Author Topic: Saw took chunks out of black plastic guide on 45degree mitre cut  (Read 1661 times)
Offline Welsh dragon
Saw blade took chunks out of black plastic guide on 45 angle cut.
Offline luvmytoolz
Re: Saw took chunks out of black plastic guide on 45degree mitre cut
« Reply #1 on: October 05, 2022, 11:15 PM »
I assume this was the rubber dust shroud which can get pushed in the way depending on the cut/angle?
Or is this the slot cover on the base, in which case unless the head has some looseness causing it to move or twist in use, it shouldn't be able to chip it?
« Last Edit: October 05, 2022, 11:19 PM by luvmytoolz »
Offline SRSemenza
« Reply #2 on: October 06, 2022, 12:29 AM »
Which saw are you talking about?  Which guide in particular?
Offline tjbnwi
« Reply #3 on: October 06, 2022, 12:36 AM »
Odd for that to happen on a miter cut, will happen on the first bevel rip.
Offline Crazyraceguy
« Reply #4 on: October 06, 2022, 05:47 PM »
There is usually some ambiguity in those terms. Confusion set in pretty quickly.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Online woodbutcherbower
« Reply #5 on: October 08, 2022, 01:00 PM »
Welsh dragon has left the building.
Offline Coen
« Reply #6 on: October 16, 2022, 04:00 PM »
? The anti-splinter strip on the guide rail? Did the saw ride over some dirt, lifting it?
Offline SRSemenza
« Reply #7 on: October 16, 2022, 04:03 PM »
OP has not returned. We really don't know which saw or what black part.
