Author Topic: Hose question. Am I missing something?  (Read 2871 times)
Offline KGB pilot125
« on: April 09, 2018, 04:27 PM »
Is there an adapter I can use to connect one hose to another?
I have this Festool 493047 Hose Sleeve but it needs to have a different end (the vac end) for them to connect to each other.
Offline mwildt
Re: Hose question. Am I missing something?
« Reply #1 on: April 09, 2018, 04:40 PM »
You need another vac end so one hose is vac-vac + the connector you listed. OR use the new connectors. Sledge (Festool) indicated that to be possible with the new connectors. OR tape them together using masking tape.
Offline Shane Holland
  • Festool Dealer
« Reply #2 on: April 09, 2018, 04:44 PM »
See attachment.
FYI, the new braided sleeve hoses will join together without any voodoo or extra bits.
The Tool Nut
ToolNut.com
877-866-5688
« Reply #3 on: April 09, 2018, 05:18 PM »
Ok thanks guys.
Thats what I am doing now, I have a D36 with Vac----Vac-Adapter-Vac----Toolend that I also swap a D27 hose onto.
I just assumed [wink] that because Festool is German there would be a more efficient way of doing it!
Offline rst
« Reply #4 on: April 09, 2018, 05:25 PM »
I bought the sleeved hose with cord when they came out, replaced the vac end with a tool end, plug that into my 36mm hose, use an extension cord to connect the plugin.  Voila...long hose with minimal pressure drop.
Offline DynaGlide
« Reply #5 on: June 26, 2021, 07:54 AM »
See attachment.
@Shane Holland or anyone else. I bought a new style 36mm hose and it doesn't join to another 36mm hose or to itself. I can join a new style 27mm to it no problem but if I want to join two 36mm hoses, I can't. What am I missing?
Instagram @matts.garage
Offline guybo
« Reply #6 on: June 26, 2021, 08:32 AM »
Hi, for two 36mm hoses, one hose must have two(2) rotating ends they are needed and a connector sleeve all rotating ends are 58mm O.D.whether, 27,36 or 50 hoses,connector sleeve#493047.
« Last Edit: June 26, 2021, 04:14 PM by guybo »
