in 1 pass with the TS55 and panther blade taking it slow.
I will have access to a proper jointer when necessary, as well as a bandsaw, but that requires me to schedule and work around my job and family obligations. Trying to limit that trip as much as possible and do what I can ahead of time.
Thanks,
Matt
