Author Topic: plumbing and leveling framed "boxing in" using the domino  (Read 5956 times)
Offline Tom Bainbridge
  • Limey Carpenter
i was doing some framed boxing in today 300 off the wall, a metre high and covered with ply (to take tiling)
the floor AND the wall were all over the place, normally this type of work is a pain, almost every piece of the frame has to be cut and fitted individualy (and you still have to tweek it) , i couldnt be arsed
so i made up a "square frame" using dominos (and left them all loose) fixed the floor and wall plate
then leveled and plumbed one end (firing 2 no, 16 guage brads through the framing into each domino) to "fix" the plumb and level
did the same at the other end, then then fired brads into all the remaining dominos
(each "joint" has a varying amount of visible domino, dependeding on the wall or floor plate position)
the ply face to the frame (scribed to the floor first) and the top (scribed to the wall) stiffens the whole unit into an immovable object
job jobbed    8)
« Last Edit: May 14, 2008, 03:28 PM by dirtydeeds »
Bromley, Kent. UK
aka dirtydeeds
  • Limey Carpenter
Re: framed boxing in using the domino
« Reply #1 on: May 14, 2008, 03:00 PM »
then on the way home (2 and a half hours for a 16 mile journey   :P ) i got to thinking and realised where i got the idea
festool made a sun bed where open joints with visible dominos where a feature of the design
« Last Edit: May 14, 2008, 03:06 PM by dirtydeeds »
Bromley, Kent. UK
aka dirtydeeds
Re: plumbing and leveling framed "boxing in" using the domino
« Reply #2 on: May 14, 2008, 04:28 PM »
job jobbed    8)
Brilliant!
« Reply #3 on: May 14, 2008, 04:29 PM »
Where and when did you see this?
  • Limey Carpenter
« Reply #4 on: May 14, 2008, 04:33 PM »
i think, and stress the word think
it was on a uk demonstration dvd for the domino
« Last Edit: May 14, 2008, 05:29 PM by dirtydeeds »
Bromley, Kent. UK
aka dirtydeeds
  • Limey Carpenter
« Reply #5 on: May 28, 2008, 03:37 PM »
apart from mk my idea clearly hasnt rung any bells or sparked anybodys imagination
here is a photo from another piece of work to show how the double pinning each domino can be used to level and plumb a framed box out
all youve got to imagine is that the floor slopes and instead of the joints being tight like this photo you leave the joints slightly open and just double pin them when youve leveled them
Bromley, Kent. UK
aka dirtydeeds
Offline patrick anderson
    • neoshed
« Reply #6 on: May 28, 2008, 04:26 PM »
I don't have a domi to try it out with mate but I did think it was a clever idea when I first read it.
patrick anderson
www.neoshed.com
may the festool be with you.....always
Offline Forrest Anderson
« Reply #7 on: May 28, 2008, 04:34 PM »
Same here - I reckon it's a neat idea, and one which I'll try to remember.
Forrest
Compiler of the Consolidated List of Festool Links - the place to go for Festool reviews, manuals, brochures and videos!
  • Limey Carpenter
« Reply #8 on: May 28, 2008, 05:07 PM »
in reply to both mr andersons
this idea isnt "a clever idea"
its just an idea that you MIGHT remember one day (i hope........... without thinking)
all i hope is that one day you can use it (or adapt/apply the basic idea) to your benefit
and make a bit of money
good luck
dd
Bromley, Kent. UK
aka dirtydeeds
