Author Topic: TS 55 FEQB-Plus plus compatibility with CMS TS-55 module  (Read 1016 times)
Offline vf73
« on: January 08, 2023, 09:44 AM »
Hello,
I just bought a CMS TS-55 module for my CMS table.
Browsing the Festool website, TS 55 FEQB-Plus technical specifications claim that this model is not compatible with the CMS module.
What is the reason for this ? Has anyone managed to adapt this model to the CMS table, and if so how ?
Any advice is more than welcome !
Cheers,
Vincent
Offline TinyShop
Re: TS 55 FEQB-Plus plus compatibility with CMS TS-55 module
« Reply #1 on: January 08, 2023, 11:23 PM »
Cue the moderators....
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline mino
« Reply #2 on: January 09, 2023, 04:08 AM »
The new TS 55 F series of saws have an integrated NVR safety device.
This means they are not practical for use in a table - the external switch will no longer work with them as designed.
Your best bet is a used TS 55.
They are cheaper to get and all the improvements since then were focused on rail use, so for CMS they are equivalent. I would actually argue that the 2.5 mm kerf blade of the original TS 55 is better for the table saw use. It is easier/cheaper to get non-FT blades and they are also slightly more stable compared to the 2.2 (TS 555R or the 1.8 (TS 55 F) blade options.
Also, from practice here on the forum, it is best to dedicate a TS saw for the CMS module. The install/remove cycles get tiring fast.
The Machine has no brains. Use Yours!
Offline vf73
« Reply #3 on: January 12, 2023, 02:52 AM »
Thanks for the advice ! Ruling out F-series as you advised, would the REQB variant be an option ?
Cheers,
Vincent
Offline GarryMartin
« Reply #4 on: January 12, 2023, 03:40 AM »
There were two CMS modules, the CMS TS 55 and the CMS TS 55 R. You need to match the saw to the module type.
If you have the CMS TS 55 modules, then the REBQ is not an option.
Offline vf73
« Reply #5 on: January 12, 2023, 03:59 AM »
Do you know which spare parts can turn a CMS TS 55 module (the one I have) into a CMS TS 55 R variant and whether such spare parts are still available ?
Offline GarryMartin
« Reply #6 on: January 13, 2023, 08:23 AM »
You'll find further information in this thread... https://www.festoolownersgroup.com/festool-tools-accessories/cms-ts-55-55r-saw-module/msg294467/#msg294467
Offline vf73
« Reply #7 on: January 14, 2023, 07:25 AM »
Thanks a lot, that's exactly what I needed !
Cheers,
Vincent
