Author Topic: Vacuum Clamp System - Filters option  (Read 653 times)
Offline bigdogmn73
« on: January 11, 2022, 04:01 PM »
If anyone out there is in need of a filter for their vacuum Clamp System they can be found here. I ordered one from one of the Festool dealers and when I got it I figured out I could have ordered it from the below for $4.99 compared to $50 plus I assume the Festool dealers won't carry it long term and they said to replace them yearly.
https://www.dieselfiltersonline.com/wk-42-2-mann-filter-european-spin-on-fuel-filter-renault-passenger-car-and-light-truck-7-700-271-026.html
Offline _Ben_
Re: Vacuum Clamp System - Filters option
« Reply #1 on: January 12, 2022, 04:10 PM »
Thanks!
Offline GarryMartin
« Reply #2 on: January 13, 2022, 07:26 AM »
Spot on. The actual part is a Mann Hummel WK 42/2 Fuel Filter.
Just bear in mind that you don't get the clips and o-rings that you get in the Festool packaging so will need to source those separately if you need them.
Offline woodwise
« Reply #3 on: January 13, 2022, 08:05 AM »
Thanks! Very useful information.
Online DynaGlide
« Reply #4 on: January 13, 2022, 08:14 AM »
Thanks. I grabbed two. If I ever get the fittings I ordered to replace the QD couplings I'll start a cross reference for the Vac-Sys parts thread.
Matt
Instagram @matts.garage
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
« Reply #5 on: January 13, 2022, 04:59 PM »
Thx Guys👍
Scored 4 for myself.
$26 and change for 4 - Including S&H.
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: PDC 18/4 Li QuaDrive Cordless Drill Set, C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIG: D4R 24 Pro Dovetail Jig, | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
Offline Bob D.
« Reply #6 on: January 13, 2022, 10:58 PM »
".... Including S&H."
S&H as in Green stamps?
Didn't know they still give out S&H Green Stamps?  [big grin]
