Author Topic: TS 55 Full Depth  (Read 517 times)
Offline Mario Turcot
TS 55 Full Depth
« on: October 10, 2019, 05:57 PM »
I have been using the TS 55 for 1.5 year. I never cut material thicker then 3/4" (18mm). Today I had to cut ~2" (49mm). I setup the track guide and set the saw depth all the way down. I then manually engage the plunge to see if it was enough. The specs says 2" 1/8 but you never know. I realized that the blade was only going down 1"  [eek]
I couldn't find what was blocking the plunge until I notice the splinterguard was the issue.
It was not cut through and the blade was bumping on it.
If it happen to you just run the saw at full depth free air and the splinterguard will not confused you like it did to me  [embarassed]
P.S. I need to clean my blade  [wink]
Mario
Re: TS 55 Full Depth
« Reply #1 on: October 10, 2019, 09:42 PM »
“P.S. I need to clean my blade‘
Good thing you didn’t try to cut something at full depth. There’d be some smoking...
