Author Topic: Sticky LR 32 plunger/lever  (Read 535 times)
Offline Df1k1
« on: December 24, 2022, 08:17 AM »
So when using the LR 32 I’ve noticed the plunger that you push on to move the router has become very finicky and sticks. I sprayed it with some WD-40 but that does not seem to help. It’s a little dangerous to be fighting with the lever while the router is spinning.  I’ve looked at the knob on top of the lever and there does not appear to be a way to loosen it. Any thoughts?
Online NiteWalkerGR
Re: Sticky LR 32 plunger/lever
« Reply #1 on: December 24, 2022, 09:06 AM »
I'd clean the wd40 off and use a different lubricant; wd40 isn't really a good lube. I like super lube; it's a good all around lube and a tube is pretty cheap.
Offline Df1k1
« Reply #2 on: December 24, 2022, 02:48 PM »
Awesome thanks. Glad I’m not the only one who’s had this
Offline Jeff Zanin
« Reply #3 on: December 26, 2022, 03:49 PM »
Superlube or PTFE.
