Author Topic: Unpairing bluetooth remote  (Read 544 times)
Offline Frank-Jan
« on: March 30, 2022, 12:02 PM »
Just a reminder for people with multiple vacs with bluetooth remotes.
If you want to use a remote that has previously been used with another vac, you first have to "unpair" it by, holding both the buttons on the remote till it flashes slightly red-ish (the manual calls it magenta). After this you can pair it as usual.
(When I had to send one of my vacs in for a warranty repair, I put the bluetooth module in my other vac; I ordered an extra bluetooth module, and used that remote on another hose, both with the same vac; later,  when I was using both vacs on the same job I couldn't get one of the hoses to pair with the other vac, I tried removing the battery, reïnstalling the module,...  (there are plenty of clips that show the pairing process, but none tell this, so I eventually downloaded a manual to figure this out.
Offline LsDelancy
Re: Unpairing bluetooth remote
« Reply #1 on: June 09, 2022, 03:02 PM »
I wish I had found this earlier.
This may be needed on a new remotes as well, as they pair them with something to test them at the factory.
I ended up taking my new CT and remote back to the dealer to learn this. He had to call Festool, who knew the issue and fix immediately.
