Author Topic: Track saw, and door sizing.  (Read 3835 times)
Offline Obj99
« on: April 25, 2019, 08:33 AM »
I am a diyer, and want to know, is it acceptable or viable to use a track saw to reduce the width of a door stile, when sizing a door that requires a small width reduction, instead of using a plane or a router. Obviously you can use the tracksaw to trim the bottom of the door, but what about the width. If so, how accurate would the Festool tracksaw be.
Offline Peter Halle
Re: Track saw, and door sizing.
« Reply #1 on: April 25, 2019, 08:37 AM »
Welcome to the FOG!
The track saw is as accurate as your ability to align the splinter strip to a line or other marks.  Sure it could work.
What kind of door(s) are you thinking about?  Others might be able to give some tips.
Offline waho6o9
    • Garage Door Handyman.com
« Reply #2 on: April 25, 2019, 10:18 AM »
"Obviously you can use the tracksaw to trim the bottom of the door, but what about the width. If so, how accurate would the Festool tracksaw be."
It would be very accurate using a Festool Panther rip blade, one continuous rail, and maybe a little sanding to make it
presentable.
Welcome to the FOG!
Offline Mike Goetzke
« Reply #3 on: April 25, 2019, 10:41 AM »
Is the door assembled? If not may need to be cautious on making sure you clamp the work piece correctly to the rail.
Offline RKA
« Reply #4 on: April 25, 2019, 10:46 AM »
@Obj99 What concerns would you have about this?  I ask because I don't really understand why you're distinguishing between the crosscut and the rip cut.  I've ripped pine doors to size with the factory 48 tooth blade, a single 55" track, a combination square to set and reposition the track consistently and a few clamps.  Works fine if you're doing a few here and there.  If you were batching these out to fit out an entire house, I'd get a longer rail or join 2 rails to speed things up.
That said, using the tracksaw will obviously give you a straight edge.  You may still find a hand plane useful to finesse the edge to fit your jambs.
-Raj
Offline Sparktrician
« Reply #5 on: April 25, 2019, 10:54 AM »
I'd be using two rails, joined and aligned properly, and clamped to the door.  Don't forget to bevel the latch side by 3-4 degrees, depending on thickness, to allow that door to slide past the jamb when it opens and closes.
- Willy -
Offline ChuckM
« Reply #6 on: April 25, 2019, 10:59 AM »
I am assuming you are getting a track saw (regardless of brands) not just for trimming doors.
One does not need a track saw to trim doors. My contractor needed to trim a bathroom door after some title work was done. He used a circular saw and a plywood sheet tacked with a a straight edge to complete the job. (I did not own a track saw or I would have let him use mine.) To avoid splintering, he blue taped the exit side of the door before cutting. I had to admit for one-time jobs, his method worked so well.
« Last Edit: April 25, 2019, 11:03 AM by ChuckM »
Offline jobsworth
  • Festool Baby.....
« Reply #7 on: April 25, 2019, 11:06 AM »
Track saw would be your best choice. You can create your bevel and cut it at the same time.
Offline demographic
« Reply #8 on: April 25, 2019, 12:42 PM »
I've used a tracksaw to ease doors but they always needed me to run a plane over the edge to finish it.
I honestly don't care what people say about them producing a "Finished edge"... Its just not.
Anyone who thinks a circular sawcut edge is an internal finish, should be bombed off site never to come back.
Just a few shallow passes with a plane sorts it out but no way on earth is a sawcut edge finished.
Mind, I'm not a fan of electric planes for a finished edge either. Still needs a proper plane afterwards.
Offline ChuckM
« Reply #9 on: April 25, 2019, 01:43 PM »
I can't but wonder how people trimmed doors BEFORE track saws became popular for the trade people. [eek]
Here is a photo of the bathroom door trimmed using a circular saw. Looks great to any reasonable homeowner. I know for a fact that here in North America not every title installer has a track saw or can afford one, and they trim doors whenever needed. Some independent title installers who do everything in small jobs in my city could go unemployed if their tool kits must include a track saw, green or not in colour.
« Last Edit: April 25, 2019, 02:08 PM by ChuckM »
Offline demographic
« Reply #10 on: April 25, 2019, 02:08 PM »
Here is a photo of the bathroom door trimmed using a circular saw. Looks great to any reasonable homeowner. I know for a fact that here in North America not every title installer has a track saw or can afford one, and they trim doors whenever needed. Many independent title installers who do everything in small jobs in my city could go unemployed if their tool kits must include a track saw, green or not in colour.
I've done it witha handsaw before, but still ran a plane over em afterwards.
But the original poster was specifically asking about not using a plane on it, which I personally think is too rough a finish.
I can go along with a sawn edge being glue ready but unless someone is after a very rustic look  its not a "Finish"
The marketing bods at Festool may well disagree but they are salesmen... not carpenters or joiners.
Offline ChuckM
« Reply #11 on: April 25, 2019, 02:18 PM »
Of course, no two woodworkers may see eye to eye when it comes to what a fine finish is. I remove machine marks with a plane even though other Forrest Woodworker II saw blade users are happy with the finish the blade leaves. I am not, when it is a furniture piece I am building.
On the other hand, I don't look under to see what it is like on the bottom edge of a bathroom door, and  the blue tape method is used by some trade people I know.
Offline JimH2
« Reply #12 on: April 25, 2019, 03:41 PM »
If the margins are that tight then they are not charging enough. $700 spread out over several years of jobs is a rounding error.
Offline ChuckM
« Reply #13 on: April 25, 2019, 04:06 PM »
We are not talking about renovation contractors or trade persons here who go to jobsites with a boatload of tools like mitre saws, jobsite table saws, track saws, sanders, etc. These are mostly tile installers or handymen who take on themselves to finish small trim jobs for bathrooms, kitchens, windows, decks, etc.
