Author Topic: Saw blade sharpening sources?  (Read 51863 times)
Offline woodbutcherbower
Re: Saw blade sharpening sources?
« Reply #30 on: June 02, 2021, 05:48 PM »
For anyone in the Midlands of England, I've been using LM Cutting Tools (based in Langley Mill, Nottinghamshire) for years. Their standard rate is 8 pence per tooth and they always come back razor-sharp. I have 36 saw blades ranging from a pile of 48T x 160mm crosscuts for the TS55, right through to half a dozen 96T x 305mm for the DeWalt 780 - plus a few other sizes and quantities in between. It's staggering how many you get through when you do this for a living.
Offline fp1337
« Reply #31 on: June 24, 2021, 02:43 PM »
Anyone know of a good carbide blade sharpening place around Boston? I found Atlantic-Carbide in Somerville. Anyone used them or someone else around that area?
Freud has an authorized sharpener in MA called "The Sharp Tool" but it's a little far from Boston.
I want to avoid shipping charges both ways, it might defeat the purpose, price-wise.
Offline Crazyraceguy
« Reply #32 on: July 14, 2021, 08:15 PM »
Another one for Leitz. We were using a local "saw & tool" company and had been for many years. They ran into a problem a few years ago of something similar to what RJneal mentioned, egg shaped. After we complained about it, they did fix the problem with the offending machine and even replaced a few blades, but when it started happening again? nope. We're out. Time to find someone new. It really sucked though, because they would take saw blades, router bits, Forstner bits, even holesaws and carried a lot of new ones right in his van. So you could get another one while the first one was gone. We always maintain spares, but occasionally some do need replacing or you need a new router bit or bearing. This was very handy and he came every week. The Leitz guy is not as comprehensive, but the sharpening is much better. Of course in recent years, the internet has brought quicker/easier ordering too.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
