Author Topic: Testing straightness of guide rail  (Read 557 times)
Offline Chris Cianci
« on: June 29, 2020, 05:43 PM »
Where do you test straightness of a guide rail? Along the rib the saw rides on.? On the non saw side along the rib that’s furthest away from the saw blade?
Offline TwelvebyTwenty
Re: Testing straightness of guide rail
« Reply #1 on: June 29, 2020, 06:20 PM »
Test what you cut rather than the rail.
Offline ear3
« Reply #2 on: June 30, 2020, 09:23 AM »
Do test cuts on two pieces of plywood and see if there are any gaps when you line up the cut sides.
Online tallgrass
« Reply #3 on: June 30, 2020, 04:16 PM »
How do you plan on testing? Also what length of rail?
Offline Birdhunter
« Reply #4 on: July 01, 2020, 05:15 PM »
If I had any doubts about my rails, I'd test them against the bed on my jointer.
Birdhunter
Offline Oldwood
  • Alberta, Canada
« Reply #5 on: July 01, 2020, 06:11 PM »
I do a quick check in the store by setting the rail on the box it is shipped in and centering the back about in the middle of the box. I carefully score a mark on the box using the rail as a guide then flip the rail end for end and lay it against the line. Viewing the line against the edge to see if it is aligned.
This is just a quick check and as has been said the truth is told by cutting 2 long pieces and hold the edges together but you must make sure the panels you cut are not releasing tension. I find most sheet stock will bow when cut down the middle of the sheet so best to first cut the sheet in half then trim a 1/8" off both edges.
Confucius
