Author Topic: Domino 500 connectors and 3/4' melamine  (Read 1590 times)
Online VirTERM
« on: October 14, 2019, 07:42 AM »
Good Morning,
I am planning to build a large bookcase from 3/4 melamine. The size is 2.1m by 2.1m and 30cm deep. I want to use melamine as the bookcase needs to be glossy white. Because of the number of shelves and the size, and since I already own Domino 500, I am contemplating using a Domino 500 connectors (do not have the connectors set yet).
A couple of questions:
Can I use an 8mm cutter with 3/4' melamine without being worry about damaging it? Will 15/25 drilling depth be ok with 3/4" melamine?
Will Domino connectors hold the construction sturdy?
I have never worked with melamine, but my basic research made me worry a bit. Will melamine work for this or perhaps I should be looking into the ply and prime/paint it at the end?
Please advise
« Last Edit: October 14, 2019, 07:56 AM by VirTERM »
Online VirTERM
Re: Domino 500 connectors and 3/4” melamine
« Reply #1 on: October 14, 2019, 05:54 PM »
Is anyone using Domino connectors with melamine?
Offline KescoNY
Re: Domino 500 connectors and 3/4' melamine
« Reply #2 on: October 14, 2019, 10:33 PM »
We use the connectors on melamine very often with no issues.  I mainly use the 5mm pin connection (kv-lr32).  I use it mainly for onsite assembly. I find them very useful for glue ups on melamine.  Very small percentage of my work is melamine (250-300 sheets a year ) but the connectors held up well for me. I add confirmat screws whenever not visible
Edit; If you need additional strength, you can opt for ply core melamine
Kapex/UG Cart/UG extensions TXS Set CXS Set PDC 18/4+3 BHC18 T18+3 Centrotec Installer's Set TS 75 TS55 TSC 55  Carvex PSC Carvex 420 & Accessory Kit  Domino 500 Set  Domino 700 set OF1010 OF 1400 OF 2200 & Accessory Kit  LR 32 Rotex 90 Rotex 150 Rotex 125  ETS-EC 150 ETS-EC 125 ETS 150 ETS 125 DTS 400 RTS 400  CT Midi CT36AC CT48 w/boom MFT3 CMS GE set with TS75, TS55, OF1400 plate  CMS VL
Online VirTERM
« Reply #3 on: November 05, 2019, 08:11 PM »
Online VirTERM
« Reply #4 on: November 06, 2019, 08:04 PM »
Just to clarify, you are referring to 3/4” or 5/8” melamine?
Offline KescoNY
« Reply #5 on: November 07, 2019, 12:32 AM »
Yes,  mainly 3/4’
Offline kcufstoidi
« Reply #6 on: November 07, 2019, 07:27 AM »
Plycore melamine? Been doing this a long time and never heard of this one. What's the price point per sheet and who sells it?
Offline ChuckM
« Reply #7 on: November 07, 2019, 09:30 AM »
Homedepot.com
« Last Edit: November 07, 2019, 09:35 AM by ChuckM »
Offline KescoNY
« Reply #8 on: November 07, 2019, 11:12 PM »
All my local suppliers carry it and it can also be had in many colors/finishes
Offline kcufstoidi
« Reply #9 on: November 08, 2019, 12:16 AM »
Did a search of Home Depot USA and saw nothing, did a web search looks of stuff from China in abundance but nothing that any wholesale dealers in southern Ontario carry. I will contact a couple of suppliers and see if its priced in the stupid zone or a unicorn here.
Online VirTERM
« Reply #10 on: November 08, 2019, 01:36 AM »
Same here, I can not find it.....
Offline ChuckM
« Reply #11 on: November 08, 2019, 08:51 AM »
« Last Edit: November 08, 2019, 09:38 AM by ChuckM »
Offline kcufstoidi
« Reply #12 on: November 08, 2019, 09:54 AM »
Not to get picky but its not melamine finish like whats found on particle core or MDF thats a paper that is hot fused on the board, its HPL like found on countertops. Not available in Canada from the depot but you could get it laided up for about for $100.00 + a sheet depending on the HPL. The site also doesn't have a price even in USD.
« Reply #13 on: November 08, 2019, 12:07 PM »
Down in the question section it says it's $69 per sheet.
« Reply #14 on: November 08, 2019, 12:19 PM »
Not available within 100 miles of my location.
« Reply #15 on: November 08, 2019, 12:26 PM »
Not in my location either... [mad] [mad] [mad]...even though the Boise Cascade Distributor is only 15 miles away from me.
