Author Topic: Saw blade sharpening sources?  (Read 52132 times)
Offline neilc
« on: April 21, 2018, 04:06 PM »
Curious where you get your saw blades sharpened - both for the circular saw as well as the Kapex.
Anyone have good luck with an online resource?
Thanks!
Offline Peter Halle
  • Ain't so Small no More
Re: Saw blade sharpening sources?
« Reply #1 on: April 21, 2018, 05:19 PM »
Tom has posted about Leitz in the past but the last time he posted about sharpening he said that he had switched to Quinn with equal or better results as Leitz with less hoops to go thru.
Here is Quinn's website:  http://quinnsaw.com/saw-blade-sharpening-services/
Offline neilc
« Reply #2 on: April 21, 2018, 06:02 PM »
Thanks Peter - I'll contact them on Monday -
Offline Rollin22Petes
« Reply #3 on: April 21, 2018, 07:38 PM »
I would also check with your local cabinet shops and see if they have a local sharpener. I'm lucky that I have a local sharpener that does excellent work and is a dealer for most major brands. He picks up and drops off at the shop every other week so I don't have worry about shipping. Whoever you choose make sure they can correctly sharpen European blades not everybody can.
Offline montyss
« Reply #4 on: April 21, 2018, 07:49 PM »
Dynamic Saw in Buffalo Ny  , Great place does a very good job at reasonable  prices .
Offline tjbnwi
« Reply #5 on: April 21, 2018, 09:14 PM »
Yep, go with Quinn. I had them sharpen my planer blades last time. Just to see how they work out, I’ll send them a couple of 5 mm Domino bits to sharpen.
You should be very happy with their service.
You can fill out the online form, if you send them early Monday you’ll probably have them back by Friday.
Offline gunnyr
    • Compass Custom Creations
« Reply #6 on: April 21, 2018, 10:15 PM »
I've used Burns Tools with good results.  Seems like it took about 2 weeks round trip.
Ditto on a call to a local cabinet shop, you can bet they want a quality service and will likely recommend them to you.
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|RAS 115|OF 1400|OF 1010|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|OSC 18|CTC SYS|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
Offline leakyroof
« Reply #7 on: April 25, 2018, 03:17 PM »
Ask Chip at Wood World, I bet he handles that for them and would know .
Offline neilc
« Reply #8 on: April 25, 2018, 06:44 PM »
Thanks Leaky and others for your recommendations!  I almost reached out to Chip.
I was planning to send to Tom's recommendation in St Louis but started dealing with securely and properly packing them, mailing them, postage costs, etc and I ended up finding a sharpening service in Elk Grove Village here in Chicago - they sell Freud and Amana blades & bits and do sharpening.  Can handle blades up to 32" in diameter.    [eek]    Don't sharpen bandsaw blades but can send them out for sharpening.
Second generation owner runs the shop.  Nice guy and very knowledgable.  One week turnaround and no need to ship.
His fee on the blades was like $15-17 each for TS55, 8" and 10" Inca blades and a Kapex blade.  Only the Kapex was the higher price.  Like most shops, they charge by the tooth.
Total Tooling Technology Inc
1475 Elmhurst Rd, Elk Grove Village, IL 60007
(847) 437-5135
http://www.totaltoolingtechnology.com
« Last Edit: April 25, 2018, 06:56 PM by neilc »
Offline leakyroof
« Reply #9 on: April 25, 2018, 09:10 PM »
(847) 437-5135
[thumbs up]
Offline BarneyD
« Reply #10 on: April 26, 2018, 08:43 AM »
(847) 437-5135
Thanks for this @neilc . I spent 38 years working right down the street from these guys and never knew they were there. On my list now. Thanks again.
Barney
Barney
Offline Rob Z
« Reply #11 on: April 26, 2018, 11:24 AM »
I've been sending blades and bits to Dave (the owner) for years. Good guy and always willing to talk if I have questions.
http://farrisprecision.com/aboutus.htm
Offline delong1974
« Reply #12 on: May 14, 2018, 08:58 PM »
Leitz has a $50 minimum, though.
Offline jobsworth
  • Festool Baby.....
« Reply #13 on: May 14, 2018, 10:48 PM »
1A Saw Sharpening, Theyre about 5 min from my house just had them sharpen my Kapex blade and a Zobo bit. Did a very good job. I got a couple of blades to take to them this week.
Offline JimH2
« Reply #14 on: January 29, 2019, 12:49 PM »
Leitz has some hurdles. I used them because they are close. I gave them a try because they were only a day away via FedEx Ground. In order to setup an account with them you have to get them your business tax ID or SSN. This is required even if you are paying by Credit Card. I could see needing this for a revolving account where credit is being granted, but this is unheard of. I left it blank when I sent the form over thinking it was only if you were using a tax-exempt status to avoid sales tax. It is usual and customary to ask for this when claiming to be tax exempt. I had already sent the blades or I would have regrouped.
Offline l0pht
« Reply #15 on: February 02, 2019, 11:26 PM »
https://3bsawandtool.com/
These guys are awesome
Offline Farming_Sawyer
  • Sawyer, builder, winemaker, farmer, chef
    • Foley's Custom Sawmill
« Reply #16 on: February 03, 2019, 08:53 AM »
I this would be A great post to pin to the top of this board as a collection of resources. I'm looking for a place locally that will sharpen Festool and Oshlun blades, here in Maine. If I find some place, I'd add it.....
CT 26E, RO125, sys-mft, sys-toolbox, a bunch of 30 year old tools I'm looking to replace.
Offline Peter Halle
« Reply #17 on: February 03, 2019, 09:25 AM »
Great Suggestion!   [thumbs up] [thumbs up]
Now a sticky!
