Drew,
It's not possible to help solve the problem unless we understand the problem. You might have a bad CT. It might be something wrong with the setup. As David wrote, it might be a blown circuit breaker. It might be user error. Could be almost anything. So...
What is the problem that you are trying to solve? What are the symptoms? What are the steps that lead up to the problem?
Regards,
Dan.
p.s., a famous tech support story - A user calls up tech support complaining that the computer doesn't work:
Customer: I'm having problems with my 'puter.
Tech Support: What's the problem?
Customer: The screen is black!
Tech Support: Hmmm... Is the power switch on?
Customer: Uhhhh... Yes!
Tech Support: OK... Is it plugged in?
Customer: Gimme a sec and I'll look...
Tech Support: OK...
Customer: I can't see if it's plugged in.
Tech Support: Oh?
Customer: The lights are off.
Tech Support: Can you turn them on?
Customer: No. The power is out in the building.
Tech Support: (Speechless!!!)
