At least on my Kapex, the angle detents are all on the same metal semi circle, so it seems like it would not be possible to adjust the right without also changing the left, unless you want to try to file out some of the holes, though as the last comment suggests, maybe by pushing one side in or out (as opposed to rotating), you might be able to effectively just adjust the angle on one side.