Offline JimH2
« Reply #18 on: February 07, 2019, 09:23 PM »
I used Leitz last week and the service was stellar. You have to give out your SSN or EIN, which seems crazy considering I paid by CC. You probably could just make one up. 3 Kapex and 1 TS-55 blade were $108. I included a return shipping label. I'm in NC and sent them to NC so shipping was negligible. Their communication was outstanding (many emails). Blades were returned with the teeth covered by a blue membrane and each in a Festool like cardboard sleeve. I will be using them again.
Offline Jack01
« Reply #19 on: February 22, 2019, 04:57 PM »
Family Hardware   Florida   They are Freude certified
Sharpening
If you send 5 blades shipping is free. That is a great value.
Price competitive to local shop as well as online shops.
If you can find couple of woodworkers close to you go with on this deal you will save on shipping and be very reasonable.
Offline Alanbach
« Reply #20 on: February 22, 2019, 08:55 PM »
I am curious why no one has mentioned Forrest? I have always had great results from them. I have not had my TS55 long enough to need any of my Festool blades sharpened yet but they do great with all of my other blades.
Offline Laminator
« Reply #21 on: February 22, 2019, 09:40 PM »
I used Forrest sharpening for many years with great results.  Unless they have changed recently, they will not sharpen festool blades because of the variable spacing of the teeth on some of their blades.   I used Carbide Processors for the last blades I had sharpened.
Online RJNeal
« Reply #22 on: February 22, 2019, 09:57 PM »
I sent some blades to Forrest including a kapex blade. This was probably 8 years ago or so. It came back shape but out of round. Like they didn’t use the correct arbor spacer.
Since then I sent all my blades to LA Grinding in Burbank. Ca.
Nice job.
Rick.
Offline Alanbach
« Reply #23 on: August 09, 2019, 11:42 AM »
I think that if you contact Forrest you will find that they have changed. I believe that they bought new equipment a few years back to be able to handle FT and some other European style blade types. Talk to Tony.
Offline WilliamCoffey
« Reply #24 on: July 11, 2020, 05:40 AM »
It is not a heavy task for anyone, You can do it easy. there is such easy way to do it thanks!
Offline Birdhunter
« Reply #25 on: July 11, 2020, 07:04 AM »
Forrest sharpens my table saw blades AND my Kapex blades. I do think the kerf gets very slightly narrower after sharpening.
Birdhunter
Offline Bob D.
  • Inactive Member
    • My Cordless Workshop
« Reply #26 on: February 23, 2021, 09:19 PM »
I send all my blades to Ridge Carbide. They do a good job, price is reasonable, quick turnaround. I send them all my TS, RAS, and MS blades that need sharpening when I get about 3 or 4 in need of their magic.
https://ridgecarbidetool.com/pages/sharpening-service
They also make custom knives for molders and other tools.
« Last Edit: February 23, 2021, 09:23 PM by Bob D. »
Offline CeeJay
« Reply #27 on: February 23, 2021, 09:25 PM »
Other side of the world.
I use Brisbane Saw Service in Queensland. Drop off blades 7am on my way to work and pick them up a few days later.  Always been excellent.
Offline SRSemenza
« Reply #28 on: February 23, 2021, 11:34 PM »
     I have had two custom router bits made by Ridge. They are very good quality, and exact to specifications.  Customer service for the custom bits was a bit old school but it was also  very good. There is one person that handles the custom bits (perhaps the owner ?) and both times involved a phone conversation.  In one case I had a molding piece that I sent to be copied for the bit. In the other I sent a drawing. Even though it was old school I couldn't be happier with the process and turn around time.
Offline CeeJay
« Reply #29 on: February 24, 2021, 12:45 AM »
I wanted a particular blade from Ridge. They don’t ship to Australia. I contacted John Ferrie the owner and he arranged shipping for me overnight.
Great service - I imagine their sharpening service is similarly good.
Offline woodbutcherbower
« Reply #30 on: June 02, 2021, 05:48 PM »
For anyone in the Midlands of England, I've been using LM Cutting Tools (based in Langley Mill, Nottinghamshire) for years. Their standard rate is 8 pence per tooth and they always come back razor-sharp. I have 36 saw blades ranging from a pile of 48T x 160mm crosscuts for the TS55, right through to half a dozen 96T x 305mm for the DeWalt 780 - plus a few other sizes and quantities in between. It's staggering how many you get through when you do this for a living.
Offline fp1337
« Reply #31 on: June 24, 2021, 02:43 PM »
Anyone know of a good carbide blade sharpening place around Boston? I found Atlantic-Carbide in Somerville. Anyone used them or someone else around that area?
Freud has an authorized sharpener in MA called "The Sharp Tool" but it's a little far from Boston.
I want to avoid shipping charges both ways, it might defeat the purpose, price-wise.
Offline Crazyraceguy
« Reply #32 on: July 14, 2021, 08:15 PM »
Another one for Leitz. We were using a local "saw & tool" company and had been for many years. They ran into a problem a few years ago of something similar to what RJneal mentioned, egg shaped. After we complained about it, they did fix the problem with the offending machine and even replaced a few blades, but when it started happening again? nope. We're out. Time to find someone new. It really sucked though, because they would take saw blades, router bits, Forstner bits, even holesaws and carried a lot of new ones right in his van. So you could get another one while the first one was gone. We always maintain spares, but occasionally some do need replacing or you need a new router bit or bearing. This was very handy and he came every week. The Leitz guy is not as comprehensive, but the sharpening is much better. Of course in recent years, the internet has brought quicker/easier ordering too.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
