I’m building a bookcase and plan to router in pin holes for adjustable shelves. I’m also planning on spraying this bookcase white. But, the LR-32 rail won’t fit into the built bookcase, so I’ll have to router in the pin holes before the bookcase is assembled.
My question is, do you usually paint your individual pieces, then router the holes, then assemble? Or router the holes, then assemble, then paint? I’m concerned the holes could get junked up with paint, so I was thinking the former, but I’m used to spraying furniture after it’s fully assembled. If I router the holes and spray it first, then assemble, won’t the glued edges (also pocket holed) not adhere as well, and won’t there be visible spaces near joined edges?