I know a retired carpenter who still does small jobs, but he earned his pre-retirement living using circular saws (cordless and corded) for decades. He is not going to get a track saw as a handyman, is he?
The point is that many people make a living as trade people (at least in my city) using tools that are main-stream and pretty basic. Some of them really can't afford using high-end tools with their limited budgets.
I don't know personally anyone who owns a Kapex to do site work, but we seem to find a good share of them here in this Forum. Dewalt, Hitachi and Bosch mitre saws are saws used by renovation and roofing contractors as far as I have seen.
« Last Edit: April 25, 2019, 04:25 PM by ChuckM »
Offline Svar
« Reply #14 on: April 25, 2019, 04:28 PM »
The point is that many people make a living as trade people (at least in my city) using tools that are main-stream and pretty basic. I don't know personally anyone who owns a Kapex to do site work, but we seem to find a good share of them here in this Forum. Dewalt, Hitachi and Bosch mitre saws are saws used by renovation and roofing contractors as far as I have seen.
If I had to guess I'd say over half of Festool market in the US is represented by well-to-do hobbyists.
Offline Jiggy Joiner
« Reply #15 on: April 25, 2019, 04:47 PM »
If it’s a small amount I favour a hand plane. If considerably more, and electric or cordless planer would be fine, otherwise circular saw, or plunge saw, then plane and a light sanding.
Often with a nice blade, a plunge saw will produce a nice cut that may only require a light sanding to finish.
Lots of ways really, I’ve seen people run a door through a table saw a few times too.
Offline Sanderxpander
« Reply #16 on: April 25, 2019, 05:05 PM »
I've trimmed a few doors with my 55 but never used a plane on it. I think I did lightly hand sand them before painting but I dare anyone to spot any roughness from skipping planing after two layers of ground paint and two layers of finish. Let alone it's the side or bottom of the door.
Offline dataz722
« Reply #17 on: May 02, 2019, 08:40 AM »
To me the biggest concern isn't the saw, its what type of door it is and how much needs to come off.  If its not a solid wood door and you need to take more than a 1/2" on each side you could run into problems.  Either opening it up to empty space or an MDF core.
Offline demographic
« Reply #18 on: May 02, 2019, 02:59 PM »
Weird, personally I hardly ever touch a door with a sander.
In fact, its a rare day when I sand anything.
Plane? heck yes,
Cabinet scraper? On hardwood sometimes, not much good on softwood.
Sander? I don't even own one although I guess my multicutter thing counts with the right attachment.
Surely it takes longer to sand a door edge than to do a couple of passes with a plane? What about removing the arris/sharp edge?
This is in a commercial environment and I'm a carpenter not a piano maker, I've done shuttering in sewage works and finishing carpentry in a billionaires grouse shooting lodge but realistically most of my work is kind of in the middle of that and schools, care homes, bars, some housebashing but I try to avoid that cos the money isn't really there.
To my eyes a decent handplane is an amazingly versatile tool, doesn't need plugged in and gives the best finish.
A sawcut is never a finish detail unless I'm building a barn, heck I even try to hide it on formwork so it doesn't end up on the finished concrete.
I still say that using a saw is a perfectly valid first stage for a door edge, but just giving it a few passes with a handplane is so easy and effective that i just can't work out sanding it instead.
On the door bottom, heck yeah, who even see's it?  Unless its badly setup and some wally has designed it so it opens onto a stairwell without a landing its against the floor.
« Reply #19 on: May 02, 2019, 03:23 PM »
Obviously making a decision to sand or not, would be subject to the state of finish after sawing, or planing or both.
With the right blade and technique, the saw or planer should suffice but, if that’s not the case, a light sanding won’t hurt before paint or lacquer.
It depends on a few variables, door type, material type, and how much is to be removed.
Offline RussellS
« Reply #20 on: May 02, 2019, 03:39 PM »
At my parents I used my TS55 to trim the Bottom of some hollow core doors after they had new fluffier thicker carpet installed.  I used some sandpaper to knock the edges off after cutting.
« Last Edit: May 03, 2019, 12:02 AM by RussellS »
« Reply #21 on: May 02, 2019, 04:52 PM »
I just don't own a whole bunch of planes and sandpaper is a cheap, quick and effective way to clean and break the edges or smooth any roughness from the saw (although tbh the cut itself always seems very clean with the TS55, if it's going to be painted).
Offline RNEMTP
« Reply #22 on: November 06, 2019, 03:56 AM »
I'm a Handyman and I have 2 track saws. 3 Miter saws, 1 of which is a Kapex. There's something to be said about professionalism and using the right tool for the job. Call me a snob but I wouldn't let anyone in my house to do work if they we using Ryobi Home Depot specials.  I trim doors all the time with my track saw. I also use a power planer if it only needs a little taken off. Or even a block plane if it's just a pesky corner. More to the point is to pay attention to the gap all the way around the door. Many times the adjustment can be made by spreading or squeezing a hinge or two. Many times the track saw produces a smoother edge than what was previously there. I run into a lot of MDF core doors that need trimming. For those, a saw cut edge is plenty smooth.
Offline TXFIVEO
« Reply #23 on: November 20, 2019, 10:56 AM »
I've used my Festool TS75 to trim the length AND width on many doors...Knotty Pine, Ash, Knotty Alder, White Oak, Maple, Reclaimed Barn Wood...has performed flawlessly with excellent results.
Offline TXFIVEO
« Reply #24 on: November 20, 2019, 12:10 PM »
Here ya go...
