Author Topic: Make an adaptor for thin workpiece holding with Festool Vac Sys  (Read 1020 times)
Offline wrobertdavis
I have posted two videos about this topic.  They are short and hopefully helpful to others.
Bob
Offline Rick Herrick
Re: Make an adaptor for thin workpiece holding with Festool Vac Sys
« Reply #1 on: October 02, 2021, 12:13 AM »
Thats a pretty nice resolution.  I would have a hard time getting that air hole all the way through. Looks like you did a good job on it.  Thanks for sharing this tip.
Offline jussi
« Reply #2 on: October 02, 2021, 08:11 AM »
Awesome tip.  I was thinking about buying the narrow head but will give this a try first.
Online Cheese
« Reply #3 on: October 02, 2021, 09:27 AM »
Great tip Robert...nice simple approach on the adapter and nice execution on cutting the vacuum seal.  [big grin]  That adhesive foam tape looks interesting, what is it normally used for?
Offline Claimdude
« Reply #4 on: October 02, 2021, 09:29 AM »
Great tip Bob!
Offline rst
« Reply #5 on: October 02, 2021, 12:39 PM »
Cheese, I've made dozens of vac jigs over the last 50 years, using self adhesive weatherseal.  I usually use Frost King 5/16 in. x 1/4 in. x 17 ft. White D-Center EPDM Medium Gap Weatherseal Tape that can be split.  I keep mine paired and overlap the ends. His jig is nice but you would not need the vertical wood part to be so high making drilling the air hole easier make.  I store my jigs with a piece of acrylic to protect the seals in storage.
Offline ChuckS
« Reply #6 on: October 02, 2021, 02:26 PM »
A clever trick indeed. The tall vertical board is needed because the OP uses it with the edge sanding guide.
I'd drill the long holes from both ends, using a self-centering doweling jig or a simple block with a guide bushing.
