Author Topic: Mfk 700 modification by half inch shy  (Read 5763 times)
Offline lshah72414
« on: May 21, 2017, 03:04 PM »
I was watching videos by paul marcel(half inch shy) and he was talking about a modification he was going to make to his mfk 700 so he can use longer router bits. Does any one know the link so I can see exactly what he did?
Offline Runhard
Daniel
Offline lshah72414
Re: Mfk 700 modification by half inch shy
« Reply #2 on: May 21, 2017, 03:21 PM »
thank you very much!
Offline ear3
« Reply #3 on: May 21, 2017, 04:17 PM »
Has anyone ever tested the proposition of whether this is warranty voiding?
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3 • STM 1800
Offline Frank-Jan
« Reply #4 on: May 21, 2017, 05:08 PM »
I don't own a mfk 700, but given that you modify a removable base, if you have a warranty issue (that is not related to using a longer than intended bit), you can just send the tool in with the non modified base.
Offline queball
« Reply #5 on: January 29, 2018, 09:51 PM »
So has anyone else tried this? Any addition tips on the modification or reasons not to do it?
Offline T. Ernsberger
« Reply #6 on: January 30, 2018, 07:43 AM »
I’ve done it and it works great.  In my opinion it should have been made this way.
« Reply #7 on: January 30, 2018, 07:47 AM »
It should not effect warranty,  its a modification of an accessory and not the tool.
Offline queball
« Reply #8 on: January 30, 2018, 07:53 AM »
I agree not sure why they would limit the capacity to 5/8". What bit are you using?
Offline Bert Vanderveen
« Reply #9 on: January 30, 2018, 11:50 AM »
Longer bits = higher chance of wobble = unsatisfying edge.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Wishlist: ETS EC 125 w 150 pad, DTS — on order!
Offline Bugsysiegals
« Reply #10 on: September 18, 2020, 10:34 AM »
I'm making shop cabinets with 3/4" Maple plywood and 3/4" Walnut edge banding.  I ended up buying the OF1010 with adapters because the MFK couldn't cut that deep.  The OF1010 works well but still required me to finish with hand plane and when I wasn't paying enough attention I forgot to support the weight and took a small chunk out of the edge banding.
That said, what depth does this modification allow you to achieve?  Does it allow the bit to wobble as suggested?  If trimming 3/4" edge banding would you still need the hand plane (wondering if the finish would be the same as what I have with the OF1010 but just a lighter form factor tool)?  Does it impact the ability to fine tune the depth on cuts where you want more shallow trimming?
« Reply #11 on: September 19, 2020, 11:08 AM »
I've marked up my MFK and plan on doing this modification, just haven't gotten around to it yet. It appears to add about an additional 1/2" of reach. A standard bit cutting length of 16 mm versus the 25 mm cutting length of the modified base using a Vortex solid carbide router bit.
I wouldn't worry about any wobble if you use helical router bits especially if you use a solid carbide helical router bit like the Vortex. Solid carbide doesn't bend, it breaks.
I believe this modification dispenses completely with the hand planing.
Can't help you on the last item until I do the modification.  [smile]
Offline Rick Herrick
« Reply #12 on: October 29, 2020, 10:00 AM »
Could it be possible, and safe, to use an oscillating tool here instead of a coping/fret saw?  I don't have either of those 2 saws and while googling to find the saws/blades, etc, I got sent to a page with osc saw blades.  I would guess you have to 'knibble' out the cutout and the fine tuning of it would take more time.  I do have an osc tool.  Only used it a couple of times but it is a tremendous tool when needed.
What is the difference between a coping and fret saw?  And what size ?  Knew has 3", 5" 8".  Again, I know very little about this type of tool so looking for pointers.
Offline Roachmill
« Reply #13 on: October 29, 2020, 10:40 AM »
I used a hacksaw to do mine. Not sure I'd trust [me with] a multitool  [embarassed]
« Reply #14 on: October 29, 2020, 10:53 AM »
I like it.  I like to say "No b*s no blue chips" .. So it worked out for you?  Your MFK is now modded and doing what you expected?
Offline Roachmill
« Reply #15 on: October 29, 2020, 11:21 AM »
Yep, it worked a treat. It did feel a bit unsettling taking a hacksaw to an expensive bit of kit but, for the extra capacity, it was well worth it.
« Reply #16 on: October 29, 2020, 11:41 AM »
Glad that worked.  Just ordered by 0 degree base so I can give it a shot.
« Reply #17 on: October 29, 2020, 11:58 AM »
I've $500 Christmas gift waiting to be spent ... considering whether it would be worth buying the MFK700 and 0 degree base even if it's only to do edge band trimming on personal home renovation cabinetry and perhaps chamfer/roundover on various projects or save for something else and keep using the OF1010/OF1400?
« Reply #18 on: October 29, 2020, 12:27 PM »
In my 'very limited' exposure to the MFK, if you are doing only iron-on edge banding, you probably don't need the 0 degree.  It was only when I tested 1/2" oak (with the 1.5 base) that I noticed how obvious a 1.5 degree cut was.  If you don't do a bunch of edge banding, I would get the pieces to go with the 1010 and watch Peter Parfitt's OF 1010 videos.  With those, you can still do edge trimming.  Sometimes I get tempted to return my MFK and get another 1010.  I like keeping my existing one with my LR32 set.
« Reply #19 on: October 29, 2020, 12:30 PM »
Yeah I started with the OF1400 and then added the OF1010 with attachments as the OF1400 was to heavy to make consistent good results. The OF1010 does work but wondered if the MFK would produce flawless results rather than the OF1010 which may gouge if not careful and or require some final bench plane to clean up.
« Reply #20 on: October 29, 2020, 12:45 PM »
So far the MFK is very nice once you dial it in.  I still have a habit of hitting the edge with a piece of 400 grit but even that is probably not needed.  Its so easy to set up and you get none of that tear out I got with the razor blade trimmers.  It is a nice tool.  I guess if I had a tight budget, I probably wouldn't get it but things are going pretty good now so getting tools while I can before retirement hits.
Offline Crazyraceguy
« Reply #21 on: November 21, 2020, 04:38 PM »
Use an 8mm shank bit and it will be fine.
I have done it to two different bases because I had one destroyed by a fire about 15 months ago. I has worked well for me. mine is cut more dramatically then the above pics also. It takes a 3/4" diameter bit with a full 1" cut length, found on the Lee Valley website.
CSX
DF500
PS420 + Base kit
OF1010
OF1400
MFK700
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
