Author Topic: OF-1010 REQ micro adjust  (Read 732 times)
Offline HowardH
« on: January 01, 2023, 06:53 PM »
i am going to route some dados using the 1010 with an 18mm straight bit.  If the plywood doesn't quite fit into the dado, what's the best way to adjust for a precise fit?  That router used to have an accessory, the Of-WA I think, which was a micro adjuster that worked on the old model but it's no longer listed on the Festoolusa website. What's the best practice for this operation using the router?  I also have a 1400 but it's mounted in my CMS table so I don't want to remove it if I don't have to.
Howard H
P1cc, T15, TID-18, RO150FEQ, ETS EC 150, MT55cc, RTS400, CT22, CT36E, 800, 1080, 1400, 1400 holey, 1900 rails, OF1400, OF1010, CSX, C18, LR32, VacSys, Vecturo, Domino, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE, PM 1500, Jet J/P, FS-WA, Shaper Origin. Felder AF-14, TSC 55 KEB, Dash-Board bench system
Offline HowardH
Howard H
Offline mino
Re: OF-1010 REQ micro adjust
« Reply #3 on: January 02, 2023, 05:46 AM »
Do note that the OF 1010 edge guide fits *both* the OF 1010 as well as the 1010 REQ:
https://www.festool.com/accessory/489427---sa-of-1000#Overview
Not sure why the compatibility list is not mentioned on the Festool USA site ..
@Festool USA
https://www.festoolusa.com/accessory/489427---sa-of-1000#Overview
From what I gaher, all accessories which use the rods or screw to the base are compatible between the whole OF 900/1000/1010/1010 R range.
So you can use the dedicated fine adjuster for it as for the OF 1010:
https://www.toolnirvana.com/collections/router-accessories/products/festool-483358-fine-adjuster-for-of-1010-edge-guide
My personal advice is get to the edge guide, two of them actually - so you can use them for edge routing like for hinges. And get one fine adjuster for them. *)
And get the micro adjuster noted as well.
It is useful in some other use cases. To be short - stock up on most/all accessories for the OF 1010 R. They completely transform what can be done with the tool. Buying an OF 1010 and skimping on accessories, is IMO losing like 60% of the value the tool brings. But I do not am your purse master.
:D
*) EDIT: Just now noticed the Q was not for edge referencing
« Last Edit: January 02, 2023, 06:01 AM by mino »
The Machine has no brains. Use Yours!
Offline Crazyraceguy
« Reply #4 on: January 02, 2023, 06:32 PM »
The main thing to pay attention to when using any type of micro adjuster to widen a groove with a router is which direction you adjust toward. Whether you are using an edge guide, or with the rail, you do not want to get into a climb-cut situation.
This applies to router tables too. If you run a groove and need to widen it, you must move the fence back. This puts the newly cut area in the front. Having it cut the area between the part and the fence is an accident waiting to happen.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
