For some dubious reason the TS 75 is delivered cutting about a millimeter closer to the rail than the TS 55. Go figure.
Quote from: Michael Kellough on October 16, 2019, 06:13 PMFor some dubious reason the TS 75 is delivered cutting about a millimeter closer to the rail than the TS 55. Go figure.You can adjust the TS so both cut at the same position for the splinter strip on the rail being in perfect position for both.See the supplemental manual on how to do that.
Is it just the cams that do the blade to splinterguard distance adjustments or is there something else on the saw to make that adjustment?
