Hello guys,
I have a question regarding the MFK700 router. I know that is it an excellent trim router for the purpose of trimming edge banding (both ABS/PVC and solid wood trim).
My question is can I use it to trim melamine edge using a compression bit to get a perfect side without any chipping? In other words, I would use my TS-75 track saw to cut my melamine 2mm more than needed, then I would use my MFK700 with a compression bit to go over the edges to get a perfect chip-free edge. Can this process be done using your hands on top rather than mounting the MFK700 into a custom router table?
Also, beside a trim router, what other function can we do with the MFK700?
Thanks guys!
