Author Topic: Sandpaper buildup  (Read 1126 times)
Offline JG
Sandpaper buildup
« on: May 23, 2021, 10:24 AM »
Hey foggers,
I am looking for some assistance with an ongoing issue when sanding outdoor rails, decks, etc.  Using my RO 125 or 90 sander with my CT36 vat.  Before sanding, I thoroughly scrape the paint in all directions to remove any loose or peeing paint.  I use 60 grit Granat sandpaper.  I originally set the suction on vac at max and speed on sander to 6.  The sanding paper gummed up with paint rather quickly.  I reduced the suction to half and the speed to 4.  Still encounter the issue.  I have experienced it on several jobs.  Having issues uploading the picture.   Any ideas what the problem is or how to resolve it?  Also, can the sandpaper be cleaned? I go through a lot of sandpaper quickly.  Thanks.
Jim
Offline squall_line
Re: Sandpaper buildup
« Reply #1 on: May 23, 2021, 10:38 AM »
How much of the paper is in contact with the surface?
Are the holes on the surface or free-floating when you're using it?
Offline SRSemenza
« Reply #2 on: May 23, 2021, 10:45 AM »
For paint and finish removal you really have to keep the sander moving (even with the speed turned down) to avoid melting the paint onto the paper. Lots of fast passes to get the job done. It won't take care of the problem 100% but it helps.
Offline Alanbach
« Reply #3 on: May 23, 2021, 11:27 AM »
I would recommend that you try a box of Festool’s Saphir sandpaper. For that application I would try 36 grit. My bet is that it will change your life😊 (at least for this particular application).
Offline Alex
« Reply #4 on: May 23, 2021, 11:49 AM »
Some paints simply do not dry out as hard as others. This is especially true of water based paints, which are often of inferior quality. I just accept that I have to use more sandpaper on such paints.
Offline Vondawg
« Reply #5 on: May 23, 2021, 12:11 PM »
Perhaps you’ve already discovered using a putty knife at an angle, lightly..knocks off the gummed up spots on your sand paper (while machine is rotating)…like said, water base finishes are almost always prone to this
Offline Bert Vanderveen
« Reply #6 on: May 23, 2021, 02:20 PM »
A block of natural rubber is used to clean sandpaper. In a pinch the sole of a Clarks desert boot will do, too.
Search for "sandpaper cleaning block" and you’ll fine, even at Walmart’s!
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
« Reply #7 on: May 23, 2021, 03:31 PM »
I used to use a putty knife but it tended to knock off the grit if I wasn't really careful, I now use one of these in the Rotex mode.
https://powertecproducts.com/71002-abrasive-cleaning-stick-8-1-2/
Offline Crazyraceguy
« Reply #8 on: May 23, 2021, 06:11 PM »
Stripping paint and fine sanding of finishes up to a polished state both share the same problem.
With fine grits, the paper loads up and causes pigtails. Little blobs build up and it is generally referred to as "corning"  (at least in the US)
With stripping, the same thing happens, but the symptoms are different. The paper loads up and quits cutting. The blobs get hot and (depending on the paint type) melts and gums up more.
Both of these are caused by one of two things.
1) The material is not cured enough.
This usually happens when the finishing process is hurried. The finish or filler has not dried long enough.
2 The abrasive is too fine. Simply switching to a lower grit and/or a coated abrasive. These are designed for stripping/ anti-clogging.
Starting with an abrasive that is too fine, not only wastes paper, it wastes time too.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
Offline Alanbach
« Reply #9 on: May 24, 2021, 12:28 AM »
As I alluded to above, I think that 60 grit on an older heavy film finish is too high a grit. It causes you to have to make the sander to work too hard and that creates excess friction and the associated heat it generates. I also think that Granat is great sandpaper but NOT ideal for removing paint. I really think that you will have greatly improved results with Saphir and with a lower grit like 36.
